09-07-2018, 10:37 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Samsung j110h dead boot repair done 06/09/2018 11:00:12 AM> Looking for EasyJTAG box... 06/09/2018 11:00:12 AM> EasyJTAG API ver. 2022 06/09/2018 11:00:12 AM> Setting IO Levels to 1.8V 06/09/2018 11:00:12 AM> Setting frequence to 6 Mhz 06/09/2018 11:00:12 AM> EasyJTAG Box Serial = A37914E4EFE7D34E 06/09/2018 11:00:12 AM> EasyJTAG Box Firmware = 2.30 06/09/2018 11:00:13 AM> Setting interface to EasyJtag2/ISP 06/09/2018 11:00:13 AM> Setting bus width to 1 Bit 06/09/2018 11:00:13 AM> Setting frequence to 6 Mhz 06/09/2018 11:00:13 AM> CMD Pullup Level: 1789 mV 06/09/2018 11:00:13 AM> CMD Active Level: 1881 mV 06/09/2018 11:00:13 AM> eMMC Init returned = 0 06/09/2018 11:00:13 AM> EMMC Device Information : 06/09/2018 11:00:13 AM> EMMC CID: 90014A483447326211014322B5E5634F 06/09/2018 11:00:13 AM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB 06/09/2018 11:00:13 AM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2b , EMMC NAME (HEX): 483447326200 , S/N: 4322B5E5 , rev. 0x01 06/09/2018 11:00:13 AM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2016 06/09/2018 11:00:13 AM> EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) 06/09/2018 11:00:13 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 06/09/2018 11:00:13 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 06/09/2018 11:00:13 AM> EMMC Permanent Write Protection: No 06/09/2018 11:00:13 AM> EMMC Temporary Write Protection: No 06/09/2018 11:00:13 AM> Extended CSD Information : 06/09/2018 11:00:13 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 06/09/2018 11:00:13 AM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 06/09/2018 11:00:13 AM> Boot Bus Config: 0x00 , width 1bit 06/09/2018 11:00:13 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 06/09/2018 11:00:13 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 06/09/2018 11:00:13 AM> Device supports partitioning features 06/09/2018 11:00:13 AM> Device can have enhanced technological features in partitions and user data area 06/09/2018 11:00:13 AM> Device can have extended partitions attribute 06/09/2018 11:00:13 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 06/09/2018 11:00:14 AM> Backup saved: H4G2b_4322B5E5_20180906_110013.extcsd 06/09/2018 11:00:14 AM> EMMC Init completed. 06/09/2018 11:00:14 AM> 06/09/2018 11:00:14 AM> Operation: Universal Factory Format 06/09/2018 11:00:14 AM> Please, wait ... 06/09/2018 11:00:14 AM> 06/09/2018 11:00:14 AM> Successfully 06/09/2018 11:00:20 AM> 06/09/2018 11:00:20 AM> Looking for EasyJTAG box... 06/09/2018 11:00:20 AM> EasyJTAG API ver. 2022 06/09/2018 11:00:20 AM> Setting IO Levels to 1.8V 06/09/2018 11:00:20 AM> Setting frequence to 6 Mhz 06/09/2018 11:00:20 AM> EasyJTAG Box Serial = A37914E4EFE7D34E 06/09/2018 11:00:20 AM> EasyJTAG Box Firmware = 2.30 06/09/2018 11:00:21 AM> Setting interface to EasyJtag2/ISP 06/09/2018 11:00:21 AM> Setting bus width to 1 Bit 06/09/2018 11:00:21 AM> Setting frequence to 6 Mhz 06/09/2018 11:00:21 AM> CMD Pullup Level: 1790 mV 06/09/2018 11:00:21 AM> CMD Active Level: 1881 mV 06/09/2018 11:00:21 AM> eMMC Init returned = 0 06/09/2018 11:00:21 AM> EMMC Device Information : 06/09/2018 11:00:21 AM> EMMC CID: 90014A483447326211014322B5E5634F 06/09/2018 11:00:21 AM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB 06/09/2018 11:00:21 AM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2b , EMMC NAME (HEX): 483447326200 , S/N: 4322B5E5 , rev. 0x01 06/09/2018 11:00:21 AM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2016 06/09/2018 11:00:21 AM> EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) 06/09/2018 11:00:21 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 06/09/2018 11:00:21 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 06/09/2018 11:00:21 AM> EMMC Permanent Write Protection: No 06/09/2018 11:00:21 AM> EMMC Temporary Write Protection: No 06/09/2018 11:00:21 AM> Extended CSD Information : 06/09/2018 11:00:21 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 06/09/2018 11:00:21 AM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 06/09/2018 11:00:21 AM> Boot Bus Config: 0x00 , width 1bit 06/09/2018 11:00:21 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 06/09/2018 11:00:21 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 06/09/2018 11:00:21 AM> Device supports partitioning features 06/09/2018 11:00:21 AM> Device can have enhanced technological features in partitions and user data area 06/09/2018 11:00:21 AM> Device can have extended partitions attribute 06/09/2018 11:00:21 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 06/09/2018 11:00:21 AM> Backup saved: H4G2b_4322B5E5_20180906_110021.extcsd 06/09/2018 11:00:21 AM> EMMC Init completed. 06/09/2018 11:00:21 AM> 06/09/2018 11:00:21 AM> Operation: Changing GP sizes (test mode) ... 06/09/2018 11:00:21 AM> 06/09/2018 11:00:21 AM> GP1 size: 0 MB , WR_REL: 1 , ENH 0 06/09/2018 11:00:21 AM> GP1 size: 0 MB , WR_REL: 1 , ENH 0 06/09/2018 11:00:21 AM> GP1 size: 0 MB , WR_REL: 1 , ENH 0 06/09/2018 11:00:21 AM> GP1 size: 0 MB , WR_REL: 1 , ENH 0 06/09/2018 11:00:21 AM> 06/09/2018 11:00:22 AM> Successfully 06/09/2018 11:00:22 AM> 06/09/2018 11:00:22 AM> Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to cancel the changes 06/09/2018 11:00:22 AM> 06/09/2018 11:00:24 AM> Looking for EasyJTAG box... 06/09/2018 11:00:24 AM> EasyJTAG API ver. 2022 06/09/2018 11:00:24 AM> Setting IO Levels to 1.8V 06/09/2018 11:00:24 AM> Setting frequence to 6 Mhz 06/09/2018 11:00:24 AM> EasyJTAG Box Serial = A37914E4EFE7D34E 06/09/2018 11:00:24 AM> EasyJTAG Box Firmware = 2.30 06/09/2018 11:00:24 AM> Setting interface to EasyJtag2/ISP 06/09/2018 11:00:24 AM> Setting bus width to 1 Bit 06/09/2018 11:00:25 AM> Setting frequence to 6 Mhz 06/09/2018 11:00:25 AM> CMD Pullup Level: 1790 mV 06/09/2018 11:00:25 AM> CMD Active Level: 1882 mV 06/09/2018 11:00:25 AM> eMMC Init returned = 0 06/09/2018 11:00:25 AM> EMMC Device Information : 06/09/2018 11:00:25 AM> EMMC CID: 90014A483447326211014322B5E5634F 06/09/2018 11:00:25 AM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB 06/09/2018 11:00:25 AM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2b , EMMC NAME (HEX): 483447326200 , S/N: 4322B5E5 , rev. 0x01 06/09/2018 11:00:25 AM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2016 06/09/2018 11:00:25 AM> EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) 06/09/2018 11:00:25 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 06/09/2018 11:00:25 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 06/09/2018 11:00:25 AM> EMMC Permanent Write Protection: No 06/09/2018 11:00:25 AM> EMMC Temporary Write Protection: No 06/09/2018 11:00:25 AM> Extended CSD Information : 06/09/2018 11:00:25 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 06/09/2018 11:00:25 AM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 06/09/2018 11:00:25 AM> Boot Bus Config: 0x00 , width 1bit 06/09/2018 11:00:25 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 06/09/2018 11:00:25 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 06/09/2018 11:00:25 AM> Device supports partitioning features 06/09/2018 11:00:25 AM> Device can have enhanced technological features in partitions and user data area 06/09/2018 11:00:25 AM> Device can have extended partitions attribute 06/09/2018 11:00:25 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 06/09/2018 11:00:25 AM> Backup saved: H4G2b_4322B5E5_20180906_110025.extcsd 06/09/2018 11:00:25 AM> EMMC Init completed. 06/09/2018 11:00:25 AM> 06/09/2018 11:00:25 AM> Operation: Changing GP sizes (final write) ... 06/09/2018 11:00:25 AM> 06/09/2018 11:00:25 AM> GP1 size: 0 MB , WR_REL: 1 , ENH 0 06/09/2018 11:00:25 AM> GP1 size: 0 MB , WR_REL: 1 , ENH 0 06/09/2018 11:00:25 AM> GP1 size: 0 MB , WR_REL: 1 , ENH 0 06/09/2018 11:00:25 AM> GP1 size: 0 MB , WR_REL: 1 , ENH 0 06/09/2018 11:00:25 AM> 06/09/2018 11:00:26 AM> Successfully 06/09/2018 11:00:26 AM> 06/09/2018 11:00:26 AM> Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize operation 06/09/2018 11:00:26 AM> 06/09/2018 11:00:26 AM> After reconnect, make sure that the size of ROM1 has been changed. 06/09/2018 11:00:26 AM> 06/09/2018 11:00:29 AM> Looking for EasyJTAG box... 06/09/2018 11:00:29 AM> EasyJTAG API ver. 2022 06/09/2018 11:00:29 AM> Setting IO Levels to 1.8V 06/09/2018 11:00:29 AM> Setting frequence to 6 Mhz 06/09/2018 11:00:29 AM> EasyJTAG Box Serial = A37914E4EFE7D34E 06/09/2018 11:00:29 AM> EasyJTAG Box Firmware = 2.30 06/09/2018 11:00:29 AM> Setting interface to EasyJtag2/ISP 06/09/2018 11:00:29 AM> Setting bus width to 1 Bit 06/09/2018 11:00:30 AM> Setting frequence to 6 Mhz 06/09/2018 11:00:30 AM> CMD Pullup Level: 1789 mV 06/09/2018 11:00:30 AM> CMD Active Level: 1882 mV 06/09/2018 11:00:30 AM> eMMC Init returned = 0 06/09/2018 11:00:30 AM> EMMC Device Information : 06/09/2018 11:00:30 AM> EMMC CID: 90014A483447326211014322B5E5634F 06/09/2018 11:00:30 AM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB 06/09/2018 11:00:30 AM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2b , EMMC NAME (HEX): 483447326200 , S/N: 4322B5E5 , rev. 0x01 06/09/2018 11:00:30 AM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2016 06/09/2018 11:00:30 AM> EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) 06/09/2018 11:00:30 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 06/09/2018 11:00:30 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 06/09/2018 11:00:30 AM> EMMC Permanent Write Protection: No 06/09/2018 11:00:30 AM> EMMC Temporary Write Protection: No 06/09/2018 11:00:30 AM> Extended CSD Information : 06/09/2018 11:00:30 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 06/09/2018 11:00:30 AM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 06/09/2018 11:00:30 AM> Boot Bus Config: 0x00 , width 1bit 06/09/2018 11:00:30 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 06/09/2018 11:00:30 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 06/09/2018 11:00:30 AM> Device supports partitioning features 06/09/2018 11:00:30 AM> Device can have enhanced technological features in partitions and user data area 06/09/2018 11:00:30 AM> Device can have extended partitions attribute 06/09/2018 11:00:30 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 06/09/2018 11:00:30 AM> Backup saved: H4G2b_4322B5E5_20180906_110030.extcsd 06/09/2018 11:00:30 AM> EMMC Init completed. 06/09/2018 11:00:30 AM> 06/09/2018 11:00:30 AM> Scanning soft partitions 06/09/2018 11:00:53 AM> Partition table not found 06/09/2018 11:00:53 AM> 06/09/2018 11:00:57 AM> Looking for EasyJTAG box... 06/09/2018 11:00:57 AM> EasyJTAG API ver. 2022 06/09/2018 11:00:57 AM> Setting IO Levels to 1.8V 06/09/2018 11:00:57 AM> Setting frequence to 6 Mhz 06/09/2018 11:00:57 AM> EasyJTAG Box Serial = A37914E4EFE7D34E 06/09/2018 11:00:57 AM> EasyJTAG Box Firmware = 2.30 06/09/2018 11:00:58 AM> Setting interface to EasyJtag2/ISP 06/09/2018 11:00:58 AM> Setting bus width to 1 Bit 06/09/2018 11:00:58 AM> Setting frequence to 6 Mhz 06/09/2018 11:00:58 AM> CMD Pullup Level: 1789 mV 06/09/2018 11:00:58 AM> CMD Active Level: 1881 mV 06/09/2018 11:00:58 AM> eMMC Init returned = 0 06/09/2018 11:00:58 AM> EMMC Device Information : 06/09/2018 11:00:58 AM> EMMC CID: 90014A483447326211014322B5E5634F 06/09/2018 11:00:58 AM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB 06/09/2018 11:00:58 AM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2b , EMMC NAME (HEX): 483447326200 , S/N: 4322B5E5 , rev. 0x01 06/09/2018 11:00:58 AM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2016 06/09/2018 11:00:58 AM> EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) 06/09/2018 11:00:58 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 06/09/2018 11:00:58 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 06/09/2018 11:00:58 AM> EMMC Permanent Write Protection: No 06/09/2018 11:00:58 AM> EMMC Temporary Write Protection: No 06/09/2018 11:00:58 AM> Extended CSD Information : 06/09/2018 11:00:58 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 06/09/2018 11:00:58 AM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 06/09/2018 11:00:58 AM> Boot Bus Config: 0x00 , width 1bit 06/09/2018 11:00:58 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 06/09/2018 11:00:58 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 06/09/2018 11:00:58 AM> Device supports partitioning features 06/09/2018 11:00:58 AM> Device can have enhanced technological features in partitions and user data area 06/09/2018 11:00:58 AM> Device can have extended partitions attribute 06/09/2018 11:00:58 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 06/09/2018 11:00:58 AM> Backup saved: H4G2b_4322B5E5_20180906_110058.extcsd 06/09/2018 11:00:58 AM> EMMC Init completed. 06/09/2018 11:00:58 AM> 06/09/2018 11:00:58 AM> Opening file: F:\SAMSUNG\J110H\SM-J110H_1_20171120145927_ro226zu6c4_fac\SM-J110H_DS_14-5-2016_20-9-53.pit 06/09/2018 11:00:58 AM> 06/09/2018 11:00:58 AM> Pit: SM-J110H_DS_14-5-2016_20-9-53.pit 06/09/2018 11:00:58 AM> Entry count: 29 06/09/2018 11:00:58 AM> 06/09/2018 11:00:58 AM> The size of the last section has been updated 06/09/2018 11:01:01 AM> Selected file: F:\SAMSUNG\J110H\SM-J110H_1_20171120145927_ro226zu6c4_fac\BL_J110HXXU0 AQJ1_CL1240844_QB15258762_REV02_user_low_ship.tar. md5 06/09/2018 11:01:01 AM> 06/09/2018 11:01:01 AM> BL_J110HXXU0AQJ1_CL1240844_QB15258762_REV02_user_l ow_ship.tar.md5 06/09/2018 11:01:01 AM> The list of files in the firmware: 06/09/2018 11:01:01 AM> spl.img 06/09/2018 11:01:01 AM> sboot.bin 06/09/2018 11:01:01 AM> sboot2.bin 06/09/2018 11:01:01 AM> param.lfs 06/09/2018 11:01:01 AM> 06/09/2018 11:01:03 AM> Looking for EasyJTAG box... 06/09/2018 11:01:03 AM> EasyJTAG API ver. 2022 06/09/2018 11:01:03 AM> Setting IO Levels to 1.8V 06/09/2018 11:01:03 AM> Setting frequence to 6 Mhz 06/09/2018 11:01:03 AM> EasyJTAG Box Serial = A37914E4EFE7D34E 06/09/2018 11:01:03 AM> EasyJTAG Box Firmware = 2.30 06/09/2018 11:01:03 AM> Setting interface to EasyJtag2/ISP 06/09/2018 11:01:03 AM> Setting bus width to 1 Bit 06/09/2018 11:01:04 AM> Setting frequence to 6 Mhz 06/09/2018 11:01:04 AM> CMD Pullup Level: 1789 mV 06/09/2018 11:01:04 AM> CMD Active Level: 1882 mV 06/09/2018 11:01:04 AM> eMMC Init returned = 0 06/09/2018 11:01:04 AM> EMMC Device Information : 06/09/2018 11:01:04 AM> EMMC CID: 90014A483447326211014322B5E5634F 06/09/2018 11:01:04 AM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB 06/09/2018 11:01:04 AM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2b , EMMC NAME (HEX): 483447326200 , S/N: 4322B5E5 , rev. 0x01 06/09/2018 11:01:04 AM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2016 06/09/2018 11:01:04 AM> EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) 06/09/2018 11:01:04 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 06/09/2018 11:01:04 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 06/09/2018 11:01:04 AM> EMMC Permanent Write Protection: No 06/09/2018 11:01:04 AM> EMMC Temporary Write Protection: No 06/09/2018 11:01:04 AM> Extended CSD Information : 06/09/2018 11:01:04 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 06/09/2018 11:01:04 AM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 06/09/2018 11:01:04 AM> Boot Bus Config: 0x00 , width 1bit 06/09/2018 11:01:04 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 06/09/2018 11:01:04 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 06/09/2018 11:01:04 AM> Device supports partitioning features 06/09/2018 11:01:04 AM> Device can have enhanced technological features in partitions and user data area 06/09/2018 11:01:04 AM> Device can have extended partitions attribute 06/09/2018 11:01:04 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 06/09/2018 11:01:04 AM> Backup saved: H4G2b_4322B5E5_20180906_110104.extcsd 06/09/2018 11:01:04 AM> EMMC Init completed. 06/09/2018 11:01:04 AM> 06/09/2018 11:01:04 AM> Operation: Write by vendor (Samsung) 06/09/2018 11:01:04 AM> 06/09/2018 11:01:04 AM> Creating GPT-partitioninig 06/09/2018 11:01:04 AM> Writing PIT at address: 000000004400 06/09/2018 11:01:04 AM> GPT-partitioning done 06/09/2018 11:01:04 AM> 06/09/2018 11:01:04 AM> Unpacking file: spl.img 06/09/2018 11:01:04 AM> Unpacking file: sboot.bin 06/09/2018 11:01:04 AM> Unpacking file: sboot2.bin 06/09/2018 11:01:04 AM> Unpacking file: param.lfs 06/09/2018 11:01:04 AM> 06/09/2018 11:01:04 AM> Partition name: BOOT 06/09/2018 11:01:04 AM> Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes 06/09/2018 11:01:04 AM> eMMC switching to ROM2 06/09/2018 11:01:04 AM> Erasing partition... 06/09/2018 11:01:07 AM> Writing partition... 06/09/2018 11:01:07 AM> Done writing partition. Write speed: 299.64 KB/s 06/09/2018 11:01:07 AM> Partition name: SBOOT 06/09/2018 11:01:07 AM> Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes 06/09/2018 11:01:07 AM> eMMC switching to ROM1 06/09/2018 11:01:07 AM> Erasing partition... 06/09/2018 11:01:08 AM> Writing partition... 06/09/2018 11:01:11 AM> Done writing partition. Write speed: 648.97 KB/s 06/09/2018 11:01:11 AM> Partition name: SBOOT2 06/09/2018 11:01:11 AM> Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes 06/09/2018 11:01:11 AM> eMMC switching to ROM1 06/09/2018 11:01:11 AM> Erasing partition... 06/09/2018 11:01:12 AM> Writing partition... 06/09/2018 11:01:14 AM> Done writing partition. Write speed: 657.69 KB/s 06/09/2018 11:01:14 AM> Partition name: PARAM 06/09/2018 11:01:14 AM> Filename: param.lfs , Offset: 000002900000 , filesize: 634880 bytes 06/09/2018 11:01:14 AM> eMMC switching to ROM1 06/09/2018 11:01:14 AM> Erasing partition... 06/09/2018 11:01:15 AM> Writing partition... 06/09/2018 11:01:16 AM> Done writing partition. Write speed: 652.41 KB/s 06/09/2018 11:01:16 AM> 06/09/2018 11:01:16 AM> Partition HIDDEN : formatting as EXT4. Please wait ... 06/09/2018 11:01:18 AM> Formatting completed 06/09/2018 11:01:18 AM> 06/09/2018 11:01:20 AM> All done time: [00:00:15:577] 06/09/2018 11:01:20 AM> 06/09/2018 11:01:21 AM> Looking for EasyJTAG box... 06/09/2018 11:01:21 AM> EasyJTAG API ver. 2022 06/09/2018 11:01:21 AM> Setting IO Levels to 1.8V 06/09/2018 11:01:21 AM> Setting frequence to 6 Mhz 06/09/2018 11:01:21 AM> EasyJTAG Box Serial = A37914E4EFE7D34E 06/09/2018 11:01:21 AM> EasyJTAG Box Firmware = 2.30 06/09/2018 11:01:22 AM> Setting interface to EasyJtag2/ISP 06/09/2018 11:01:22 AM> Setting bus width to 1 Bit 06/09/2018 11:01:22 AM> Setting frequence to 6 Mhz 06/09/2018 11:01:22 AM> CMD Pullup Level: 1790 mV 06/09/2018 11:01:22 AM> CMD Active Level: 1879 mV 06/09/2018 11:01:22 AM> eMMC Init returned = 0 06/09/2018 11:01:22 AM> EMMC Device Information : 06/09/2018 11:01:22 AM> EMMC CID: 90014A483447326211014322B5E5634F 06/09/2018 11:01:22 AM> EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB 06/09/2018 11:01:22 AM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2b , EMMC NAME (HEX): 483447326200 , S/N: 4322B5E5 , rev. 0x01 06/09/2018 11:01:22 AM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2016 06/09/2018 11:01:22 AM> EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) 06/09/2018 11:01:22 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 06/09/2018 11:01:22 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 06/09/2018 11:01:22 AM> EMMC Permanent Write Protection: No 06/09/2018 11:01:22 AM> EMMC Temporary Write Protection: No 06/09/2018 11:01:22 AM> Extended CSD Information : 06/09/2018 11:01:22 AM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 06/09/2018 11:01:22 AM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 06/09/2018 11:01:22 AM> Boot Bus Config: 0x00 , width 1bit 06/09/2018 11:01:22 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 06/09/2018 11:01:22 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 06/09/2018 11:01:22 AM> Device supports partitioning features 06/09/2018 11:01:22 AM> Device can have enhanced technological features in partitions and user data area 06/09/2018 11:01:22 AM> Device can have extended partitions attribute 06/09/2018 11:01:22 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 06/09/2018 11:01:22 AM> Backup saved: H4G2b_4322B5E5_20180906_110122.extcsd 06/09/2018 11:01:22 AM> EMMC Init completed. 06/09/2018 11:01:22 AM> 06/09/2018 11:01:22 AM> Scanning soft partitions 06/09/2018 11:01:22 AM> GPT header is found and is valid 06/09/2018 11:01:22 AM> Partition: sboot, [000000400000 - 000000600000], size: 000000200000 06/09/2018 11:01:22 AM> Partition: sboot2, [000000600000 - 000000800000], size: 000000200000 06/09/2018 11:01:22 AM> Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 06/09/2018 11:01:22 AM> Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 06/09/2018 11:01:22 AM> Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 06/09/2018 11:01:23 AM> Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 06/09/2018 11:01:23 AM> Partition: wdsp, [000000C00000 - 000001000000], size: 000000400000 06/09/2018 11:01:23 AM> Partition: modem, [000001000000 - 000001800000], size: 000000800000 06/09/2018 11:01:23 AM> Partition: modem2, [000001800000 - 000002000000], size: 000000800000 06/09/2018 11:01:23 AM> Partition: tddsp, [000002000000 - 000002400000], size: 000000400000 06/09/2018 11:01:23 AM> Partition: fota_sig, [000002400000 - 000002500000], size: 000000100000 06/09/2018 11:01:23 AM> Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 06/09/2018 11:01:23 AM> Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 06/09/2018 11:01:23 AM> Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 06/09/2018 11:01:23 AM> Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 06/09/2018 11:01:23 AM> Partition: param, [000002900000 - 000002B00000], size: 000000200000 06/09/2018 11:01:23 AM> Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 06/09/2018 11:01:23 AM> Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 06/09/2018 11:01:23 AM> Partition: reserved2, [000004400000 - 000004500000], size: 000000100000 06/09/2018 11:01:23 AM> Partition: kernel, [000004500000 - 000005500000], size: 000001000000 06/09/2018 11:01:23 AM> Partition: recovery, [000005500000 - 000006500000], size: 000001000000 06/09/2018 11:01:23 AM> Partition: csc, [000006500000 - 000012D00000], size: 00000C800000 06/09/2018 11:01:23 AM> Partition: system, [000012D00000 - 000053D00000], size: 000041000000 06/09/2018 11:01:23 AM> Partition: hidden, [000053D00000 - 000056500000], size: 000002800000 06/09/2018 11:01:23 AM> Partition: userdata, [000056500000 - 0000E8FFBE00], size: 000092AFBE00 06/09/2018 11:01:23 AM> GPT header successfully parsed |
