Easy-Jtag / Easy-Jtag Plus The official support section. You can ask here your question and get answer regarding using Easy-Jtag / Easy-Jtag Plus. |
08-16-2019, 12:18 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | samsung j210f dead repair help Code: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting frequence to 21 MHz CMD Pullup Level: 2021 mV CMD Active Level: 2475 mV EMMC Device Information : EMMC CID: 150100514E3136424200771BE48873B8 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: 771BE488 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_771BE488_20100428_000219.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 (2.00 MB) Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 (2.00 MB) Partition: l_fixnv1, [000000800000 - 000000900000], size: 000000100000 (1.00 MB) Partition: l_fixnv2, [000000900000 - 000000A00000], size: 000000100000 (1.00 MB) Partition: pm_sys, [000000A00000 - 000000B00000], size: 000000100000 (1.00 MB) Partition: rsvdfixnv1, [000000B00000 - 000000C00000], size: 000000100000 (1.00 MB) Partition: l_ldsp, [000000C00000 - 000001000000], size: 000000400000 (4.00 MB) Partition: l_modem, [000001000000 - 000002000000], size: 000001000000 (16.0 MB) Partition: l_gdsp, [000002000000 - 000002400000], size: 000000400000 (4.00 MB) Partition: l_warm, [000002400000 - 000002800000], size: 000000400000 (4.00 MB) Partition: FOTA_SIG, [000002800000 - 000002900000], size: 000000100000 (1.00 MB) Partition: l_runtimenv1, [000002900000 - 000002A00000], size: 000000100000 (1.00 MB) Partition: l_runtimenv2, [000002A00000 - 000002B00000], size: 000000100000 (1.00 MB) Partition: td_runtimenv1, [000002B00000 - 000002C00000], size: 000000100000 (1.00 MB) Partition: td_runtimenv2, [000002C00000 - 000002D00000], size: 000000100000 (1.00 MB) Partition: PARAM, [000002D00000 - 000002F00000], size: 000000200000 (2.00 MB) Partition: efs, [000002F00000 - 000004300000], size: 000001400000 (20.0 MB) Partition: prodnv, [000004300000 - 000004800000], size: 000000500000 (5.00 MB) Partition: RESERVED2, [000004800000 - 000004E00000], size: 000000600000 (6.00 MB) Partition: KERNEL, [000004E00000 - 000006200000], size: 000001400000 (20.0 MB) Partition: RECOVERY, [000006200000 - 000007600000], size: 000001400000 (20.0 MB) Partition: PERSISTENT, [000007600000 - 000007700000], size: 000000100000 (1.00 MB) Partition: PERSDATA, [000007700000 - 000008000000], size: 000000900000 (9.00 MB) Partition: CACHE, [000008000000 - 000014800000], size: 00000C800000 (200. MB) Partition: SYSTEM, [000014800000 - 0000A1000000], size: 00008C800000 (2.20 GB) Partition: HIDDEN, [0000A1000000 - 0000A3800000], size: 000002800000 (40.0 MB) Partition: userdata, [0000A3800000 - 0003AA800000], size: 000307000000 (12.1 GB) GPT header successfully parsed Get firmware version Firmware info not found |
