12-26-2017, 08:39 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | samsung sm-g7102 Can't init device, Reason: OCR Ready Timeout Err Z3X EasyJtag Software ver. 2.9.0.0 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 0500D01E3BC5A469, ,FW Ver.: 01.62 CMD Pullup Level:1732 mV CMD Active Level:11830 mV Box IO Level:1850 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. |
01-03-2018, 15:43 | #6 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: gsmworld
Member: 757297 Status: Offline Thanks Meter: 36 | Quote:
01-12-2018, 03:01 | #13 (permalink) |
Freak Poster Join Date: May 2005 Location: hanoi.vietnam
Member: 142949 Status: Offline Thanks Meter: 71 | good log, good enough voltage adapter after fix adapter CMD Pullup Level: 2897 mV CMD Active Level: 2805 mV I think isp to fix boot ... safe and faster Feeling the current software may not be good for isp because there is not much time to test Last edited by nguyenhuu; 01-12-2018 at 03:07. |
01-12-2018, 08:18 | #15 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | sm-g7102/sm-g7105 that mobile need usb supply or charger dont connect vcc and vccq |
The Following User Says Thank You to Sniper_04 For This Useful Post: |
