Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 10-19-2017, 18:02   #106 (permalink)
Member: 2698255
Thaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaank you
Old 10-21-2017, 08:03   #107 (permalink)
Member: 1751613
Thanks Meter: 31
samsung sm g532g dead boot repair done si riaz 01812488833 samsung sm g532g dead boot repair done si riaz 01812488833
Old 10-23-2017, 08:15   #108 (permalink)
Member: 2189114
Thanks Meter: 60
Originally Posted by Shohel_sst View Post
After successfull repair same problem and when i flash full file in odin mode set goes again dead.
bro need 2017 firmware
G532G_DXU1AQA4_OLB1AQA3
G532F_XXU1AQA3_OXE1AQA3
download z3x shell
Old 10-27-2017, 09:55   #109 (permalink)
Member: 1471030
Thanks Meter: 22
G532G_DXU1AQA4_OLB1AQB1
use this file 100%
Old 10-29-2017, 08:50   #110 (permalink)
wasangaama's Avatar
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 75
i do this operation few times.. it works perfectly
today received g532g unit dead by another shop
it gives this error after load .pit file
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 2041 mV
CMD Active Level: 2289 mV
Can't init device. Reason: CARD Data FIFO Timeout Error
Old 11-13-2017, 12:33   #111 (permalink)
Member: 2090936
Thanks Meter: 26
i have same unit
jtag and flashing done, the phone is alive now but no signal
IMEI on system dos't match to IMEI in phone's sticker
Old 11-15-2017, 20:41   #112 (permalink)
ganjbek's Avatar
Member: 1246378
Thanks Meter: 104
After the restoration, will the cert be different?
network will the call be?
how to get your imei back?
Old 11-18-2017, 14:58   #113 (permalink)
shoaibansari.'s Avatar
Member: 1284209
Sonork: 100.1614938
Thanks Meter: 131
another dead recoverd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 188.17 Kb/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 551.19 Kb/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 23.95 Kb/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 612.42 Kb/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 559.17 Kb/s
All done
Old 11-18-2017, 16:18   #114 (permalink)
Member: 112185
Sonork: 100.1612613
Thanks Meter: 90
many liers in this forum
Old 11-25-2017, 15:41   #115 (permalink)
Member: 2776492
Thanks Meter: 34
Originally Posted by learnersoul View Post
after write this rom emmc back to live but shows emergency calls only and after write efs problem not solved
please help me solve the problem
search network manually and sellect network,,will be ok,,
if still write certs,,,
Old 11-25-2017, 15:58   #116 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 60
to all as of now no solution patch cert on this model.
thats why after you write dump no signal or emergency call only because the imei not match,
Old 12-25-2017, 09:41   #117 (permalink)
Member: 2498409
Thanks Meter: 87
Originally Posted by FullFlash™ View Post
the share your files
can i write these files with medusa pro and how can i write
Old 12-25-2017, 10:19   #118 (permalink)
Member: 2498409
Thanks Meter: 87
g532g working efs file need
Old 01-18-2018, 04:53   #119 (permalink)
Member: 2785109
sorry pass by masum mt can't .
please.
Old 02-06-2018, 18:24   #120 (permalink)
bendou's Avatar
Member: 165971
Thanks Meter: 58
maybe dead or something wrong ?
Page generated in 0.38558 seconds with 8 queries
