Old 12-15-2018, 09:25   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
Sm-c900f dead by combination
EasyJtag Suite Classic ver.: 2.9.0.0 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights FAIL
Android Explorer ver:1.0.0.24
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.11.3
QUALCOMM Direct ver:1.0.6306.57125
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.0.0
Z3X Card Serial : AA22-0D87 , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Compression if OFF
Z3X EasyJtag Software ver. 2.9.0.0
Loading eMMC GEN2 Firmware... IO: 3300 mV
Box S/N: B1AA4ABBBCB35E7A, ,FW Ver.: 02.23
CMD Pullup Level:2130 mV
CMD Active Level:3145 mV
Box IO Level:3300 mV
CLK Rate:12000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
EMMC CID : 150100434A4E4234521034BAB41AA423
EMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 10/2017 Rev.0x10
EMMC NAME: CJNB4R , S/N: 884651034
EMMC NAME (HEX): 434A4E42345200
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: CJNB4R_ 884651034_20181215_1354.extcsd
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 122142686
Found Data areas (firmware parts) count is: 42
Partition info successfully found
P0 (SBL1) [0x400000 0x80000] Size: 512.0KB
P1 (SBL1BAK) [0x480000 0x80000] Size: 512.0KB
P2 (DDR) [0x500000 0x8000] Size: 32.0KB
P3 (LIMITS) [0x508000 0x8000] Size: 32.0KB
P4 (ABOOT) [0x510000 0x200000] Size: 2.0MB
P5 (RPM) [0x710000 0x80000] Size: 512.0KB
P6 (TZ) [0x790000 0x200000] Size: 2.0MB
P7 (HYP) [0x990000 0x80000] Size: 512.0KB
P8 (FSG) [0xa10000 0x300000] Size: 3.0MB
P9 (SEC) [0xd10000 0x4000] Size: 16.0KB
P10 (KEYMASTER) [0xd14000 0x80000] Size: 512.0KB
P11 (CMNLIB) [0xd94000 0x40000] Size: 256.0KB
P12 (LKSECAPP) [0xdd4000 0x80000] Size: 512.0KB
P13 (APDP) [0xe54000 0x20000] Size: 128.0KB
P14 (MSADP) [0xe74000 0x20000] Size: 128.0KB
P15 (PAD) [0xe94000 0x96c000] Size: 9.421MB
P16 (MODEMST1) [0x1800000 0x300000] Size: 3.0MB
P17 (MODEMST2) [0x1b00000 0x300000] Size: 3.0MB
P18 (PARAM) [0x1e00000 0xa00000] Size: 10.0MB
P19 (EFS) [0x2800000 0xe00000] Size: 14.0MB
P20 (BOOT) [0x3600000 0x2000000] Size: 32.0MB
P21 (RECOVERY) [0x5600000 0x2000000] Size: 32.0MB
P22 (BOTA) [0x7600000 0x700000] Size: 7.0MB
P23 (FOTA) [0x7d00000 0x500400] Size: 5.0MB
P24 (BACKUP) [0x8200400 0x5fdc00] Size: 5.991MB
P25 (FSC) [0x87fe000 0x300000] Size: 3.0MB
P26 (SSD) [0x8afe000 0x2000] Size: 8.0KB
P27 (PERSIST) [0x8b00000 0x2000000] Size: 32.0MB
P28 (PERSISTENT) [0xab00000 0x100000] Size: 1.0MB
P29 (STEADY) [0xac00000 0x100000] Size: 1.0MB
P30 (KEYSTORE) [0xad00000 0x80000] Size: 512.0KB
P31 (CONFIG) [0xad80000 0x8000] Size: 32.0KB
P32 (MOTA) [0xad88000 0x100000] Size: 1.0MB
P33 (DEVCFG) [0xae88000 0x40000] Size: 256.0KB
P34 (DSP) [0xaec8000 0x1000000] Size: 16.0MB
P35 (MODEM) [0xbec8000 0x6838000] Size: 104.218MB
P36 (APNHLOS) [0x12700000 0x2800000] Size: 40.0MB
P37 (PERSDATA) [0x14f00000 0x900000] Size: 9.0MB
P38 (SYSTEM) [0x15800000 0x11f000000] Size: 4.484GB
P39 (CACHE) [0x134800000 0xc800000] Size: 200.0MB
P40 (HIDDEN) [0x141000000 0x6400000] Size: 100.0MB
P41 (USERDATA) [0x147400000 0xd483fbe00] Size: 53.127GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0015800000 (4.484GB)
Build ID: NMF26X
Display Build ID: NMF26X.C900FDDU1BRD1
Release ID: 7.1.1
Device Model: SM-C900F
Product ID: c9lte
Device Name: c9ltedd
Architecture ABI: arm64-v8a
Device manufacturer: samsung
Device Platform: msm8952
Build Description: c9ltedd-user 7.1.1 NMF26X C900FDDU1BRD1 release-keys
Samsung CPU: MSM8976
Build ID: NMF26X
Release ID: 7.1.1
Product ID: c9lte
Done.
NEED HELP
Old 12-15-2018, 10:31   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
http://forum.gsmhosting.com/vbb/f672...-done-2449470/
The Following User Says Thank You to layder For This Useful Post:
Page generated in 0.12582 seconds with 8 queries
