03-10-2018, 12:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,080 | Samsung J200h Dead Boot Reapir Success CMD Pullup Level: 2093 mV CMD Active Level: 2918 mV EMMC Device Information : EMMC CID: 90014A483847347421010AA52132838E EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4t , EMMC NAME (HEX): 483847347400 , S/N: 0AA52132 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 8/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t_0AA52132_20180310_162534.extcsd EMMC Init completed. Get firmware version Firmware info not found Setting frequence to 21 Mhz CMD Pullup Level: 2093 mV CMD Active Level: 2918 mV EMMC Device Information : EMMC CID: 90014A483847347421010AA52132838E EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4t , EMMC NAME (HEX): 483847347400 , S/N: 0AA52132 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 8/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t_0AA52132_20180310_162650.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: param.lfs Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 341.67 KB/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 764.01 KB/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 759.76 KB/s Partition name: PARAM Filename: param.lfs , Offset: 000002900000 , filesize: 573440 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 756.71 KB/s Partition CACHE : formatting as EXT4. Please wait ... Formatting completed Partition HIDDEN : formatting as EXT4. Please wait ... Formatting completed Partition EFS : formatting as EXT4. Please wait ... Formatting completed All done time: [00:00:22:985] https://www.facebook.com/permalink.p...tion&ref=notif |
The Following User Says Thank You to raisalina For This Useful Post: |
