Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-11-2019, 12:32   #1 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 785
samsung j100h dead boot repair done very easy and simple
Setting frequence to 21 MHz
CMD Pullup Level: 2103 mV
CMD Active Level: 2402 mV
Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
CMD Pullup Level: 2114 mV
CMD Active Level: 2392 mV
CMD Pullup Level: 2093 mV
EMMC Device Information :
EMMC CID: 90014A48344732621101ACF568A43204
EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA
EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: ACF568A4 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2015
   EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H4G2b_ACF568A4_20100428_004724.extcsd
EMMC Init completed.
Scanning soft partitions
Partition table not found
Error: Previous operation is not finished yet.
CMD Active Level: 2382 mV
Backup saved: H4G2b_ACF568A4_20100428_004804.extcsd
Operation: Writing all eMMC Regions...
Operation: Writing BootConfig ...
Reg: 179  Value: 0x08
Reg: 177  Value: 0x00
Reg: 162  Value: 0x00
Done
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Filename: EMMC_ROM2_H4G2b_2165950698_00000000_00400000.bin
eMMC switching to ROM2
Writing partition...
Done writing partition. Write speed: 333.21 KB/s
Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000
Filename: EMMC_ROM3_H4G2b_2165950698_00000000_00400000.bin
eMMC switching to ROM3
Done writing partition. Write speed: 333.89 KB/s
Writing to: ROM1 , start: 0x000000000000 , size: 0x000010000000
Filename: EMMC_ROM1_H4G2b_2165950698_00000000_10000000.bin
eMMC switching to ROM1
Done writing partition. Write speed: 511.60 KB/s
All done   time: [00:08:59:448]
Backup saved: H4G2b_ACF568A4_20100428_010006.extcsd
GPT header is found and is valid
Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 (2.00 MB)
Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 (2.00 MB)
Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 (1.00 MB)
Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 (1.00 MB)
Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 (1.00 MB)
Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 (1.00 MB)
Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 (4.00 MB)
Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 (8.00 MB)
Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 (8.00 MB)
Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 (4.00 MB)
Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 (1.00 MB)
Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 (1.00 MB)
Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 (1.00 MB)
Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 (1.00 MB)
Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 (1.00 MB)
Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 (2.00 MB)
Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 (20.0 MB)
Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 (5.00 MB)
Partition: RESERVED2, [000004400000 - 000004500000], size: 000000100000 (1.00 MB)
Partition: KERNEL, [000004500000 - 000005500000], size: 000001000000 (16.0 MB)
Partition: RECOVERY, [000005500000 - 000006500000], size: 000001000000 (16.0 MB)
Partition: CSC, [000006500000 - 000012D00000], size: 00000C800000 (200. MB)
Partition: system, [000012D00000 - 000053D00000], size: 000041000000 (1.02 GB)
Partition: HIDDEN, [000053D00000 - 000056500000], size: 000002800000 (40.0 MB)
Partition: userdata, [000056500000 - 0000E8100000], size: 000091C00000 (2.28 GB)
GPT header successfully parsed
Get firmware version
Firmware info not found
Old 07-11-2019, 16:35   #2 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 410
post step by step how to recover
The Following User Says Thank You to sr8787 For This Useful Post:
Old 07-11-2019, 17:42   #3 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 785
**********j100h dead boot repair step by step today this is number 3
eMMC_tool Suite  ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 7 (32 bit) build 7600 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = 0500D01E3BC5A469
Card Serial = AA1373CD
EasyJTAG Box Firmware = 1.63
Changelog:
30.06.2019 (ver 1.6.1.0)
   Fix:   Bugs that have been found through your crash report
CMD Active Level: 2371 mV
EMMC CID: 90014A4834473262110124135A514242
EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 24135A51 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2015
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H4G2b_24135A51_20100428_000337.extcsd
Entry count: 29
Partition: BOOT, [000000000000 - 000000080000], size: 000000080000
Partition: BOOT2, [000000000000 - 000000100000], size: 000000100000
Partition: userdata, [000056500000 - 0000E9000000], size: 000092B00000
Backup saved: H4G2b_24135A51_20100428_000443.extcsd
Operation: Universal Factory Format
Please, wait ...
Successfully
Backup saved: H4G2b_24135A51_20100428_000504.extcsd
Operation: Changing GP sizes (test mode) ...
GP1 size: 0 MB , WR_REL: 1 , ENH 0
GP2 size: 0 MB , WR_REL: 1 , ENH 0
GP3 size: 0 MB , WR_REL: 1 , ENH 0
GP4 size: 0 MB , WR_REL: 1 , ENH 0
Zero sizes. This may damage your eMMC
Do you want to continue?
Successfu
lly
CMD Pullup Level: 2083 mV
Backup saved: H4G2b_24135A51_20100428_000515.extcsd
Successfully
Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to cancel the changes
Backup saved: H4G2b_24135A51_20100428_000732.extcsd
Backup saved: H4G2b_24135A51_20100428_011031.extcsd
Done
Done writing partition. Write speed: 333.26 KB/s
Done writing partition. Write speed: 333.92 KB/s
Done writing partition. Write speed: 523.33 KB/s
All done   time: [21:19:25:693]
after repair boot just flash ap,cp,cse. enjoy
Old 07-11-2019, 18:23   #4 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 18
Done
As per your logs, first you got this error-Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
then what did you do, how did you connect the emmc successfuly after that error? Please tell?
Old 07-12-2019, 02:43   #5 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 785
just connect charger without battery and try again
Old 07-12-2019, 06:11   #6 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 18
Charger or USB cable from PC to phone motherboard? because I also connected usb from PC to motherboard after this error but nothing changed, got the same error every time.
Old 07-12-2019, 06:23   #7 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 785
if problem again just change vcc or vccq and also check usb port connect direct 5.0v charger
The Following User Says Thank You to kothamamun For This Useful Post:
Old 07-12-2019, 07:11   #8 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 18
Okays..thanks... I'll try the above steps if get another mobile with same problem
Page generated in 0.43758 seconds with 7 queries
