03-20-2018, 07:26
#1 (permalink)
Member: 2650126
Thanks Meter: 42 | Samsung GT-N5100 Deadboot done by change EMMC Today i have jobs samsung GT-N5100 deadboot and i try to direct but cant connect emmc i think the emmc wasdead and im change emmc with kmvtu heres is logs Quote:
Setting interface to EasyJtag2/E-Socket
Setting bus width to 8 Bit
Setting frequence to 42 Mhz
EMMC Device Information :
EMMC CID: 15010056545530304DFC3D39868641FB
EMMC CSD: D02701320F5903FFF6DBFFFF8E40406D
EMMC Manufacture Name: SAMSUNG , EMMC NAME: VTU00M , EMMC NAME (HEX): 56545530304D , S/N: 3D398686 , rev. 0xFC
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2014
EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x01 , width 4bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: VTU00M_3D398686_20180320_122959.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000
Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000
Partition: EFS, [000000C00000 - 000002000000], size: 000001400000
Partition: PARAM, [000002000000 - 000002800000], size: 000000800000
Partition: BOOT, [000002800000 - 000003000000], size: 000000800000
Partition: RECOVERY, [000003000000 - 000003800000], size: 000000800000
Partition: RADIO, [000003800000 - 000005800000], size: 000002000000
Partition: CACHE, [000005800000 - 000065800000], size: 000060000000
Partition: SYSTEM, [000065800000 - 000105800000], size: 0000A0000000
Partition: HIDDEN, [000105800000 - 000128800000], size: 000023000000
Partition: OTA, [000128800000 - 000129000000], size: 000000800000
Partition: USERDATA, [000129000000 - 0003AB000000], size: 000282000000
GPT header successfully parsed
| AND FLASH WITH Z3X Quote:
File analysis... OK
Total file size: 0x9006A20C (2304 Mb)
Searching USB Flash interface... COM188 detected
Setup connection... OK
Set PIT file... OK
Reading PIT from phone... OK
Sending sboot.bin... OK
Sending param.bin... OK
Sending tz.img... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img... OK
Sending modem.bin... OK
Sending cache.img... OK
Sending hidden.img... OK
Flashing done (time - 00:08:04)
Done with Samsung Tool PRO v.31.0
