Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 09-01-2015, 08:56   #1 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 935
Samsung i9300 totally dead EMMC repair done without removing EMMC
Hi, friends here i am going to share Samsung i9300 totally dead EMMC [KMVTU000LM-B503] repair info how i have done this without removing EMMC from board. its not easy and also not possible without special devices. its just information if you have any emmc repair device you can get much information from this post. if you have dead phone in hands and have not any professional tool you can visit our service Lab to fix that.
What we need to do this.
1= Z3X Easy Jtag
2= i9300 with dead emmc
3= special needle [shown in picture]
4= Good soldering skills
Let's start get i9300 direct emmc pinouts from support. and remove glue under emmc near TP
Solder pinouts carefully on board and emmc adapter witch come with x3x jtag insert needle and try then connect emmc adapter to easy jtag box. then try to detect emmc when you see emmc detected log in lo window you can remove needle. then start formware upgrade and follow instruction carefully given in easy jtag box log window.
some screenshots.
Complete Log
Success!
Sending eMMC firmware...
Success!
Verifying eMMC firmware...
Success!
Flashing eMMC firmware...
Success!
Repairing eMMC CID...
Success!
eMMC firmware is updated now!
Please reconnect all eMMC lines before next operation!
Please don't forget to repair extCSD from backup!
Please don't forget to configure BOOT sizes!
Done.
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\000000_ 537986854_20150602_1959.extcsd
Running:Repair extCSD...
Z3X EasyJtag Software ver. 2.0.3.0
Skip loading eMMC Addon Firmware
CMD Pullup Level:742 mV
CMD Active Level:2186 mV
Writing...
Done.
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: xxxxxxxxxxxx, ,FW Ver.: 01.52
CMD Active Level:2196 mV
eMMC Device Information
EMMC CID : 15010056545530304DFC3D39868641FA
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 04/2014 Rev.0xFC
EMMC NAME: VTU00M , S/N: 1027180166
EMMC NAME (HEX): 56545530304D00
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: VTU00M_1027180166_20150602_2001.extcsd
Done.
Running:Change BOOT CONFIG...
Writing eMMC Register...
Written: REG : 179 VAL :48
Done.
Running:Change BOOT WIDTH...
Written: REG : 177 VAL :1
Done.
Box S/N: xxxxxxxxxxx, ,FW Ver.: 01.52
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VTU00M_1027180166_20150602_2002.extcsd
Done.
i9300\EMMC_ROM1_00000000_20000000.bin
Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM)
Done. Write Speed: 4800 kB/s
Checking NAND Image : C:\Documents and Settings\ABDUL HAKEEM\Desktop\i9300 ec dead\dump i9300\EMMC_ROM2_00000000_00200000.bin
File successefuly loaded!
Processing file...C:\Documents and Settings\ABDUL HAKEEM\Desktop\i9300 ec dead\dump i9300\EMMC_ROM2_00000000_00200000.bin
CMD Pullup Level:721 mV
CMD Active Level:1134 mV
Input file : C:\Documents and Settings\ABDUL HAKEEM\Desktop\i9300 ec dead\dump i9300\EMMC_ROM2_00000000_00200000.bin
Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 818 kB/s
Output file :C:\Documents and Settings\ABDUL HAKEEM\Desktop\i9300 ec dead\EMMC_ROM1_00000000_02000000.bin
Reading 0x000002000000 bytes from 0x000000000000 ...ROM1 ( USER ROM)
Done. Read Speed: 629 kB/s
Br,
PAK FONES
The Following 3 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 09-01-2015, 09:11   #2 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 935
The Following 6 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 09-01-2015, 15:53   #3 (permalink)
Member: 1383093
Thanks Meter: 50
How to remove emmc ic and how to put repair or new emmc
The Following 3 Users Say Thank You to ahmc For This Useful Post:
Old 09-01-2015, 16:03   #4 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 748
already posted butt thanks for work hard
Repair TOTALLY DEAD i9300/N7100 Without Removing eMMC - WITH PICTURES
The Following 3 Users Say Thank You to chand_gee For This Useful Post:
Old 09-11-2015, 13:49   #5 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 935
Originally Posted by chand_gee View Post
i know sure i have get much information from your post.
Old 09-16-2015, 15:27   #6 (permalink)
Member: 2117988
Sonork: 100.1667932
Thanks Meter: 41
help me on how to connect tp
Originally Posted by >>PakFones<< View Post
pls sir can u help me with how to connect tp.thanks in advance
Old 02-16-2016, 15:16   #7 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 935
will make video in future.......
The Following 2 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 02-16-2016, 22:01   #8 (permalink)
kasra's Avatar
Member: 103435
Thanks Meter: 46
thanx bro
w8ting for the video
The Following User Says Thank You to kasra For This Useful Post:
Old 02-23-2016, 12:14   #9 (permalink)
Member: 907376
very good work thank you
Old 02-23-2016, 13:01   #10 (permalink)
Member: 2159417
that not work explain detail
Old 02-23-2016, 13:02   #11 (permalink)
Member: 1847344
Thanks Meter: 286
all fak becase how to thoch neduls to tp no gape bord or mmce ic
Old 02-23-2016, 13:30   #12 (permalink)
Member: 1197181
Sonork: aiephone
same problem with i9300
Old 02-28-2016, 05:03   #13 (permalink)
shabirahmad22's Avatar
Member: 2293727
Sonork: 100.1660528
Thanks Meter: 393
pake post i9300 not warking example no prove
The Following User Says Thank You to shabirahmad22 For This Useful Post:
Old 02-28-2016, 16:33   #14 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 935
this will work only if you have emmc connection experience before then you will need a tp neadle this needle must be connected with ground wire at detection time. first do experimenta on open emmc when you get hold on it then try on board emmc.
Good Luck dear.
Sent from my SM-N910C using Tapatalk
Old 02-29-2016, 11:51   #15 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,391
@ >>PakFones<< Good work mate
@shamsulhaq @ shabirahmad22 this is not fake this is real
we are doing this since months without removing emmc ic on i9300/n7100
if you need prove bring sets with such issue we will show you how to do this in few mins without removing emmc or any components
Regards
The Following User Says Thank You to c_ahmad79 For This Useful Post:
Page generated in 0.41694 seconds with 8 queries
