05-02-2018, 13:50 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Samsung i8552 boot repair done CMD Pullup Level: 1949 mV CMD Active Level: 2310 mV EMMC Device Information : EMMC CID: 1501004B375530304D0A952DCEFF11A6 EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: SAMSUNG , EMMC NAME: K7U00M , EMMC NAME (HEX): 4B375530304D , S/N: 952DCEFF , rev. 0x0A EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 1/2014 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: K7U00M_952DCEFF_20180502_165631.extcsd EMMC Init completed. Scanning soft partitions MBR header is found. Analyzing data ... Partition: mmcblk0p0 [000000000200 - 000000005200], size: 000000005000 Partition: mmcblk0p1 [000000005200 - 000000030E00], size: 00000002BC00 Partition: mmcblk0p2 [000000030E00 - 000001430E00], size: 000001400000 EBR detected at address: 000001430E00 Partition: mmcblk0p3 [000001800000 - 0000018FA000], size: 0000000FA000 Partition: mmcblk0p4 [0000018FA000 - 0000019F4000], size: 0000000FA000 Partition: mmcblk0p5 [0000019F4000 - 000001BE8000], size: 0000001F4000 Partition: mmcblk0p6 [000001BE8000 - 0000027E8000], size: 000000C00000 Partition: mmcblk0p7 [0000027E8000 - 000002AE8000], size: 000000300000 Partition: mmcblk0p8 [000002AE8000 - 000002DE8000], size: 000000300000 Partition: mmcblk0p9 [000002DE8000 - 0000031E8000], size: 000000400000 Partition: mmcblk0p10 [0000031E8000 - 0000039E8000], size: 000000800000 Partition: mmcblk0p11 [0000039E8000 - 0000045E8000], size: 000000C00000 Partition: mmcblk0p12 [0000045E8000 - 0000049E8000], size: 000000400000 Partition: mmcblk0p13 [0000049E8000 - 000004DE8000], size: 000000400000 Partition: mmcblk0p14 [000004DE8000 - 0000059E8000], size: 000000C00000 Partition: mmcblk0p15 [0000059E8000 - 0000071E8000], size: 000001800000 Partition: mmcblk0p16 [0000071E8000 - 0000075E8000], size: 000000400000 Partition: mmcblk0p17 [0000075E8000 - 000007668000], size: 000000080000 Partition: mmcblk0p18 [000007668000 - 000007868000], size: 000000200000 Partition: mmcblk0p19 [000007868000 - 000052868000], size: 00004B000000 Partition: mmcblk0p20 [000052868000 - 00007F868000], size: 00002D000000 Partition: mmcblk0p21 [00007F868000 - 000085C68000], size: 000006400000 Partition: mmcblk0p22 [000085C68000 - 0001D2034E00], size: 00014C3CCE00 MBR header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = GT-I8552 Phone platform = msm7627a CPU Abi = armeabi-v7a Android release = 4.1.2 Firmware version = JZO54K.I8552XXANJ1 Firmware date = Wed Oct 29 19:06:33 KST 2014 Setting frequence to 21 Mhz CMD Pullup Level: 1980 mV CMD Active Level: 2320 mV EMMC Device Information : EMMC CID: 1501004B375530304D0A952DCEFF11A6 EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: SAMSUNG , EMMC NAME: K7U00M , EMMC NAME (HEX): 4B375530304D , S/N: 952DCEFF , rev. 0x0A EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 1/2014 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: K7U00M_952DCEFF_20180502_165708.extcsd EMMC Init completed. Operation: Universal Factory Format Please, wait ... Successfully Setting frequence to 21 Mhz CMD Pullup Level: 1980 mV CMD Active Level: 2310 mV EMMC Device Information : EMMC CID: 1501004B375530304D0A952DCEFF11A6 EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: SAMSUNG , EMMC NAME: K7U00M , EMMC NAME (HEX): 4B375530304D , S/N: 952DCEFF , rev. 0x0A EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 1/2014 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: K7U00M_952DCEFF_20180502_165714.extcsd EMMC Init completed. Setting frequence to 21 Mhz CMD Pullup Level: 1938 mV CMD Active Level: 2310 mV EMMC Device Information : EMMC CID: 1501004B375530304D0A952DCEFF11A6 EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: SAMSUNG , EMMC NAME: K7U00M , EMMC NAME (HEX): 4B375530304D , S/N: 952DCEFF , rev. 0x0A EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 1/2014 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: K7U00M_952DCEFF_20180502_165740.extcsd EMMC Init completed. Opening file: K7U00M_rawprogram0.xml Error: eMMC has a small size The size of the last section has been updated Setting frequence to 21 Mhz CMD Pullup Level: 1938 mV CMD Active Level: 2320 mV EMMC Device Information : EMMC CID: 1501004B375530304D0A952DCEFF11A6 EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: SAMSUNG , EMMC NAME: K7U00M , EMMC NAME (HEX): 4B375530304D , S/N: 952DCEFF , rev. 0x0A EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 1/2014 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: K7U00M_952DCEFF_20180502_165746.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon) Partition name: MBR Filename: mbr0.bin , Offset: 000000000000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 39.76 KB/s Partition name: mmcblk0p0 Filename: mmcblk0p0.bin , Offset: 000000000200 , filesize: 20480 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 277.69 KB/s Partition name: mmcblk0p1 Filename: mmcblk0p1.bin , Offset: 000000005200 , filesize: 179200 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 325.61 KB/s Partition name: mmcblk0p2 Filename: mmcblk0p2.bin , Offset: 000000030E00 , filesize: 20971520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 445.79 KB/s Partition name: EXT Filename: ebr0.bin , Offset: 000001430E00 , filesize: 10240 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 216.18 KB/s Partition name: mmcblk0p3 Filename: mmcblk0p3.bin , Offset: 000001800000 , filesize: 1024000 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 508.91 KB/s Partition name: mmcblk0p4 Filename: mmcblk0p4.bin , Offset: 0000018FA000 , filesize: 1024000 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 509.03 KB/s Partition name: mmcblk0p5 Filename: mmcblk0p5.bin , Offset: 0000019F4000 , filesize: 2048000 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 510.76 KB/s Partition name: mmcblk0p6 Filename: mmcblk0p6.bin , Offset: 000001BE8000 , filesize: 12582912 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 484.12 KB/s Partition name: mmcblk0p7 Filename: mmcblk0p7.bin , Offset: 0000027E8000 , filesize: 3145728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 512.88 KB/s Partition name: mmcblk0p8 Filename: mmcblk0p8.bin , Offset: 000002AE8000 , filesize: 3145728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 448.55 KB/s Partition name: mmcblk0p9 Filename: mmcblk0p9.bin , Offset: 000002DE8000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 512.83 KB/s Partition name: mmcblk0p10 Filename: mmcblk0p10.bin , Offset: 0000031E8000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 512.32 KB/s Partition name: mmcblk0p11 Filename: mmcblk0p11.bin , Offset: 0000039E8000 , filesize: 12582912 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 512.48 KB/s Partition name: mmcblk0p12 Filename: mmcblk0p12.bin , Offset: 0000045E8000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 511.85 KB/s Partition name: mmcblk0p13 Filename: mmcblk0p13.bin , Offset: 0000049E8000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 513.62 KB/s Partition name: mmcblk0p14 Filename: mmcblk0p14.bin , Offset: 000004DE8000 , filesize: 12582912 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 512.81 KB/s Partition name: mmcblk0p15 Filename: mmcblk0p15.bin , Offset: 0000059E8000 , filesize: 25165824 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 511.48 KB/s Partition name: mmcblk0p16 Filename: mmcblk0p16.bin , Offset: 0000071E8000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 511.77 KB/s Partition name: mmcblk0p17 Filename: mmcblk0p17.bin , Offset: 0000075E8000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 504.84 KB/s Partition name: mmcblk0p18 Filename: mmcblk0p18.bin , Offset: 000007668000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 510.79 KB/s Check BOOT_PARTITION_EN for the selected vendor All done time: [00:04:18:761] Setting frequence to 21 Mhz CMD Pullup Level: 1959 mV CMD Active Level: 2310 mV EMMC Device Information : EMMC CID: 1501004B375530304D0A952DCEFF11A6 EMMC CSD: D02701320F5903FFF6DBFFE18E404028 EMMC Manufacture Name: SAMSUNG , EMMC NAME: K7U00M , EMMC NAME (HEX): 4B375530304D , S/N: 952DCEFF , rev. 0x0A EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 1/2014 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: K7U00M_952DCEFF_20180502_170221.extcsd EMMC Init completed. Scanning soft partitions MBR header is found. Analyzing data ... Partition: mmcblk0p0 [000000000200 - 000000005200], size: 000000005000 Partition: mmcblk0p1 [000000005200 - 000000030E00], size: 00000002BC00 Partition: mmcblk0p2 [000000030E00 - 000001430E00], size: 000001400000 EBR detected at address: 000001430E00 Partition: mmcblk0p3 [000001800000 - 0000018FA000], size: 0000000FA000 Partition: mmcblk0p4 [0000018FA000 - 0000019F4000], size: 0000000FA000 Partition: mmcblk0p5 [0000019F4000 - 000001BE8000], size: 0000001F4000 Partition: mmcblk0p6 [000001BE8000 - 0000027E8000], size: 000000C00000 Partition: mmcblk0p7 [0000027E8000 - 000002AE8000], size: 000000300000 Partition: mmcblk0p8 [000002AE8000 - 000002DE8000], size: 000000300000 Partition: mmcblk0p9 [000002DE8000 - 0000031E8000], size: 000000400000 Partition: mmcblk0p10 [0000031E8000 - 0000039E8000], size: 000000800000 Partition: mmcblk0p11 [0000039E8000 - 0000045E8000], size: 000000C00000 Partition: mmcblk0p12 [0000045E8000 - 0000049E8000], size: 000000400000 Partition: mmcblk0p13 [0000049E8000 - 000004DE8000], size: 000000400000 Partition: mmcblk0p14 [000004DE8000 - 0000059E8000], size: 000000C00000 Partition: mmcblk0p15 [0000059E8000 - 0000071E8000], size: 000001800000 Partition: mmcblk0p16 [0000071E8000 - 0000075E8000], size: 000000400000 Partition: mmcblk0p17 [0000075E8000 - 000007668000], size: 000000080000 Partition: mmcblk0p18 [000007668000 - 000007868000], size: 000000200000 Partition: mmcblk0p19 [000007868000 - 000052868000], size: 00004B000000 Partition: mmcblk0p20 [000052868000 - 00007F868000], size: 00002D000000 Partition: mmcblk0p21 [00007F868000 - 000085C68000], size: 000006400000 Partition: mmcblk0p22 [000085C68000 - 0001D1FFFE00], size: 00014C397E00 MBR header successfully parsed Get firmware version Firmware info not found |
The Following 4 Users Say Thank You to royalnasim For This Useful Post: |
