07-12-2019, 11:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,776 | warning health report is bad whats problem Code: Setting frequence to 21 MHz CMD Pullup Level: 2000 mV CMD Active Level: 2299 mV EMMC Device Information : EMMC CID: 150100514E3136424200CDE4EEEEB3A4 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: CDE4EEEE , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_CDE4EEEE_20190712_163028.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x0B Exceeded its maximum estimated device life time Pre EOL information [267]: 0x01 Normal Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: NVRAM, [000000800000 - 000001000000], size: 000000800000 (8.00 MB) Partition: LK, [000001000000 - 000001200000], size: 000000200000 (2.00 MB) Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB) Partition: SECRO, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB) Partition: SECCFG, [000001B00000 - 000001B80000], size: 000000080000 (512. KB) Partition: EFUSE, [000001B80000 - 000001C00000], size: 000000080000 (512. KB) Partition: TEE1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB) Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB) Partition: EFS, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) Partition: NVDATA, [000003000000 - 000005000000], size: 000002000000 (32.0 MB) Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 (8.00 MB) Partition: RECOVERY, [000005800000 - 000006800000], size: 000001000000 (16.0 MB) Partition: BOOT, [000006800000 - 000007800000], size: 000001000000 (16.0 MB) Partition: MD1IMG, [000007800000 - 000009800000], size: 000002000000 (32.0 MB) Partition: MD1DSP, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB) Partition: KEYSTORE, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB) Partition: OMEKEYSTORE, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB) Partition: PROINFO, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB) Partition: PARA, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB) Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB) Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) Partition: PROTECT1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB) Partition: PROTECT2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB) Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) Partition: SYSTEM, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB) Partition: CACHE, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB) Partition: HIDDEN, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB) Partition: USERDATA, [0000E9400000 - 0001D1FFBE00], size: 0000E8BFBE00 (3.64 GB) GPT header successfully parsed AP_G532GDXU1ASA5_CL15222057_QB21594701_REV00_user_low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: boot.img recovery.img system.img secro.img userdata.img Setting frequence to 21 MHz CMD Pullup Level: 2010 mV CMD Active Level: 2299 mV EMMC Device Information : EMMC CID: 150100514E3136424200CDE4EEEEB3A4 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: CDE4EEEE , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_CDE4EEEE_20190712_163111.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x0B Exceeded its maximum estimated device life time Pre EOL information [267]: 0x01 Normal |
07-12-2019, 13:30 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
You need replace flash IC Flash IC cell is degradation when writing | |
The Following User Says Thank You to layder For This Useful Post: |
