Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 08-10-2018, 09:18   #1 (permalink)
raisalina's Avatar
Member: 1911970
Sonork: 9741081772
Thanks Meter: 1,458
Thumbs up Samsung Galaxy J7 Pro J730F Boot Repair Success
Setting frequence to 21 Mhz
CMD Pullup Level: 350 mV
CMD Active Level: 2258 mV
EMMC Device Information :
EMMC CID: 150100434B544D345200E1C0EA795570
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: CKTM4R , HEX: 434B544D3452 , S/N: E1C0EA79 , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2018
EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x01 , width 4bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: CKTM4R_E1C0EA79_20180810_115209.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB)
Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB)
Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB)
Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB)
Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB)
Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB)
Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB)
Partition: CARRIER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB)
Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB)
Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB)
Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB)
Partition: OTA, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB)
Partition: RADIO, [000008B00000 - 00000E300000], size: 000005800000 (88.0 MB)
Partition: TOMBSTONES, [00000E300000 - 00000E400000], size: 000000100000 (1.00 MB)
Partition: PERSISTENT, [00000E400000 - 00000E480000], size: 000000080000 (512. KB)
Partition: STEADY, [00000E480000 - 00000E880000], size: 000000400000 (4.00 MB)
Partition: RESERVED2, [00000E880000 - 00000F000000], size: 000000780000 (7.50 MB)
Partition: SYSTEM, [00000F000000 - 0000CF000000], size: 0000C0000000 (3.00 GB)
Partition: CACHE, [0000CF000000 - 0000DB800000], size: 00000C800000 (200. MB)
Partition: HIDDEN, [0000DB800000 - 0000E1C00000], size: 000006400000 (100. MB)
Partition: CP_DEBUG, [0000E1C00000 - 0000E2100000], size: 000000500000 (5.00 MB)
Partition: NAD_FW, [0000E2100000 - 0000E3500000], size: 000001400000 (20.0 MB)
Partition: NAD_REFER, [0000E3500000 - 0000E3600000], size: 000000100000 (1.00 MB)
Partition: USERDATA, [0000E3600000 - 000E8F200000], size: 000DABC00000 (54.6 GB)
GPT header successfully parsed
Get firmware version
Brand = samsung
Manufacturer = samsung
Model = SM-J730F
Phone platform = exynos5
CPU Abi = armeabi-v7a
Android release = 7.0
Firmware version = NRD90M.J730FXWU2ARE2
Firmware date = Tue May 8 22:29:36 KST 2018
Backup saved: CKTM4R_E1C0EA79_20180810_115229.extcsd
Opening file: J7Y17LTE_EUR_OPEN.pit
Pit: J7Y17LTE_EUR_OPEN.pit
Entry count: 29
The size of the last section has been updated
BL_J730FXWU2ARE2_CL12784722_QB18059576_REV00_user_ low_ship.tar.md5
The list of files in the firmware:
sboot.bin
param.bin
cm.bin
Backup saved: CKTM4R_E1C0EA79_20180810_115244.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 000E8F7FBE00
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: cm.bin
Unpacking file: sboot.bin
Unpacking file: param.bin
Partition name: CM
Filename: cm.bin , Offset: 000000000000 , filesize: 2445584 bytes
eMMC switching to ROM3
Erasing partition...
Writing partition...
Done writing partition. Write speed: 259.52 KB/s
Partition name: BOOTLOADER
Filename: sboot.bin , Offset: 000000000000 , filesize: 1728784 bytes
eMMC switching to ROM2
Done writing partition. Write speed: 258.38 KB/s
Partition name: PARAM
Filename: param.bin , Offset: 000003500000 , filesize: 1566720 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 674.88 KB/s
Partition USERDATA : formatting as EXT4. Please wait ...
Formatting completed
Check BootConfig for the selected vendor
All done time: [00:01:31:920]
YOUTUBE
https://www.youtube.com/watch?v=CR4_En4A1FY
The Following 4 Users Say Thank You to raisalina For This Useful Post:
Old 12-19-2018, 14:39   #2 (permalink)
Mobile_Control's Avatar
Member: 998119
Thanks Meter: 49
please emmc isp!!!
Old 12-19-2018, 15:28   #3 (permalink)
Member: 13148
Thanks Meter: 684
Originally Posted by Mobile_Control View Post
please emmc isp!!!
pinout for J730FM is present at z3x support. try it to use
Old 12-19-2018, 19:17   #4 (permalink)
Member: 48933
Thanks Meter: 97
And 100% OK, today i sucssesfuly connected j730f
Page generated in 0.22721 seconds with 7 queries
