05-06-2018, 09:20 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: india
Member: 2097870 Status: Offline Sonork: FINDING.... Thanks Meter: 65 | Ao5510 boot repair PROBLEM PHONE NOT POWER ON ANY SOL ? ---------- eMMC Device Information ---------- EMMC CID : 90014A4841473464040503A2F03622A9 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2015 Rev.0x5 EMMC NAME: HAG4d , S/N: 61009974 EMMC NAME (HEX): 48414734642000 EMMC ROM1 (Main User Data) Capacity: 15032 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HAG4d _ 61009974_20180506_1340.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5C000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D5BFBC sectors 14.7 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30785502 Found Data areas (firmware parts) count is: 29 Partition info successfully found --------------------------------------------- P0 (MODEM) [0x2000000 0x4000000] Size: 64.0MB P1 (SBL1) [0x6000000 0x80000] Size: 512.0KB P2 (SBL1BAK) [0x6080000 0x80000] Size: 512.0KB P3 (ABOOT) [0x6100000 0xf00000] Size: 15.0MB P4 (ABOOTBAK) [0x7000000 0xf00000] Size: 15.0MB P5 (RPM) [0x7f00000 0x80000] Size: 512.0KB P6 (RPMBAK) [0x7f80000 0x80000] Size: 512.0KB P7 (TZ) [0x8000000 0x80000] Size: 512.0KB P8 (TZBAK) [0x8080000 0x80000] Size: 512.0KB P9 (HYP) [0x8100000 0x80000] Size: 512.0KB P10 (HYPBAK) [0x8180000 0x80000] Size: 512.0KB P11 (PAD) [0x8200000 0x100000] Size: 1.0MB P12 (MODEMST1) [0x8300000 0x180000] Size: 1.500MB P13 (MODEMST2) [0x8480000 0x180000] Size: 1.500MB P14 (MISC) [0x8600000 0x100000] Size: 1.0MB P15 (FSC) [0x8700000 0x400] Size: 1.0KB P16 (SSD) [0x8700400 0x2000] Size: 8.0KB P17 (DDR) [0xa000000 0x8000] Size: 32.0KB P18 (FSG) [0xa008000 0x180000] Size: 1.500MB P19 (SEC) [0xa188000 0x4000] Size: 16.0KB P20 (BOOT) [0xa18c000 0x1400000] Size: 20.0MB P21 (PARAMS) [0xc000000 0x100000] Size: 1.0MB P22 (PANIC) [0xc100000 0x1400000] Size: 20.0MB P23 (AUTOBAK) [0xd500000 0xa00000] Size: 10.0MB P24 (SYSTEM) [0xe000000 0x4b000000] Size: 1.171GB P25 (PERSIST) [0x59000000 0xa00000] Size: 10.0MB P26 (CACHE) [0x59a00000 0x8000000] Size: 128.0MB P27 (RECOVERY) [0x61a00000 0x1400000] Size: 20.0MB P28 (USERDATA) [0x62e00000 0x3489fbe00] Size: 13.133GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000E000000 (1.171GB) Build ID: LRX22G Display Build ID: LRX22G Release ID: 5.0.2 Device Name: YUREKA Architecture ABI: arm64-v8a Device manufacturer: YU Device Platform: msm8916 Product ID: YUREKA Device Model: AO5510 Build Description: YUREKA-user 5.0.2 LRX22G YNG1TAS0W0 release-keys |
