Member: 413268
Thanks Meter: 76 | Samsung J200h/ds emmc repair done first full erase emmc
Repair EMMC using factory file -- Easy Jtag Plus
phone should be enter download mode
Flash phone using same file
log : Quote:
31/03/2017 18:19:40> eMMC_tool Suite ver. 1.0.0.42
31/03/2017 18:19:40> Microsoft Windows 8.1 (32 bit) build 9600 (6.3.9600.18217)
31/03/2017 18:19:40> Looking for EasyJTAG box...
31/03/2017 18:19:40> EasyJTAG API ver. 2008
31/03/2017 18:19:40> Setting IO Levels to 2.8V
31/03/2017 18:19:40> Setting frequence to 21 Mhz
31/03/2017 18:19:40> HiPower mode is OFF
31/03/2017 18:19:41> OpenUSB returned = 0
31/03/2017 18:19:41> Power Controller returned = 0
31/03/2017 18:19:41> EasyJTAG Box Serial = 06060709B543D70E
31/03/2017 18:19:45> Card Serial = AA10-A253
31/03/2017 18:19:45> CardAttr = 3B7D95000080318065B0831148C883009000
31/03/2017 18:19:45> EasyJTAG Box Firmware = 01.56
31/03/2017 18:20:02> Looking for EasyJTAG box...
31/03/2017 18:20:02> EasyJTAG API ver. 2008
31/03/2017 18:20:02> Setting IO Levels to 2.8V
31/03/2017 18:20:02> Setting frequence to 21 Mhz
31/03/2017 18:20:02> HiPower mode is OFF
31/03/2017 18:20:03> OpenUSB returned = 0
31/03/2017 18:20:03> Power Controller returned = 0
31/03/2017 18:20:03> EasyJTAG Box Serial = 06060709B543D70E
31/03/2017 18:20:03> EasyJTAG Box Firmware = 01.56
31/03/2017 18:20:03> HiPower mode is OFF
31/03/2017 18:20:04> CMD Pullup Level: 2041 mV
31/03/2017 18:20:04> CMD Active Level: 2516 mV
31/03/2017 18:20:04> eMMC Init returned = 0
31/03/2017 18:20:04> EMMC Device Information :
31/03/2017 18:20:04> EMMC CID: 90014A483847347421010504D52B13AA
31/03/2017 18:20:04> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012
31/03/2017 18:20:04> EMMC Manufacture Name: SKHYNIX
31/03/2017 18:20:04> EMMC Manufacture ID: 0x90 , OEM ID: 014A
31/03/2017 18:20:04> EMMC Manufacture Date: 1/2016 , Rev: 01
31/03/2017 18:20:04> EMMC NAME: H8G4t! , S/N: 0504D52B , rev. 01
31/03/2017 18:20:04> EMMC NAME (HEX): 483847347421
31/03/2017 18:20:04> EMMC ROM 1 (Main User Data) Capacity: 7448 MB (0001D1800000)
31/03/2017 18:20:04> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
31/03/2017 18:20:04> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
31/03/2017 18:20:04> EMMC Permanent Write Protection: No
31/03/2017 18:20:04> EMMC Temporary Write Protection: No
31/03/2017 18:20:04> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
31/03/2017 18:20:04> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
31/03/2017 18:20:04> Boot Bus Config: 0x00 , width 1bit
31/03/2017 18:20:04> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
31/03/2017 18:20:04> Supported partition features [PARTITIONING_SUPPORT]: 0x07
31/03/2017 18:20:04> Device supports partitioning features
31/03/2017 18:20:04> Device can have enhanced technological features in partitions and user data area
31/03/2017 18:20:04> Device can have extended partitions attribute
31/03/2017 18:20:04> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
31/03/2017 18:20:04> Backup saved: H8G4t!_0504D52B_20170331_182004.extcsd
31/03/2017 18:20:04> EMMC Init completed.
31/03/2017 18:20:22> Looking for EasyJTAG box...
31/03/2017 18:20:22> EasyJTAG API ver. 2008
31/03/2017 18:20:22> Setting IO Levels to 2.8V
31/03/2017 18:20:22> Setting frequence to 21 Mhz
31/03/2017 18:20:22> HiPower mode is OFF
31/03/2017 18:20:24> OpenUSB returned = 0
31/03/2017 18:20:24> Power Controller returned = 0
31/03/2017 18:20:24> EasyJTAG Box Serial = 06060709B543D70E
31/03/2017 18:20:24> EasyJTAG Box Firmware = 01.56
31/03/2017 18:20:24> HiPower mode is OFF
31/03/2017 18:20:24> CMD Pullup Level: 2052 mV
31/03/2017 18:20:24> CMD Active Level: 2516 mV
31/03/2017 18:20:24> eMMC Init returned = 0
31/03/2017 18:20:24> EMMC Device Information :
31/03/2017 18:20:24> EMMC CID: 90014A483847347421010504D52B13AA
31/03/2017 18:20:24> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012
31/03/2017 18:20:24> EMMC Manufacture Name: SKHYNIX
31/03/2017 18:20:24> EMMC Manufacture ID: 0x90 , OEM ID: 014A
31/03/2017 18:20:24> EMMC Manufacture Date: 1/2016 , Rev: 01
31/03/2017 18:20:24> EMMC NAME: H8G4t! , S/N: 0504D52B , rev. 01
31/03/2017 18:20:24> EMMC NAME (HEX): 483847347421
31/03/2017 18:20:24> EMMC ROM 1 (Main User Data) Capacity: 7448 MB (0001D1800000)
31/03/2017 18:20:24> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
31/03/2017 18:20:24> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
31/03/2017 18:20:24> EMMC Permanent Write Protection: No
31/03/2017 18:20:24> EMMC Temporary Write Protection: No
31/03/2017 18:20:24> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
31/03/2017 18:20:24> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
31/03/2017 18:20:24> Boot Bus Config: 0x00 , width 1bit
31/03/2017 18:20:24> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
31/03/2017 18:20:24> Supported partition features [PARTITIONING_SUPPORT]: 0x07
31/03/2017 18:20:24> Device supports partitioning features
31/03/2017 18:20:24> Device can have enhanced technological features in partitions and user data area
31/03/2017 18:20:24> Device can have extended partitions attribute
31/03/2017 18:20:24> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
31/03/2017 18:20:24> Backup saved: H8G4t!_0504D52B_20170331_182024.extcsd
31/03/2017 18:20:24> EMMC Init completed.
31/03/2017 18:20:24> Opening file: C:\Users\EamaTech\Desktop\J200H_XXU0APK1_OXE0APK1\ J23G_EUR_OPEN.pit
31/03/2017 18:20:24> Pit: J23G_EUR_OPEN.pit
31/03/2017 18:20:24> Entry count: 31
31/03/2017 18:20:24> The size of the last section has been updated
31/03/2017 18:20:29>
31/03/2017 18:20:29> BL_J200HXXU0APK1_CL1145746_QB11476181_REV00_user_l ow_ship.tar.md5
31/03/2017 18:20:29> The list of files in the firmware:
31/03/2017 18:20:29> spl.img
31/03/2017 18:20:29> sboot.bin
31/03/2017 18:20:29> sboot2.bin
31/03/2017 18:20:29> param.lfs
31/03/2017 18:20:35> AP_J200HXXU0APK1_CL1145746_QB11476181_REV00_user_l ow_ship.tar.md5
31/03/2017 18:20:35> The list of files in the firmware:
31/03/2017 18:20:35> boot.img
31/03/2017 18:20:35> recovery.img
31/03/2017 18:20:35> system.img
31/03/2017 18:20:40> MODEM_J200HXXU0APC1_CL2092461_QB4557520_REV00.tar. md5
31/03/2017 18:20:40> The list of files in the firmware:
31/03/2017 18:20:40> sprdcp.img
31/03/2017 18:20:40> sprddsp.img
31/03/2017 18:20:40> nvitem.bin
31/03/2017 18:20:43> CSC_OXE_J200HOXE0APK1_CL1145746_QB11476181_REV00_u ser_low_ship.tar.md5
31/03/2017 18:20:43> The list of files in the firmware:
31/03/2017 18:20:43> j23g_eur_open.pit
31/03/2017 18:20:43> cache.img
31/03/2017 18:20:43> hidden.img
31/03/2017 18:20:49> Looking for EasyJTAG box...
31/03/2017 18:20:49> EasyJTAG API ver. 2008
31/03/2017 18:20:49> Setting IO Levels to 2.8V
31/03/2017 18:20:49> Setting frequence to 21 Mhz
31/03/2017 18:20:49> HiPower mode is OFF
31/03/2017 18:20:51> OpenUSB returned = 0
31/03/2017 18:20:51> Power Controller returned = 0
31/03/2017 18:20:51> EasyJTAG Box Serial = 06060709B543D70E
31/03/2017 18:20:51> EasyJTAG Box Firmware = 01.56
31/03/2017 18:20:51> HiPower mode is OFF
31/03/2017 18:20:51> CMD Pullup Level: 2041 mV
31/03/2017 18:20:51> CMD Active Level: 2505 mV
31/03/2017 18:20:51> eMMC Init returned = 0
31/03/2017 18:20:51> EMMC Device Information :
31/03/2017 18:20:51> EMMC CID: 90014A483847347421010504D52B13AA
31/03/2017 18:20:51> EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012
31/03/2017 18:20:51> EMMC Manufacture Name: SKHYNIX
31/03/2017 18:20:51> EMMC Manufacture ID: 0x90 , OEM ID: 014A
31/03/2017 18:20:51> EMMC Manufacture Date: 1/2016 , Rev: 01
31/03/2017 18:20:51> EMMC NAME: H8G4t! , S/N: 0504D52B , rev. 01
31/03/2017 18:20:51> EMMC NAME (HEX): 483847347421
31/03/2017 18:20:51> EMMC ROM 1 (Main User Data) Capacity: 7448 MB (0001D1800000)
31/03/2017 18:20:51> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
31/03/2017 18:20:51> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
31/03/2017 18:20:51> EMMC Permanent Write Protection: No
31/03/2017 18:20:51> EMMC Temporary Write Protection: No
31/03/2017 18:20:51> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
31/03/2017 18:20:51> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
31/03/2017 18:20:51> Boot Bus Config: 0x00 , width 1bit
31/03/2017 18:20:51> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
31/03/2017 18:20:51> Supported partition features [PARTITIONING_SUPPORT]: 0x07
31/03/2017 18:20:51> Device supports partitioning features
31/03/2017 18:20:51> Device can have enhanced technological features in partitions and user data area
31/03/2017 18:20:51> Device can have extended partitions attribute
31/03/2017 18:20:51> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
31/03/2017 18:20:51> Backup saved: H8G4t!_0504D52B_20170331_182051.extcsd
31/03/2017 18:20:51> EMMC Init completed.
31/03/2017 18:20:51> Operation: Write by vendor (Samsung)
31/03/2017 18:20:51> Unpacking file: spl.img
31/03/2017 18:20:51> Unpacking file: sboot.bin
31/03/2017 18:20:51> Unpacking file: sboot2.bin
31/03/2017 18:20:51> Unpacking file: nvitem.bin
31/03/2017 18:20:51> Unpacking file: sprddsp.img
31/03/2017 18:20:51> Unpacking file: sprdcp.img
31/03/2017 18:20:51> Unpacking file: param.lfs
31/03/2017 18:20:51> Unpacking file: boot.img
31/03/2017 18:20:51> Unpacking file: recovery.img
31/03/2017 18:20:51> Unpacking file: cache.img
31/03/2017 18:20:51> Unpacking file: system.img
31/03/2017 18:21:02> Unpacking file: hidden.img
31/03/2017 18:21:03>
31/03/2017 18:21:03> Partition name: BOOT
31/03/2017 18:21:03> Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes
31/03/2017 18:21:03> eMMC switching to ROM2
31/03/2017 18:21:03> Writing partition...
31/03/2017 18:21:03> Done writing partition. Write speed: 435,69 Kb/s
31/03/2017 18:21:03> Partition name: SBOOT
31/03/2017 18:21:03> Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes
31/03/2017 18:21:03> eMMC switching to ROM1
31/03/2017 18:21:05> Done writing partition. Write speed: 1293,60 Kb/s
31/03/2017 18:21:05> Partition name: SBOOT2
31/03/2017 18:21:05> Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes
31/03/2017 18:21:05> eMMC switching to ROM1
31/03/2017 18:21:05> Writing partition...
31/03/2017 18:21:06> Done writing partition. Write speed: 1296,43 Kb/s
31/03/2017 18:21:06> Partition name: WFIXNV2
31/03/2017 18:21:06> Filename: nvitem.bin , Offset: 000000900000 , filesize: 181868 bytes
31/03/2017 18:21:06> eMMC switching to ROM1
31/03/2017 18:21:06> Writing partition...
31/03/2017 18:21:07> Done writing partition. Write speed: 1091,44 Kb/s
31/03/2017 18:21:07> Partition name: WDSP
31/03/2017 18:21:07> Filename: sprddsp.img , Offset: 000000C00000 , filesize: 2097152 bytes
31/03/2017 18:21:07> eMMC switching to ROM1
31/03/2017 18:21:07> Writing partition...
31/03/2017 18:21:08> Done writing partition. Write speed: 1341,84 Kb/s
31/03/2017 18:21:08> Partition name: MODEM
31/03/2017 18:21:08> Filename: sprdcp.img , Offset: 000001000000 , filesize: 8388608 bytes
31/03/2017 18:21:08> eMMC switching to ROM1
31/03/2017 18:21:09> Writing partition...
31/03/2017 18:21:17> Done writing partition. Write speed: 986,33 Kb/s
31/03/2017 18:21:17> Partition name: PARAM
31/03/2017 18:21:17> Filename: param.lfs , Offset: 000002900000 , filesize: 573440 bytes
31/03/2017 18:21:17> eMMC switching to ROM1
31/03/2017 18:21:17> Writing partition...
31/03/2017 18:21:18> Done writing partition. Write speed: 832,93 Kb/s
31/03/2017 18:21:18> Partition name: KERNEL
31/03/2017 18:21:18> Filename: boot.img , Offset: 000004600000 , filesize: 13796368 bytes
31/03/2017 18:21:18> eMMC switching to ROM1
31/03/2017 18:21:18> Writing partition...
31/03/2017 18:21:33> Done writing partition. Write speed: 941,11 Kb/s
31/03/2017 18:21:33> Partition name: RECOVERY
31/03/2017 18:21:33> Filename: recovery.img , Offset: 000005600000 , filesize: 14527504 bytes
31/03/2017 18:21:33> eMMC switching to ROM1
31/03/2017 18:21:33> Writing partition...
31/03/2017 18:21:48> Done writing partition. Write speed: 947,07 Kb/s
31/03/2017 18:21:48> Partition name: CACHE
31/03/2017 18:21:48> Filename: cache.img , Offset: 000007000000 , filesize: 21074208 bytes
31/03/2017 18:21:48> eMMC switching to ROM1
31/03/2017 18:21:48> Writing partition...
31/03/2017 18:21:48> Sparse image found v.1.0 Total chunks: 16
31/03/2017 18:22:07> Done writing partition. Write speed: 1094,57 Kb/s
31/03/2017 18:22:07> Partition name: SYSTEM
31/03/2017 18:22:07> Filename: system.img , Offset: 000013800000 , filesize: 1415671168 bytes
31/03/2017 18:22:07> eMMC switching to ROM1
31/03/2017 18:22:07> Writing partition...
31/03/2017 18:22:07> Sparse image found v.1.0 Total chunks: 2262
31/03/2017 18:48:19> Done writing partition. Write speed: 879,76 Kb/s
31/03/2017 18:48:19> Partition name: HIDDEN
31/03/2017 18:48:19> Filename: hidden.img , Offset: 000071400000 , filesize: 26431808 bytes
31/03/2017 18:48:19> eMMC switching to ROM1
31/03/2017 18:48:19> Writing partition...
31/03/2017 18:48:19> Sparse image found v.1.0 Total chunks: 18
31/03/2017 18:48:45> Done writing partition. Write speed: 996,93 Kb/s
31/03/2017 18:48:45> All done
| Thanks Z3X for great work |
