10-17-2017, 15:34 | #1 (permalink) |
Freak Poster Join Date: Aug 2014 Location: kolkata
Member: 2234421 Status: Offline Sonork: 100.1674816 Thanks Meter: 60 | Samsung J200H flashing with easy jtag need help so need flash procedur emmc method with easy jtag |
10-17-2017, 15:35 | #2 (permalink) |
Member: 2234421 Status: Offline Sonork: 100.1674816 Thanks Meter: 60 | try to flash with direct emmc odin flasher but not done here is log Setting IO Levels to 2.8V OpenUSB returned=0 Power Controller returned=0 EasyJTAG Box Serial=0C00B01800A01620 EasyJTAG Box Firmware=01.60 eMMC Init returned=0 eMMC NAME = 483847347421 eMMC Size ROM1 (User)= 15269888 Blocks (7.3 GB) eMMC Size ROM2 (Boot1)= 8192 Blocks (4.0 MB) eMMC Size ROM3 (Boot2)= 8192 Blocks (4.0 MB) eMMC Size RPMB (Protected) = 8192 Blocks (4.0 MB) eMMC Init completed. ODIN: Writing PIT... Creating GPT-partitioninig Unpacking file spl.img and adding to image Offset for BOOT is 00000000 ODIN: Writing ROM2 <- spl.img - 0x0000000A blocks to eMMC offset 00000000 Offset for C:\ProgramData\Z3XAppsData\temp\spl.img is 00000000 ODIN: Filesize 32768 Blocks 64 ODIN: eMMC switching to ROM2 Done writing partition... Unpacking file sboot.bin and adding to image Offset for SBOOT is 00400000 ODIN: Writing ROM1 <- sboot.bin - 0x0000000A blocks to eMMC offset 00400000 Offset for C:\ProgramData\Z3XAppsData\temp\sboot.bin is 00400000 ODIN: Filesize 1573888 Blocks 3074 ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file sboot2.bin and adding to image Offset for SBOOT2 is 00600000 ODIN: Writing ROM1 <- sboot2.bin - 0x0000000A blocks to eMMC offset 00600000 Offset for C:\ProgramData\Z3XAppsData\temp\sboot2.bin is 00600000 ODIN: Filesize 1573888 Blocks 3074 ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file nvitem.bin and adding to image Offset for WFIXNV2 is 00900000 ODIN: Writing ROM1 <- nvitem.bin - 0x0000000A blocks to eMMC offset 00900000 Offset for C:\ProgramData\Z3XAppsData\temp\nvitem.bin is 00900000 ODIN: Filesize 181868 Blocks 355 ODIN: Misalign 108 Bytes ODIN: FIX Filesize 182272 Blocks 356 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file sprddsp.img and adding to image Offset for WDSP is 00C00000 ODIN: Writing ROM1 <- sprddsp.img - 0x0000000A blocks to eMMC offset 00C00000 Offset for C:\ProgramData\Z3XAppsData\temp\sprddsp.img is 00C00000 ODIN: Filesize 2097152 Blocks 4096 ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file sprdcp.img and adding to image Offset for MODEM is 01000000 ODIN: Writing ROM1 <- sprdcp.img - 0x0000000A blocks to eMMC offset 01000000 Offset for C:\ProgramData\Z3XAppsData\temp\sprdcp.img is 01000000 ODIN: Filesize 8388608 Blocks 16384 ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file param.lfs and adding to image Offset for PARAM is 02900000 ODIN: Writing ROM1 <- param.lfs - 0x0000000A blocks to eMMC offset 02900000 Offset for C:\ProgramData\Z3XAppsData\temp\param.lfs is 02900000 ODIN: Filesize 573440 Blocks 1120 ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file boot.img and adding to image Offset for KERNEL is 04600000 ODIN: Writing ROM1 <- boot.img - 0x0000000A blocks to eMMC offset 04600000 Offset for C:\ProgramData\Z3XAppsData\temp\boot.img is 04600000 ODIN: Filesize 13788176 Blocks 26930 ODIN: Misalign 16 Bytes ODIN: FIX Filesize 13788672 Blocks 26931 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file recovery.img and adding to image Offset for RECOVERY is 05600000 ODIN: Writing ROM1 <- recovery.img - 0x0000000A blocks to eMMC offset 05600000 Offset for C:\ProgramData\Z3XAppsData\temp\recovery.img is 05600000 ODIN: Filesize 14519312 Blocks 28358 ODIN: Misalign 16 Bytes ODIN: FIX Filesize 14519808 Blocks 28359 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file cache.img and adding to image Offset for CACHE is 07000000 ODIN: Writing ROM1 <- cache.img - 0x0000000A blocks to eMMC offset 07000000 Offset for C:\ProgramData\Z3XAppsData\temp\cache.img is 07000000 ODIN: Filesize 41460000 Blocks 80976 ODIN: eMMC switching to ROM1 Sparse image found v. 00000001.00000000 Sparse header size : 00000020 Chunk header size : 00000010 Data Block size : 00001000 8 pages Total blocks : 51200 Total chunks : 16 Image CRC32 : 00000000 ------------------------------ Chunk type : 0000 Reserved data : 0000 Output data size : 0000CAC1 Total data size: 00000001 Chunk Type is Unknown... Done writing partition... Unpacking file system.img and adding to image Offset for SYSTEM is 13800000 ODIN: Writing ROM1 <- system.img - 0x0000000A blocks to eMMC offset 13800000 Offset for C:\ProgramData\Z3XAppsData\temp\system.img is 13800000 ODIN: Filesize 1384963008 Blocks 2705005 ODIN: eMMC switching to ROM1 Sparse image found v. 00000001.00000000 Sparse header size : 00000020 Chunk header size : 00000010 Data Block size : 00001000 8 pages Total blocks : 384000 Total chunks : 2234 Image CRC32 : 00000000 ------------------------------ Chunk type : 0000 Reserved data : 0000 Output data size : 0000CAC1 Total data size: 00000001 Chunk Type is Unknown... Done writing partition... Unpacking file hidden.img and adding to image Offset for HIDDEN is 71400000 ODIN: Writing ROM1 <- hidden.img - 0x0000000A blocks to eMMC offset 71400000 Offset for C:\ProgramData\Z3XAppsData\temp\hidden.img is 71400000 ODIN: Filesize 16483312 Blocks 32193 ODIN: eMMC switching to ROM1 Sparse image found v. 00000001.00000000 Sparse header size : 00000020 Chunk header size : 00000010 Data Block size : 00001000 8 pages Total blocks : 7680 Total chunks : 61 Image CRC32 : 00000000 ------------------------------ Chunk type : 0000 Reserved data : 0000 Output data size : 0000CAC1 Total data size: 00000001 Chunk Type is Unknown... Done writing partition... All Done! |
