LOGS
Setting interface to EasyJtag2/E-Socket
Setting bus width to 8 Bit
Setting frequence to 42 Mhz
EMMC Device Information :
EMMC CID: 150100463732324D42003DF86A7343D1
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: F722MB , HEX: 463732324D42 , S/N: 3DF86A73 , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2016
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: F722MB_3DF86A73_20180504_134952.extcsd
EMMC Init completed.
Operation: Write all eMMC Regions at once
Writing BootConfig ...
Reg: 179 Value: 0x48
Reg: 177 Value: 0x01
Reg: 162 Value: 0x00
Done
All done time: [00:00:00:141]
Boot Bus Config: 0x01 , width 4bit
Backup saved: F722MB_3DF86A73_20180504_134958.extcsd
Scanning soft partitions
Partition table not found
Backup saved: F722MB_3DF86A73_20180504_135123.extcsd
Operation: Write Dump
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Input file: C:\Users\SAC\Desktop\J200G\DUMP\EMMC_FN12MB_ROM2_0 00000000000_000000400000.bin
eMMC switching to ROM2
Writing partition...
Done writing partition. Write speed: 2710.95 KB/s
All done time: [00:00:01:685]
Backup saved: F722MB_3DF86A73_20180504_135132.extcsd
Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000
Input file: C:\Users\SAC\Desktop\J200G\DUMP\EMMC_FN12MB_ROM3_0 00000000000_000000400000.bin
eMMC switching to ROM3
Done writing partition. Write speed: 3311.20 KB/s
All done time: [00:00:01:419]
Backup saved: F722MB_3DF86A73_20180504_135153.extcsd
Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000
Input file: C:\Users\SAC\Desktop\SM-J200G(LMY47X.J200GDDU2APL1-5.1.1-LMY47X)[FN12MB_3506D212] By Desbie Cell\userarea.bin
eMMC switching to ROM1
Done writing partition. Write speed: 11285.60 KB/s
All done time: [00:01:33:148]
Backup saved: F722MB_3DF86A73_20180504_135333.extcsd
GPT header is found and is valid
Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB)
Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB)
Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB)
Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB)
Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB)
Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB)
Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB)
Partition: CARRIER, [000003400000 - 000003800000], size: 000000400000 (4.00 MB)
Partition: PARAM, [000003800000 - 000004000000], size: 000000800000 (8.00 MB)
Partition: BOOT, [000004000000 - 000004D00000], size: 000000D00000 (13.0 MB)
Partition: RECOVERY, [000004D00000 - 000005C00000], size: 000000F00000 (15.0 MB)
Partition: OTA, [000005C00000 - 000006400000], size: 000000800000 (8.00 MB)
Partition: CDMA-RADIO, [000006400000 - 000006800000], size: 000000400000 (4.00 MB)
Partition: RADIO, [000006800000 - 000009000000], size: 000002800000 (40.0 MB)
Partition: TOMBSTONES, [000009000000 - 000009400000], size: 000000400000 (4.00 MB)
Partition: TDATA, [000009400000 - 000009800000], size: 000000400000 (4.00 MB)
Partition: PERSISTENT, [000009800000 - 000009900000], size: 000000100000 (1.00 MB)
Partition: PERSDATA, [000009900000 - 00000A500000], size: 000000C00000 (12.0 MB)
Partition: RESERVED2, [00000A500000 - 00000A800000], size: 000000300000 (3.00 MB)
Partition: SYSTEM, [00000A800000 - 00009A800000], size: 000090000000 (2.25 GB)
Partition: CACHE, [00009A800000 - 0000A7000000], size: 00000C800000 (200. MB)
Partition: HIDDEN, [0000A7000000 - 0000A9800000], size: 000002800000 (40.0 MB)
Partition: USERDATA, [0000A9800000 - 0001D1C00000], size: 000128400000 (4.63 GB)
GPT header successfully parsed
RESTORE PART
Opening file: FN12MB_samsung.pit
Pit: FN12MB_samsung.pit
Entry count: 26
The size of the last section has been updated
Backup saved: F722MB_3DF86A73_20180504_135419.extcsd
Operation: Write by vendor (Samsung)
Partition name: EFS
Filename: efs.img , Offset: 000000C00000 , filesize: 20971520 bytes
Done writing partition. Write speed: 10463.26 KB/s
Partition name: CPEFS
Filename: cpefs.img , Offset: 000002000000 , filesize: 8388608 bytes
Done writing partition. Write speed: 9593.49 KB/s
Partition name: M9KEFS1
Filename: m9kefs1.bin , Offset: 000002800000 , filesize: 4194304 bytes
Done writing partition. Write speed: 8816.00 KB/s
Partition name: M9KEFS2
Filename: m9kefs2.bin , Offset: 000002C00000 , filesize: 4194304 bytes
Done writing partition. Write speed: 9113.67 KB/s
Partition name: M9KEFS3
Filename: m9kefs3.bin , Offset: 000003000000 , filesize: 4194304 bytes
Done writing partition. Write speed: 8697.99 KB/s
Partition name: CARRIER
Filename: carrier.img , Offset: 000003400000 , filesize: 4194304 bytes
Done writing partition. Write speed: 8994.24 KB/s
Partition name: PARAM
Filename: param.bin , Offset: 000003800000 , filesize: 8388608 bytes
Done writing partition. Write speed: 9442.72 KB/s
Partition name: CDMA-RADIO
Filename: modem_cdma.bin , Offset: 000006400000 , filesize: 4194304 bytes
Done writing partition. Write speed: 8953.39 KB/s
Partition name: RADIO
Filename: modem.bin , Offset: 000006800000 , filesize: 41943040 bytes
Done writing partition. Write speed: 10914.16 KB/s
Partition name: TOMBSTONES
Filename: tombstones.img , Offset: 000009000000 , filesize: 4194304 bytes
Done writing partition. Write speed: 9265.59 KB/s
Partition name: TDATA
Filename: tdata.img , Offset: 000009400000 , filesize: 4194304 bytes
Done writing partition. Write speed: 8746.97 KB/s
Partition name: PERSISTENT
Filename: PERSISTENT.bin , Offset: 000009800000 , filesize: 1048576 bytes
Done writing partition. Write speed: 5932.78 KB/s
Partition name: PERSDATA
Filename: persdata.img , Offset: 000009900000 , filesize: 12582912 bytes
Done writing partition. Write speed: 9924.54 KB/s
Partition name: RESERVED2
Filename: - , Offset: 00000A500000 , filesize: 3145728 bytes
Done writing partition. Write speed: 8436.27 KB/s
Partition CACHE : formatting as EXT4. Please wait ...
Formatting completed
Partition HIDDEN : formatting as EXT4. Please wait ...
Partition USERDATA : formatting as EXT4. Please wait ...
Done
All done time: [00:03:55:547]
