Old 07-19-2018, 15:40   #1 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Samsung SM-J106F eMMC Repair Successfully But Mobile Still Dead ( Help Me )
Hello Everyone Some Days Ago In My Shop Come With Dead Condition than do boot repair Samsung SM-J106F eMMC Repair Successfully But Mobile Still Dead ( Help Me )
Please Help Me
Thanks & Regards By:
All TECH 4 You
Old 07-19-2018, 16:14   #2 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
post logs not picture that are small
Old 07-20-2018, 07:20   #3 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Here Full LOG Via "DETECT" From Easy JTAG Clssic 3.0.0.0
Compression is ON
Z3X EasyJtag Software ver. 3.0.0.0
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: 0B0170135E37F259, ,FW Ver.: 01.63
CMD Pullup Level:1701 mV
CMD Active Level:1742 mV
Box IO Level:1800 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 90014A4838473474920129C118F5B3AA
eMMC CSD : D02701320F5903FFFFFFFFE78A40002A
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 11/2016  Rev.0x1
eMMC NAME: H8G4t  , S/N:  700520693
eMMC NAME (HEX): 483847347420
EMMC ROM1 (Main User Data)   Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G4t _ 700520693_20180720_1145.extcsd
Partition table scan:
 GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB
Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB
Logical sector size: 0x200  bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 15269854
Found Data areas (firmware parts) count is: 28
Partition info successfully found
P0 (SBOOT) [0x400000 0x200000] Size: 2.0MB
P1 (SBOOT2) [0x600000 0x200000] Size: 2.0MB
P2 (L_FIXNV1) [0x800000 0x100000] Size: 1.0MB
P3 (L_FIXNV2) [0x900000 0x100000] Size: 1.0MB
P4 (PM_SYS) [0xa00000 0x100000] Size: 1.0MB
P5 (RSVDFIXNV1) [0xb00000 0x100000] Size: 1.0MB
P6 (L_LDSP) [0xc00000 0x400000] Size: 4.0MB
P7 (L_MODEM) [0x1000000 0x1000000] Size: 16.0MB
P8 (L_GDSP) [0x2000000 0x400000] Size: 4.0MB
P9 (L_WARM) [0x2400000 0x400000] Size: 4.0MB
P10 (FOTA_SIG) [0x2800000 0x100000] Size: 1.0MB
P11 (L_RUNTIMENV1) [0x2900000 0x100000] Size: 1.0MB
P12 (L_RUNTIMENV2) [0x2a00000 0x100000] Size: 1.0MB
P13 (TD_RUNTIMENV1) [0x2b00000 0x100000] Size: 1.0MB
P14 (TD_RUNTIMENV2) [0x2c00000 0x100000] Size: 1.0MB
P15 (PARAM) [0x2d00000 0x200000] Size: 2.0MB
P16 (EFS) [0x2f00000 0x1400000] Size: 20.0MB
P17 (PRODNV) [0x4300000 0x500000] Size: 5.0MB
P18 (RESERVED2) [0x4800000 0x580000] Size: 5.500MB
P19 (KERNEL) [0x4d80000 0x1400000] Size: 20.0MB
P20 (RECOVERY) [0x6180000 0x1400000] Size: 20.0MB
P21 (PERSISTENT) [0x7580000 0x80000] Size: 512.0KB
P22 (PERSDATA) [0x7600000 0x900000] Size: 9.0MB
P23 (STEADY) [0x7f00000 0x100000] Size: 1.0MB
P24 (CACHE) [0x8000000 0xc800000] Size: 200.0MB
P25 (SYSTEM) [0x14800000 0xad000000] Size: 2.703GB
P26 (HIDDEN) [0xc1800000 0x2800000] Size: 40.0MB
P27 (USERDATA) [0xc4000000 0x10dffbe00] Size: 4.217GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0014800000 (2.703GB)
Build ID:  MMB29Q
Display Build ID:  MMB29Q.J106FJVS0ARF1
Release ID:  6.0.1
Device Model:  SM-J106F
Device Name:  j1miniveltejv
Architecture ABI:  armeabi-v7a
Device manufacturer:  samsung
Device Platform:  sc8830
Product ID:  j1minivelte
Build Description:  j1miniveltejv-user 6.0.1 MMB29Q J106FJVS0ARF1 release-keys
Samsung CPU:  SC9830I
Done.
Please Solve My Problem
All TECH 4 You
Old 07-20-2018, 08:31   #4 (permalink)
Elgendi's Avatar
Member: 2821459
Thanks Meter: 806
U Not Need All Flash Setup U Need Only Pit And Least BL From Firmware,,After That Hope U PHone Open U CAn Do Full Flash With 4file Rom.
Old 07-20-2018, 08:53   #5 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Sir First I Was Flash Pit & Latest BL File But Mobile Still Dead So Finally I Flash Full Firmware But Mobile Still So Please Help Me
Old 07-20-2018, 08:56   #6 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
change emmc damage-----------
Old 07-20-2018, 09:02   #7 (permalink)
Member: 2846254
What is your emmc model? If you have Samsung, you should burn the dump, otherwise you should change emmc.
Old 07-20-2018, 09:23   #8 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
SKhynix H9TQ64A8GTAC UAKUM 647A
If You Have Working Dump Please Upload
Old 07-20-2018, 11:38   #9 (permalink)
Member: 2846254
If you do not have a dummy file, you can burn the Flash file with Easy-Jtag Plus if you have a bird error, you should change the EMMC.
Old 07-20-2018, 12:33   #10 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
What Mean Of burn the Flash file with Easy-Jtag Plus Please Tell Me
Old 07-20-2018, 13:28   #11 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
just use latest version of firmware at sammobile site, use firmware that suite your phone region
Old 07-20-2018, 14:18   #12 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
I Do Already Write Latest Firmware :
Model :SM-J106F
Model name :Galaxy J1 mini Prime
Country :United Arab Emirates
Version :Android 6.0.1
Build date :14 Jun 2018
Security Patch Level :2018-06-01
Product code :XSG
PDA :J106FJVS0ARF1
CSC :J106FOJV0ARF1
But Problem Still Same So Please Solve My Problem
Old 07-20-2018, 15:14   #13 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
did you try KSA J106FJVS0ARF2
Old 07-22-2018, 07:12   #14 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
I Write This Firmware Mobile Still Dead
First I Write PIT+BL File Mobile Not On After Full File Write With Pit File But Also Mobile Still Dead
LOG Via Easy JTAG Classic:
Compression is ON
Loading eMMC GEN1 Firmware... IO: 2800 mV
CMD Pullup Level:2000 mV
CMD Active Level:2495 mV
Box IO Level:2800 mV
CLK Rate:7000 kHz
Bus Width:1bit,SDR
Backup saved: H8G4t _ 700520693_20180722_1139.extcsd
 GPT: present
Build ID:  MMB29Q
Display Build ID:  MMB29Q.J106FJVS0ARF2
Release ID:  6.0.1
Build Description:  j1miniveltejv-user 6.0.1 MMB29Q J106FJVS0ARF2 release-keys
Done.
LOG Via Easy JTAG PLUS:
Setting frequence to 14 Mhz
CMD Pullup Level: 1691 mV
CMD Active Level: 1753 mV
EMMC Device Information :
EMMC CID: 90014A4838473474920129C118F5B3AA
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4t , HEX: 483847347400 , S/N: 29C118F5 , rev. 0x01
   EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Backup saved: H8G4t_29C118F5_20180722_114044.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: sboot, [000000400000 - 000000600000], size: 000000200000 (2.00 MB)
Partition: sboot2, [000000600000 - 000000800000], size: 000000200000 (2.00 MB)
Partition: l_fixnv1, [000000800000 - 000000900000], size: 000000100000 (1.00 MB)
Partition: l_fixnv2, [000000900000 - 000000A00000], size: 000000100000 (1.00 MB)
Partition: pm_sys, [000000A00000 - 000000B00000], size: 000000100000 (1.00 MB)
Partition: rsvdfixnv1, [000000B00000 - 000000C00000], size: 000000100000 (1.00 MB)
Partition: l_ldsp, [000000C00000 - 000001000000], size: 000000400000 (4.00 MB)
Partition: l_modem, [000001000000 - 000002000000], size: 000001000000 (16.0 MB)
Partition: l_gdsp, [000002000000 - 000002400000], size: 000000400000 (4.00 MB)
Partition: l_warm, [000002400000 - 000002800000], size: 000000400000 (4.00 MB)
Partition: fota_sig, [000002800000 - 000002900000], size: 000000100000 (1.00 MB)
Partition: l_runtimenv1, [000002900000 - 000002A00000], size: 000000100000 (1.00 MB)
Partition: l_runtimenv2, [000002A00000 - 000002B00000], size: 000000100000 (1.00 MB)
Partition: td_runtimenv1, [000002B00000 - 000002C00000], size: 000000100000 (1.00 MB)
Partition: td_runtimenv2, [000002C00000 - 000002D00000], size: 000000100000 (1.00 MB)
Partition: param, [000002D00000 - 000002F00000], size: 000000200000 (2.00 MB)
Partition: efs, [000002F00000 - 000004300000], size: 000001400000 (20.0 MB)
Partition: prodnv, [000004300000 - 000004800000], size: 000000500000 (5.00 MB)
Partition: reserved2, [000004800000 - 000004D80000], size: 000000580000 (5.50 MB)
Partition: kernel, [000004D80000 - 000006180000], size: 000001400000 (20.0 MB)
Partition: recovery, [000006180000 - 000007580000], size: 000001400000 (20.0 MB)
Partition: persistent, [000007580000 - 000007600000], size: 000000080000 (512. KB)
Partition: persdata, [000007600000 - 000007F00000], size: 000000900000 (9.00 MB)
Partition: steady, [000007F00000 - 000008000000], size: 000000100000 (1.00 MB)
Partition: cache, [000008000000 - 000014800000], size: 00000C800000 (200. MB)
Partition: system, [000014800000 - 0000C1800000], size: 0000AD000000 (2.70 GB)
Partition: hidden, [0000C1800000 - 0000C4000000], size: 000002800000 (40.0 MB)
Partition: userdata, [0000C4000000 - 0001D1FFBE00], size: 00010DFFBE00 (4.22 GB)
GPT header successfully parsed
Get firmware version
Brand = samsung
Manufacturer = samsung
Model = SM-J106F
Phone platform = sc8830
CPU Abi = armeabi-v7a
Android release = 6.0.1
Firmware version = MMB29Q.J106FJVS0ARF2
Firmware date = Mon Jun 18 19:59:59 KST 2018
Note:If MR.Blang You Are Listen This Thread Please Help Me
All TECH 4 You
The Following 2 Users Say Thank You to Yashbanswara For This Useful Post:
Old 07-22-2018, 08:25   #15 (permalink)
omairlee01's Avatar
Member: 2068959
Thanks Meter: 252
Compression is ON
CLK Rate:7000 kHz
Bus Width:1bit,SDR
 GPT: present
Build ID:  MMB29Q
Release ID:  6.0.1
Done.
Brand = samsung
Model = SM-J106F
All TECH 4 You
u try full erase factory reset eMMC Then WRite Boot 1 boot2 Ext_csd Then Write Tested DUMP FILE From Support
Page generated in 0.25912 seconds with 8 queries
