11-10-2017, 00:49 | #1 (permalink) |
Insane Poster Join Date: Sep 2003 Location: BUENOS AIRES--ARGENTINA
Member: 39836 Status: Offline Thanks Meter: 2 | Sm.j320m help I have problem whith gpt demanged.... Watt is solution for this¿¿ Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0FFFB013496F58A3, ,FW Ver.: 01.60 CMD Pullup Level:1804 mV CMD Active Level:2547 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 150100514E3136424200A60B684414C4 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2017 Rev.0x0 EMMC NAME: QN16BB , S/N: 2785765444 EMMC NAME (HEX): 514E3136424200 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QN16BB_2785765444_20171109_2008.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. You will need to delete this partition or resize it in another utility. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: 507FDD sectors 2.5 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 5275647 Found Data areas (firmware parts) count is: 29 Partition info successfully found --------------------------------------------- P2 (SBOOT) [0x400000 0x200000] Size: 2.0MB P3 (SBOOT2) [0x600000 0x200000] Size: 2.0MB P4 (L_FIXNV1) [0x800000 0x100000] Size: 1.0MB P5 (L_FIXNV2) [0x900000 0x100000] Size: 1.0MB P6 (PM_SYS) [0xa00000 0x100000] Size: 1.0MB P7 (RSVDFIXNV1) [0xb00000 0x100000] Size: 1.0MB P8 (L_LDSP) [0xc00000 0x400000] Size: 4.0MB P9 (L_MODEM) [0x1000000 0x1000000] Size: 16.0MB P10 (L_GDSP) [0x2000000 0x400000] Size: 4.0MB P11 (L_WARM) [0x2400000 0x400000] Size: 4.0MB P12 (FOTA_SIG) [0x2800000 0x100000] Size: 1.0MB P13 (L_RUNTIMENV1) [0x2900000 0x100000] Size: 1.0MB P14 (L_RUNTIMENV2) [0x2a00000 0x100000] Size: 1.0MB P15 (TD_RUNTIMENV1) [0x2b00000 0x100000] Size: 1.0MB P16 (TD_RUNTIMENV2) [0x2c00000 0x100000] Size: 1.0MB P17 (PARAM) [0x2d00000 0x200000] Size: 2.0MB P18 (EFS) [0x2f00000 0x1400000] Size: 20.0MB P19 (PRODNV) [0x4300000 0x500000] Size: 5.0MB P20 (RESERVED2) [0x4800000 0x600000] Size: 6.0MB P21 (KERNEL) [0x4e00000 0x1400000] Size: 20.0MB P22 (RECOVERY) [0x6200000 0x1400000] Size: 20.0MB P23 (PERSISTENT) [0x7600000 0x100000] Size: 1.0MB P24 (PERSDATA) [0x7700000 0x900000] Size: 9.0MB |
