02-09-2017, 13:31 | #1 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2213928 Status: Offline Thanks Meter: 440 | Samsung sm- g355h emmc repier step by step 2 emmc firmware update 3: MoviNAND Factory Reset... 4 MoviNAND Reset + Format... 4 repiar extCSD file 5 write dump file ROM1 ROM2 MAIN USER DATA CSD Z3X EasyJtag Software ver. 2.0.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0201001B9BA01510, ,FW Ver.: 01.52 CMD Pullup Level:2062 mV CMD Active Level:2681 mV eMMC Device Information EMMC CID : 1501004B3558594D42038027DEC58186 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2014 Rev.0x3 EMMC NAME: K5XYMB , S/N: XXXXXXXX EMMC NAME (HEX): 4B3558594D4200 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. Backup saved: K5XYMB_2150096581_20150400_0009.extcsd Searching for partition tables... Detected GPT over MBR... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (FIXNV1) Range: [0X400000,0X7BFE00] ,Len: 3C0000 MMCBLK0P1 (FIXNV2) Range: [0X7C0000,0XB7FE00] ,Len: 3C0000 MMCBLK0P2 (SBL1) Range: [0XB80000,0XD7FE00] ,Len: 200000 MMCBLK0P3 (SBL2) Range: [0XD80000,0XF7FE00] ,Len: 200000 MMCBLK0P4 (WDSP) Range: [0XF80000,0X147FE00] ,Len: 500000 MMCBLK0P5 (WDSP_BACKUP) Range: [0X1480000,0X197FE00] ,Len: 500000 MMCBLK0P6 (MODEM) Range: [0X1980000,0X237FE00] ,Len: A00000 MMCBLK0P7 (MODEM_BACKUP) Range: [0X2380000,0X2D7FE00] ,Len: A00000 MMCBLK0P8 (FOTA_SIG) Range: [0X2D80000,0X2DBFE00] ,Len: 40000 MMCBLK0P9 (OTA) Range: [0X2DC0000,0X35BFE00] ,Len: 800000 MMCBLK0P10 (RUNTIMENV1) Range: [0X35C0000,0X397FE00] ,Len: 3C0000 MMCBLK0P11 (RUNTIMENV2) Range: [0X3980000,0X3D3FE00] ,Len: 3C0000 MMCBLK0P12 (PARAM) Range: [0X3D40000,0X3FFFE00] ,Len: 2C0000 MMCBLK0P13 (EFS) Range: [0X4240000,0X563FE00] ,Len: 1400000 MMCBLK0P14 (PRODNV) Range: [0X5640000,0X5B3FE00] ,Len: 500000 MMCBLK0P15 (ODIN_RESERVED) Range: [0X5B40000,0X5B7FE00] ,Len: 40000 MMCBLK0P16 (KERNEL) Range: [0X5B80000,0X6A7FE00] ,Len: F00000 MMCBLK0P17 (RECOVERY) Range: [0X6A80000,0X797FE00] ,Len: F00000 MMCBLK0P18 (CSC) Range: [0X7980000,0XF17FE00] ,Len: 7800000 MMCBLK0P19 (SYSTEM) Range: [0XF180000,0X5657FE00] ,Len: 47400000 MMCBLK0P20 (HIDDEN) Range: [0X56580000,0X5837FE00] ,Len: 1E00000 MMCBLK0P21 (USERDATA) Range: [0X58380000,0XE837FE00] ,Len: 90000000 Done...Presets has been updated... FOR V1 BORD HERE DUMP PINOUT TESTED https://drive.google.com/file/d/0BwQ...ew?usp=sharing |
The Following 11 Users Say Thank You to yuvraj9x2 For This Useful Post: |
02-20-2017, 01:01 | #3 (permalink) |
No Life Poster Join Date: Dec 2014 Location: u.a.e
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | why this phone can't repair from pinout you need to remove emmc box can't detect emmc i try 4 pc and same problem أرسلت من SM-G900F بإستخدام تاباتلك |
02-20-2017, 19:43 | #4 (permalink) | |
Member: 2213928 Status: Offline Thanks Meter: 440 | Quote:
https://drive.google.com/file/d/0BwQ...ew?usp=sharing | |
05-15-2018, 04:31 | #7 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Negros, Philippines
Member: 525940 Status: Offline Thanks Meter: 213 | Quote:
