Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 04-12-2019, 13:45   #1 (permalink)
Member: 678375
Sonork: 100.1645205
Thanks Meter: 40
Samsung G610f Dead boot Repair
hey friends help me out for this problem
have one samsung G610f its stuck at kies upgrade mode
while flashing its dead and error on system writing
so tried dead boot with easy jtag but there is some detail want
here is log
EMMC CID : 150100414A4E42335203386BF065A36C
EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 10/2016 Rev.0x3
EMMC NAME: AJNB3R , S/N: 946597989
EMMC NAME (HEX): 414A4E42335200
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: AJNB3R_ 946597989_20190412_1803.extcsd
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB
Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 30777310
Partition info successfully found
P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB
P1 (BOTA1) [0x800000 0x400000] Size: 4.0MB
P2 (EFS) [0xc00000 0x1400000] Size: 20.0MB
P3 (CPEFS) [0x2000000 0x800000] Size: 8.0MB
P4 (M9KEFS1) [0x2800000 0x400000] Size: 4.0MB
P5 (M9KEFS2) [0x2c00000 0x400000] Size: 4.0MB
P6 (M9KEFS3) [0x3000000 0x400000] Size: 4.0MB
P7 (CARRIER) [0x3400000 0x100000] Size: 1.0MB
P8 (PARAM) [0x3500000 0x800000] Size: 8.0MB
P9 (BOOT) [0x3d00000 0x2000000] Size: 32.0MB
P10 (RECOVERY) [0x5d00000 0x2600000] Size: 38.0MB
P11 (OTA) [0x8300000 0x800000] Size: 8.0MB
P12 (CDMA-RADIO) [0x8b00000 0x400000] Size: 4.0MB
P13 (RADIO) [0x8f00000 0x5800000] Size: 88.0MB
P14 (TOMBSTONES) [0xe700000 0x100000] Size: 1.0MB
P15 (DNT) [0xe800000 0x100000] Size: 1.0MB
P16 (PERSISTENT) [0xe900000 0x80000] Size: 512.0KB
P17 (PERSDATA) [0xe980000 0xc00000] Size: 12.0MB
P18 (STEADY) [0xf580000 0x100000] Size: 1.0MB
P19 (RESERVED2) [0xf680000 0x180000] Size: 1.500MB
P20 (SYSTEM) [0xf800000 0xbb800000] Size: 2.929GB
P21 (CACHE) [0xcb000000 0xc800000] Size: 200.0MB
P22 (HIDDEN) [0xd7800000 0x3c00000] Size: 60.0MB
P23 (CP_DEBUG) [0xdb400000 0x500000] Size: 5.0MB
P24 (USERDATA) [0xdb900000 0x2cfafbe00] Size: 11.244GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000F800000 (2.929GB)
Unable to mount SYSTEM , code : 95
Done.
give me suggestion
Old 04-12-2019, 13:49   #2 (permalink)
Member: 678375
Sonork: 100.1645205
Thanks Meter: 40
there is no firmware info
Old 04-13-2019, 13:22   #3 (permalink)
Member: 13148
Thanks Meter: 881
firmware info are reding from "system" partition.
if you "system" partition is damaged, the info is not be readed
Old 04-13-2019, 13:33   #4 (permalink)
Member: 678375
Sonork: 100.1645205
Thanks Meter: 40
Sir so what is the solution for this, tried to write bl from 8.0 but, phone is not going on download mode..
Old 04-13-2019, 13:47   #5 (permalink)
Member: 13148
Thanks Meter: 881
We need create patch at new version. Some new Samsung phones are rejects new GPT.
To solve this problem you need write first 128KB of ROM1 (select dump, select Preset size and Write it) from worked dump from this model, after Write by vendor latest BL
Old 04-13-2019, 14:20   #6 (permalink)
Member: 678375
Sonork: 100.1645205
Thanks Meter: 40
But sir samsung latest build 8.1 and its format .lz4 therefore easyjtag not support that file version,
Old 04-13-2019, 16:52   #7 (permalink)
Member: 13148
Thanks Meter: 881
you need use latest version
Old 04-14-2019, 06:01   #8 (permalink)
Member: 678375
Sonork: 100.1645205
Thanks Meter: 40
Sir i have same device that has 7.0, how i read working dump from that. Its possible to backup working dump
Old 04-14-2019, 11:07   #9 (permalink)
Member: 13148
Thanks Meter: 881
how ara is read data from one flash ic and write to another?
how are is copy files from one folder to another? it's so hard work.....
select range, read it, write it....
but you need backup original efs partition (and may be modemst1/st2, fsg) and restore is to save IMEI
Old 04-15-2019, 06:27   #10 (permalink)
Member: 678375
Sonork: 100.1645205
Thanks Meter: 40
Sir what size rom 1 i read from another phone.
Old 04-15-2019, 08:55   #11 (permalink)
Member: 13148
Thanks Meter: 881
See size of boots partitions. ~100-300MB
Page generated in 0.14607 seconds with 7 queries
