Old 11-18-2016, 16:51   #1 (permalink)
Mony.Never.Die's Avatar
Member: 70045
Sonork: 100.80221
Thanks Meter: 30
Thumbs up Samsung I9300 Null Null after EMMC reblaced, not Baseband IC
Dear All,
I faced this problem many many times, i got S3 I9300 with dead boot after i change emmc phone working but imei null null, i changed emmc again with another one phone work fine imei is ok, so it is not baseband problem at least in my case it is emmc problem, i connect the first emmc direct to jtag and i can browse the files and write the dump 100% ok the i used it with the same phone again imei null null
how to fix the emmc problem
Regards
Old 11-18-2016, 17:01   #2 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 133
Remove emmc and reball and place again..
Old 11-18-2016, 17:04   #3 (permalink)
Member: 70045
Sonork: 100.80221
Thanks Meter: 30
Done professionally and same problem not only one emmc i have like 10 of them same issue
Old 11-18-2016, 17:07   #4 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 133
Did you update emmc firmware?
After update firmware dont write extcd file just update boot config.
Old 11-18-2016, 17:09   #5 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 133
If phone cp hardware is ok then its emmc partitions problem.
Old 11-18-2016, 20:16   #6 (permalink)
Member: 70045
Sonork: 100.80221
Thanks Meter: 30
how to fix that any idea
Old 11-18-2016, 20:18   #7 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 133
Try easyjag plus select pit and flash efs modem direct to emmc.
The Following User Says Thank You to Jani-Jan For This Useful Post:
Old 11-20-2016, 07:22   #8 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 140
It's hardware isuue.first chek emmc ic is good? Second may be over heat basband ic when change emmc..
Old 11-20-2016, 13:10   #9 (permalink)
Member: 70045
Sonork: 100.80221
Thanks Meter: 30
how to flash efs modem to emmc direct
Old 11-20-2016, 13:11   #10 (permalink)
Member: 70045
Sonork: 100.80221
Thanks Meter: 30
emmc is good phone working and cp baseband good no overheat if i change emmc i get imei ok
Old 11-20-2016, 15:41   #11 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Its very possible that you overheat baseband IC. Reball it .
Old 11-21-2016, 14:57   #12 (permalink)
Member: 70045
Sonork: 100.80221
Thanks Meter: 30
listen to me bro have one mother bored with 2 emmc chips one of them working fine with imei and the other one working fine with no imei so baseband ic is ok i tested it it is something wrong with the emmc and my question is how to fix it since it is accepting dump file on jtag direct emmc
Old 11-22-2016, 13:49   #13 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 67
yup i think baseband ic is over heat i also face this problem every time i change emmc ic for i9300 sometime i got null imei..
the final solution need too grind the emmc for safety
not over heating the baseband ic..
Old 11-22-2016, 14:12   #14 (permalink)
Member: 70045
Sonork: 100.80221
Thanks Meter: 30
Old 11-24-2016, 09:15   #15 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
This is hw problem of eMMC chip in page size512k and no way for repair
original eMMC B503 is expensive so everyone buy used (second hand) emmc then it's normal sometimes some eMMC have a some problem
The Following 3 Users Say Thank You to BABAK NURI For This Useful Post:
Page generated in 0.22095 seconds with 9 queries
