Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851
Sonork: 100.1680491 Thanks Meter: 2,363 | samsung sm-g530h repair done but phone still dead samsung sm-g530h repair done but phone still dead
[IMG] [/IMG] Quote:
eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 2022
EasyJTAG Box Serial = 0900301095CE53A5
Card Serial = AAAA-6B50
EasyJTAG Box Firmware = 1.62
Changelog:
12.12.2017 (ver 1.4.9.0)
Fix: Bugs that have been found through your crash report
Fix: RandomVerify function
Fix: Creation of GPT for Samsung (write by vendor)
Fix: Failed to mount large Fat partitions (explorer)
Fix: Extraction from contact2.db (explorer)
Fix: Error in the "build.prop" parser
Fix: CID Parser
Add: Support for EasyJtag Plus Box
Add: Path for TempDir and InitialDir (option in settings)
Add: Unpack Lenovo QSB (utilities)
Add: Selecting a PIT file from CSC (write by vendor Samsung)
Add: Detect for encrypted dumps from GPG Box
Add: Detect for FullDiskEncryption Partition (explorer)
Add: LinearVerify of the Partition (read by vendor)
Add: Information base about emmc compatibility (thanks to phonemicrodb)
Add: Resizing the window (for small screen resolutions)
Add: Converting large partitions in SparseImage when reading by vendor (option in settings)
Add: Mounting SparseImage (explorer)
Add: Automatic backup of the EFS partition for Samsung (read by vendor)
Add: Formatting of EFS partition for Samsung on request (write by vendor)
Setting frequence to 14 Mhz
CMD Pullup Level: 3124 mV
CMD Active Level: 3238 mV
EMMC Device Information :
EMMC CID: 150100514E5730304D0096EAE0AFB132
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture Name: SAMSUNG , EMMC NAME: QNW00M , EMMC NAME (HEX): 514E5730304D , S/N: 96EAE0AF , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 11/2014
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QNW00M_96EAE0AF_20180503_173337.extcsd
EMMC Init completed.
Opening file: SM-G530H_4-3-2018_14-26-45.pit
Pit: SM-G530H_4-3-2018_14-26-45.pit
Entry count: 31
The size of the last section has been updated
BL_G530HDCS1AQB1_CL301731_QB12468293_REV00_user_lo w_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
aboot.mbn
sbl1.mbn
rpm.mbn
tz.mbn
hyp.mbn
non-hlos.bin
sec.dat
CMD Pullup Level: 3135 mV
CMD Active Level: 3227 mV
Backup saved: QNW00M_96EAE0AF_20180503_173352.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: non-hlos.bin
Unpacking file: sbl1.mbn
Unpacking file: aboot.mbn
Unpacking file: rpm.mbn
Unpacking file: tz.mbn
Unpacking file: hyp.mbn
Unpacking file: sec.dat
Partition name: APNHLOS
Filename: non-hlos.bin , Offset: 000000400000 , filesize: 8587008 bytes
eMMC switching to ROM1
Erasing partition...
Writing partition...
Done writing partition. Write speed: 497.67 KB/s
Partition name: SBL1
Filename: sbl1.mbn , Offset: 000004C70000 , filesize: 288216 bytes
Done writing partition. Write speed: 463.58 KB/s
Partition name: ABOOT
Filename: aboot.mbn , Offset: 000004CF8000 , filesize: 1045356 bytes
Done writing partition. Write speed: 486.01 KB/s
Partition name: RPM
Filename: rpm.mbn , Offset: 000004EF8000 , filesize: 182012 bytes
Done writing partition. Write speed: 467.99 KB/s
Partition name: QSEE
Filename: tz.mbn , Offset: 000004F78000 , filesize: 413680 bytes
Done writing partition. Write speed: 461.62 KB/s
Partition name: QHEE
Filename: hyp.mbn , Offset: 000004FF8000 , filesize: 53112 bytes
Done writing partition. Write speed: 305.01 KB/s
Partition name: SEC
Filename: sec.dat , Offset: 000005378000 , filesize: 684 bytes
Done writing partition. Write speed: 13.61 KB/s
All done time: [00:00:30:696]
how to solve it sir
please help me sir |
