03-17-2018, 08:46 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Samsung j200g mdm on problem Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 Mhz CMD Pullup Level: 482 mV CMD Active Level: 1656 mV EMMC Device Information : EMMC CID: 90014A4838473474320129574A5984ED EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4t2 , EMMC NAME (HEX): 483847347432 , S/N: 29574A59 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 8/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4t2_29574A59_20180317_131417.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 Partition: CARRIER, [000003400000 - 000003800000], size: 000000400000 Partition: PARAM, [000003800000 - 000004000000], size: 000000800000 Partition: BOOT, [000004000000 - 000004D00000], size: 000000D00000 Partition: RECOVERY, [000004D00000 - 000005C00000], size: 000000F00000 Partition: OTA, [000005C00000 - 000006400000], size: 000000800000 Partition: CDMA-RADIO, [000006400000 - 000006800000], size: 000000400000 Partition: RADIO, [000006800000 - 000009000000], size: 000002800000 Partition: TOMBSTONES, [000009000000 - 000009400000], size: 000000400000 Partition: TDATA, [000009400000 - 000009800000], size: 000000400000 Partition: PERSISTENT, [000009800000 - 000009900000], size: 000000100000 Partition: PERSDATA, [000009900000 - 00000A500000], size: 000000C00000 Partition: RESERVED2, [00000A500000 - 00000A800000], size: 000000300000 Partition: SYSTEM, [00000A800000 - 00009A800000], size: 000090000000 Partition: CACHE, [00009A800000 - 0000A7000000], size: 00000C800000 Partition: HIDDEN, [0000A7000000 - 0000A9800000], size: 000002800000 Partition: USERDATA, [0000A9800000 - 0001D1C00000], size: 000128400000 GPT header successfully parsed Get firmware version Error: Except: Unmount [cache/] failed Brand = samsung Manufacturer = samsung Model = SM-J200G Phone platform = exynos3 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY47X.J200GDCU2AQH3 Firmware date = Wed Aug 16 20:19:56 KST 2017 how to solve Error: Except: Unmount [cache/] failed? |
