04-05-2019, 04:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,076 | Samsung J7 Prime G6100 Backup Emmc Dump Success Code: HiPower mode is ON Setting frequence to 21 Mhz CMD Pullup Level: 2000 mV CMD Active Level: 2629 mV EMMC Device Information : EMMC CID: 150100525831424D4210DC60C2BB84EC EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: DC60C2BB , rev. 0x10 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RX1BMB_DC60C2BB_20190404_182859.extcsd EMMC Init completed. Get firmware version Brand = samsung Manufacturer = samsung Device = on7xltechn Model = SM-G6100 Phone platform = msm8953 CPU Abi = arm64-v8a Android release = 8.0.0 Firmware version = R16NW.G6100ZHU2CRI8 Firmware date = Sun Sep 30 08:52:46 KST 2018 HiPower mode is ON Setting frequence to 21 Mhz CMD Pullup Level: 2000 mV CMD Active Level: 2640 mV EMMC Device Information : EMMC CID: 150100525831424D4210DC60C2BB84EC EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: DC60C2BB , rev. 0x10 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RX1BMB_DC60C2BB_20190404_182922.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM1 , start: 0x000000000000 , size: 0x000020000000 Output file: C:\Users\Salina\Desktop\0\g6100\EMMC_RX1BMB_ROM1_000000000000_000020000000.bin eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 952.49 Kb/s All done time: [00:09:16:052] HiPower mode is ON Setting frequence to 21 Mhz CMD Pullup Level: 2000 mV CMD Active Level: 2640 mV EMMC Device Information : EMMC CID: 150100525831424D4210DC60C2BB84EC EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: DC60C2BB , rev. 0x10 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RX1BMB_DC60C2BB_20190404_183906.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM2 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\Salina\Desktop\0\g6100\EMMC_RX1BMB_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Reading partition... Done reading partition. Read speed: 532.82 Kb/s All done time: [00:00:13:081] HiPower mode is ON Setting frequence to 21 Mhz CMD Pullup Level: 2000 mV CMD Active Level: 2629 mV EMMC Device Information : EMMC CID: 150100525831424D4210DC60C2BB84EC EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: DC60C2BB , rev. 0x10 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RX1BMB_DC60C2BB_20190404_183929.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM3 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\Salina\Desktop\0\g6100\EMMC_RX1BMB_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Reading partition... Done reading partition. Read speed: 482.98 Kb/s All done time: [00:00:13:866] https://www.youtube.com/watch?v=WbsxCUgyLqM&t=124s |
The Following 2 Users Say Thank You to raisalina For This Useful Post: |
05-16-2019, 12:26 | #3 (permalink) |
Freak Poster Join Date: Aug 2013 Location: searching
Member: 1996822 Status: Offline Thanks Meter: 93 | thanks raisalina Samsung J7 Prime G6100 FRP done Setting frequence to 21 Mhz CMD Pullup Level: 1990 mV CMD Active Level: 2629 mV EMMC Device Information : EMMC CID: 150100525831424D4210F61CC20A836A EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: F61CC20A , rev. 0x10 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RX1BMB_F61CC20A_20190516_170825.extcsd EMMC Init completed. Get firmware version Brand = samsung Manufacturer = samsung Device = on7xltechn Model = SM-G6100 Phone platform = msm8953 CPU Abi = arm64-v8a Android release = 8.0.0 Firmware version = R16NW.G6100ZHU2CRI8 Firmware date = Sun Sep 30 08:52:46 KST 2018 Setting frequence to 21 Mhz CMD Pullup Level: 1980 mV CMD Active Level: 2619 mV EMMC Device Information : EMMC CID: 150100525831424D4210F61CC20A836A EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: F61CC20A , rev. 0x10 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RX1BMB_F61CC20A_20190516_170838.extcsd EMMC Init completed. Operation: Remove FRP Searching GPT ... GPT header is found and is valid FRP partition found (partname: persistent) Erasing FRP partition ... Done erasing partition. All done |
The Following User Says Thank You to tasweb For This Useful Post: |
