09-01-2017, 15:27 | #1 (permalink) |
Insane Poster Join Date: Feb 2006 Location: Italia Age: 53
Member: 237150 Status: Offline Thanks Meter: 2 | Problem Easy-jtag update card Recently i have purchased Z3x Easy Jtag from reseller GsmSolution when trying to update not allowed (from 1.5 to 2.2) Card SN: AAFXXFXX Card Type:New Top Card Card Version:1.5 Reseller:GSM Sources Card Activated:01/09/2017 WHEN TRY TO UPGRADE SHOWS " Fail: max 3 unsuccessful attemp per day. /Too many attempts can damage your card AAFXXFXX) Also be shure that correct card selected. Please advice and help to solve |
The Following User Says Thank You to shine71 For This Useful Post: |
09-01-2017, 23:17 | #2 (permalink) |
Member: 237150 Status: Offline Thanks Meter: 2 | I tried now to update the card but now it says server not found. What's happening? I have another Z3X box enabled for samsung and LG and I've never had any problems. Who helps me? |
09-02-2017, 11:48 | #4 (permalink) |
Member: 237150 Status: Offline Thanks Meter: 2 | But is there a valid support for this box stage ????? over 90 views and no one to give me answers? I thought the Z3X team was one of the most valid but I have but I must think badly |
09-02-2017, 16:38 | #5 (permalink) |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Hi, Please, try to update Easy-Jtag card in the external card reader. In some cases, card can stuck in some types of card readers, included box internal card reader. We are trying to figure out this problem. Best Regards |
09-02-2017, 18:43 | #9 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | I cañt send massage shine71 has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her. This error |
09-03-2017, 17:03 | #15 (permalink) |
Member: 237150 Status: Offline Thanks Meter: 2 | I did the tests and I list the results: I used the card of my z3x active box for lg and samsung in my easy jtag, at this point I ran the easy jtag Connectivyti Diag v1.0 software in the driver folder to this point I read the box and the card with this software getting all the data of both the easy jtag and the card. Checking if JTAG present ... Found EASY Jtag BOX "Easy Jtag Control Port (COM10) Box HWID "USB \ VID_0325 & PID_0032 & REV_0100 & MI_00 Box Driver RegKey: {4d36e978-e325-11ce-bfc1-08002be10318} \ 0001 Box Driver Ver .: Box Driver Date .: Configuring for card and uart box ... Searching card ... [215] ----------------------------- Card status: Card found Card SN: FExx-xxxx Card ver: 2.2 ver: 2.2 Card ver int: 16 *+ Lg activated *+ Sams activated Found command port "Easy Jtag Control Port (COM10) Setting JTAG Mode EASY Jtag BOX SN #: 0200xxxxxxxxxxxx EASY Jtag BOX Firmware ver.:01.58 At this point, I did the same procedure using the easy jtag card I can not upgrade from version 1.5 to 2.2 to get this result: Checking if JTAG present ... Found EASY Jtag BOX "Easy Jtag Control Port (COM10) Box HWID "USB \ VID_0325 & PID_0032 & REV_0100 & MI_00 Box Driver RegKey: {4d36e978-e325-11ce-bfc1-08002be10318} \ 0001 Box Driver Ver .: Box Driver Date .: Configuring for card and uart box ... Searching card ... [1] ----------------------------- Card status: Card not found now I wonder is a problem of my card or what? |
