02-07-2019, 09:54 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: tamilnadu,india
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | Samsung S7262 Dead after flash here is the log: Code: Compression is ON Z3X EasyJtag Software ver. 3.4.0.2 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0404131EE6D0E70A, ,FW Ver.: 01.63 CMD Pullup Level:1763 mV CMD Active Level:2402 mV Box IO Level:3300 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 1501004E35585A4142044C31DEC28160 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2014 Rev.0x4 eMMC NAME: N5XZAB , S/N: 1278336706 eMMC NAME (HEX): 4E35585A4142 IC Name: Samsung , KMN5X000ZA-B209/4GB @FBGA162 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: N5XZAB_1278336706_20190207_1240.extcsd Done. extCSD file...E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\ext_csd.bin Running:Repair extCSD... Z3X EasyJtag Software ver. 3.4.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1763 mV CMD Active Level:2402 mV Box IO Level:3300 mV CLK Rate:14000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x03]: implementation based on CMD12 Background operations support [BKOPS_SUPPORT: 0x01] Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x1b] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x11] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x05] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x02] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x00748000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x02] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x01] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x08] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0004da Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 ------------Done parsing------------ Writing as extCSD 4.41 Done. Compression is ON Z3X EasyJtag Software ver. 3.4.0.2 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0404131EE6D0E70A, ,FW Ver.: 01.63 CMD Pullup Level:1763 mV CMD Active Level:2402 mV Box IO Level:3300 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 1501004E35585A4142044C31DEC28160 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2014 Rev.0x4 eMMC NAME: N5XZAB , S/N: 1278336706 eMMC NAME (HEX): 4E35585A4142 IC Name: Samsung , KMN5X000ZA-B209/4GB @FBGA162 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: N5XZAB_1278336706_20190207_1256.extcsd Done. Checking NAND Image : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot1.bin Autodetected RAW data File successefuly loaded! Partition table scan: GPT: not present Processing file...E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot1.bin Writing as RAW data Z3X EasyJtag Software ver. 3.4.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1763 mV CMD Active Level:2402 mV Input file : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot1.bin Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done, time taken: 3 sec. Average Write Speed: 551 kB/s Checking NAND Image : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot2.bin Autodetected RAW data File successefuly loaded! Partition table scan: GPT: not present Processing file...E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot2.bin Writing as RAW data Z3X EasyJtag Software ver. 3.4.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1763 mV CMD Active Level:2402 mV Input file : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\boot2.bin Writing 0000200000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Done, time taken: 3 sec. Average Write Speed: 557 kB/s Checking NAND Image : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\userarea.bin Autodetected RAW data Partition info successfully found Detected LINUX(Android) SYSTEM : 0x0010D00000 (898.0MB) Build ID: JZO54K Display Build ID: JZO54K.S7262JVUAML1 Release Incremental ID: S7262JVUAML1 Release Base ID: 4.1.2 Device Model: GT-S7262 Device Name: logan2gxx Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: sc6820i Product ID: logan2g Build Description: logan2gxx-user 4.1.2 JZO54K S7262JVUAML1 release-keys File successefuly loaded! Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB Soft (Partitioned) Disk/Image size: 746FBB sectors 3.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 7630813 Processing file...E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\userarea.bin Writing as RAW data Z3X EasyJtag Software ver. 3.4.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:1763 mV CMD Active Level:2402 mV Input file : E:\Easy Jtag\Dump's\GT-S7262-JZO54K.S7262DXUANG3\userarea.bin Writing 00E9000000 bytes to 0000000000... ROM1 (USER ROM) Done, time taken: 3541 sec. Average Write Speed: 1103 kB/s Compression is ON Z3X EasyJtag Software ver. 3.4.0.2 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0404131EE6D0E70A, ,FW Ver.: 01.63 CMD Pullup Level:1753 mV CMD Active Level:2402 mV Box IO Level:3300 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 1501004E35585A4142044C31DEC28160 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2014 Rev.0x4 eMMC NAME: N5XZAB , S/N: 1278336706 eMMC NAME (HEX): 4E35585A4142 IC Name: Samsung , KMN5X000ZA-B209/4GB @FBGA162 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: N5XZAB_1278336706_20190207_1359.extcsd Done. Last edited by ChandruChiyyan; 02-07-2019 at 09:59. |
02-08-2019, 20:32 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
2) Try to set write verify for ROM1 3) try another Dump file or write original firmware by vendor - Samsung | |
