08-13-2017, 20:10 | #3 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | First Change eMMC Voltage 1.8 volt ISP to 2.8 volt ISP, When Not Connect eMMC, Next... VCC & VCCQ Line Disconnect From Adapter, Then Use USB Cable PC to Mobile PCB for VCC & VCCQ. Last edited by Pijush Das; 08-13-2017 at 20:17. |
The Following User Says Thank You to Pijush Das For This Useful Post: |
08-14-2017, 17:11 | #6 (permalink) |
Member: 1902789 Status: Offline Thanks Meter: 1,100 | Hello Sir, You first use USB cable PC to Mobile PCB for VCC & VCCQ & eMMC voltage see under the Settings TAB |
08-14-2017, 17:52 | #9 (permalink) |
Member: 1902789 Status: Offline Thanks Meter: 1,100 | Please don't open settings Tab, Just Open eMMC Tool Tab & see down the setting Tab (sorry for my mistake is down not under) BUT i see ur adapter is RJ-45 --- this adapter for ATF Box & that is not work in Easy Jtag Last edited by Pijush Das; 08-14-2017 at 18:00. |
