ChandruChiyyan | 02-07-2019 09:54 | Samsung S7262 Dead after flash I got samsung s7262 restart problem ... while flashing mobile went to dead so i tryed to reapair after repair allso mobile dead what i did wrong ?
here is the log: Code:
Compression is ON
Z3X EasyJtag Software ver. 3.4.0.2
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 0404131EE6D0E70A, ,FW Ver.: 01.63
CMD Pullup Level:1763 mV
CMD Active Level:2402 mV
Box IO Level:3300 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 1501004E35585A4142044C31DEC28160
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 08/2014 Rev.0x4
eMMC NAME: N5XZAB , S/N: 1278336706
eMMC NAME (HEX): 4E35585A4142
IC Name: Samsung , KMN5X000ZA-B209/4GB @FBGA162
EMMC ROM1 (Main User Data) Capacity: 3728 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: N5XZAB_1278336706_20190207_1240.extcsd
Done.
extCSD file...E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\ext_csd.bin
Running:Repair extCSD...
Skip loading eMMC Addon Firmware
CLK Rate:14000 kHz
------------Parsing extCSD------------
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x03]:
implementation based on CMD12
Background operations support [BKOPS_SUPPORT: 0x01]
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
[MIN_PERF_DDR_W_8_52: 0x00]
[MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x15]
Secure Erase Multiplier [SEC_ERASE_MULT: 0x1b]
Secure TRIM Multiplier [SEC_TRIM_MULT: 0x11]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x10]
Access size [ACC_SIZE: 0x05]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x02]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x11]
Sector Count [SEC_COUNT: 0x00748000]
Minimum Write Performance for 8bit:
[MIN_PERF_W_8_52: 0x00]
[MIN_PERF_R_8_52: 0x00]
[MIN_PERF_W_8_26_4_52: 0x00]
[MIN_PERF_R_8_26_4_52: 0x00]
Minimum Write Performance for 4bit:
[MIN_PERF_W_4_26: 0x00]
[MIN_PERF_R_4_26: 0x00]
Power classes registers:
[PWR_CL_26_360: 0x00]
[PWR_CL_52_360: 0x00]
[PWR_CL_26_195: 0x00]
[PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x02]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02]
Card Type [CARD_TYPE: 0x07]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x01]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x08]
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x01
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x05
Enable background operations handshake [BKOPS_EN]: 0x00
HPI management [HPI_MGMT]: 0x00
Partitioning Support [PARTITIONING_SUPPORT]: 0x03
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0004da
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
------------Done parsing------------
Writing as extCSD 4.41
Done.
Compression is ON
CLK Rate:1000 kHz
Bus Width:1bit,SDR
Backup saved: N5XZAB_1278336706_20190207_1256.extcsd
Done.
Checking NAND Image : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot1.bin
Autodetected RAW data
File successefuly loaded!
Partition table scan:
GPT: not present
Processing file...E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot1.bin
Writing as RAW data
Input file : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot1.bin
Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done, time taken: 3 sec. Average Write Speed: 551 kB/s
Checking NAND Image : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot2.bin
GPT: not present
Processing file...E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot2.bin
Writing as RAW data
Input file : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot2.bin
Writing 0000200000 bytes to 0000000000 ...ROM3 (BOOT2 ROM)
Done, time taken: 3 sec. Average Write Speed: 557 kB/s
Checking NAND Image : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\userarea.bin
Partition info successfully found
Detected LINUX(Android) SYSTEM : 0x0010D00000 (898.0MB)
Build ID: JZO54K
Display Build ID: JZO54K.S7262JVUAML1
Release Incremental ID: S7262JVUAML1
Release Base ID: 4.1.2
Device Model: GT-S7262
Device Name: logan2gxx
Architecture ABI: armeabi-v7a
Device manufacturer: samsung
Device Platform: sc6820i
Product ID: logan2g
Build Description: logan2gxx-user 4.1.2 JZO54K S7262JVUAML1 release-keys
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB
Soft (Partitioned) Disk/Image size: 746FBB sectors 3.6 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B
First usable sector: 34
Last usable sector: 7630813
Processing file...E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\userarea.bin
Writing as RAW data
Input file : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\userarea.bin
Writing 00E9000000 bytes to 0000000000... ROM1 (USER ROM)
Done, time taken: 3541 sec. Average Write Speed: 1103 kB/s
Compression is ON
CMD Pullup Level:1753 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
Backup saved: N5XZAB_1278336706_20190207_1359.extcsd
Done.
