05-04-2018, 05:48 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | samsung gt-i9060 dead boot repair Code: Compression is ON Z3X EasyJtag Software ver. 2.9.0.3 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: xxxxxxxxxx, ,FW Ver.: 01.62 Warning: CMD Pullup Level (340 mV) too low , check cables etc.! CMD Active Level:2268 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.3 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: xxxxxxxxx, ,FW Ver.: 01.62 Warning: CMD Pullup Level (340 mV) too low , check cables etc.! CMD Active Level:2227 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.3 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: xxxxxxx, ,FW Ver.: 01.62 CMD Pullup Level:598 mV CMD Active Level:2289 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.3 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: xxxxxxxx, ,FW Ver.: 01.62 CMD Pullup Level:1980 mV CMD Active Level:2289 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. |
