07-28-2019, 07:15 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Samsung J701F Try All eMMC Pinout But Mobile Still Not Connect Please Help Me Code: Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: xxxxxxxxxxxxx, ,FW Ver.: 01.63 CMD Pullup Level:536 mV CMD Active Level:2567 mV Box IO Level:2800 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: xxxxxxxxxxxx, ,FW Ver.: 01.63 CMD Pullup Level:567 mV CMD Active Level:2877 mV Box IO Level:3300 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: xxxxxxxxxxx, ,FW Ver.: 01.63 CMD Pullup Level:2258 mV CMD Active Level:2846 mV Box IO Level:3300 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Second Error: Code: Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: xxxxxxxxxxxx, ,FW Ver.: 01.63 CMD Pullup Level:587 mV CMD Active Level:1722 mV Box IO Level:1800 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: xxxxxxxxxxx, ,FW Ver.: 01.63 CMD Pullup Level:649 mV CMD Active Level:2536 mV Box IO Level:2800 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: xxxxxxxxxxxx, ,FW Ver.: 01.63 CMD Pullup Level:505 mV CMD Active Level:2794 mV Box IO Level:3300 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Sir I Was Try All These Pinouts But Mobile Still Not Connect Thanks & Regards By:All TECH 4 You |
The Following User Says Thank You to Yashbanswara For This Useful Post: |
07-28-2019, 07:41 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Earth
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | I have the same problem, J701F doesn’t get connected properly. May be all pinouts have some mistakes Sent from my iPhone using Tapatalk |
07-28-2019, 10:27 | #5 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | ow this error coming: Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0B0170135E37F259, ,FW Ver.: 01.63 Warning: CMD Pullup Level (237 mV) too low , check cables etc.! CMD Active Level:288 mV Box IO Level:2800 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. |
07-28-2019, 10:31 | #6 (permalink) |
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | yes , I Managed to connect using this pinout but with other box (u f i ). thank you. Code: Insertion test... Done. Init bus... VCC: 3.3 V, VCCQ: 1.8 V Bus: 1 bit (SDR 4MHz) Access mode: sector mode Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V) Card/BGA: BGA (Discrete embedded) - High density MMC Manufacturer ID: 0x15 (Samsung) Product name: AJTD4R (0x414a54443452), rev: 0x00, serial number: 0x7058B47C Manufacturing date: Aug 2017 CID: 15010041 4A544434 52007058 B47C8400 CSD: D0270132 0F5903FF F6DBFFEF 8E40400C EXT_CSD revision: 1.8 (MMC v5.1) Partition info: Boot1: 4096 KiB Boot2: 4096 KiB RPMB: 16384 KiB User area: 14.68 GiB(15,758,000,128 bytes) Cache size: 64 MiB Partition configuration: 0x00 No boot acknowledge is sent (default) Device is not boot-enabled (default) Partitioning support: 0x07 Device support partitioning feature Device can have enhanced technological features Device partitioning possible Boot configuration protection: 0x00 Boot bus conditions: 0x01 Bus width: x4 (sdr/ddr), boot mode: sdr(default), reset bus width to x1 sdr(default) Boot area write protection: 0x00 Power-on write protection: possible Permanent write protection: possible Lock status: not locked User area write protection: 0x50 Password protection features: enabled Power-on write protection: possible Permanent write protection: not possible Lock status: not locked ANDROID System Info: platform: exynos5, cpu abi: armeabi-v7a manufacturer: samsung board: universal7870, name: j7veltedx brand: samsung, model: SM-J701F build id: M1AJQ, version: 8.1.0 Oreo (M1AJQ.J701FDDU6BRI3) build description: j7veltedx-user 8.1.0 M1AJQ J701FDDU6BRI3 release-keys crypto state: encrypted? Custom moviNAND command is not supported for this device(MMC51). Detected: SAMSUNG moviNAND KMAJT000D4-RXXX/16G |
07-28-2019, 11:34 | #7 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
07-31-2019, 11:19 | #9 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Note:First Tell Me Which Box You Are Using Easy JTAG V1 OLD & V2 NEW I Have Same Problem No Connect To Every time Now Return To Customer . I Thick Problem With 1.8 / 2.8 / 3.3 But I was give 1.8/2.8 /3.3 With 100 OHM But Mobile not connect & UFI BOX Easy connect & THIS MOBILE Easy Connect With 2.8 & 3.3 Check In This Thread History Check Post No:6 Xcuse me But Also Planing Buy New Emmc Box & My Choice Of UFI Thanks & Regards By :All TECH 4 You Last edited by Yashbanswara; 07-31-2019 at 11:27. |
07-31-2019, 11:38 | #10 (permalink) | |
07-31-2019, 15:12 | #11 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | All Mobile Emmc Connect Successfully Via ISP But Only Not Connect J701F Realme 2 Successfully Connect: http://forum.gsmhosting.com/vbb/13710432-post7.html What Mean Of This Lines:EasyJTAG Plus Box (Black-White Box) not need Pull-Up resistors My Question Is :Now Must Need BUY New Easy JTAG Plus Box. Because I Return To Customer 2 Models J701f Because Not Connect Via ISP What Do I Am Thanks & Regards By:All TECH 4 You |
