09-10-2017, 12:17 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: INDIA,TAMILNADU,PATTUKKOTTAI
Member: 304090 Status: Offline Thanks Meter: 210 | samsung j100h boot repair problem..... Frequence: 14 Mhz CMD Pullup Level: 412 mV CMD Active Level: 2423 mV EMMC Device Information : EMMC CID: 65646F4D204D4F521281000002400152 EMMC CSD: D07FFF320F59007FF6DB80001E40001C EMMC Manufacture Name: EMMC Manufacture ID: 0x65 , OEM ID: 646F EMMC Manufacture Date: 0/2014 , Rev: 81 EMMC NAME: M MOR , S/N: 00000240 , rev. 81 EMMC NAME (HEX): 4D204D4F5212 EMMC ROM 1 (Main User Data) Capacity: 128 MB (000008000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x78 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: M MOR_00000240_20170910_164301.extcsd EMMC Init completed. Warning: Maybe your emmc damaged Opening file: J13G.pit Pit: J13G.pit Entry count: 29 Error: eMMC has a small size The size of the last section was not updated any solution? |
09-11-2017, 19:10 | #4 (permalink) |
No Life Poster Join Date: Aug 2015 Location: KATHMANDU,NEPAL
Member: 2438408 Status: Offline Thanks Meter: 380 | Samsung j100h phone successfully dead boot repair done ✅ but phone same case successfully write pit and boot loader |
The Following User Says Thank You to alexid For This Useful Post: |
