12-29-2018, 07:59 | #4 (permalink) |
Freak Poster Join Date: Aug 2014 Location: France Age: 34
Member: 2235775 Status: Offline Thanks Meter: 351 | contact me. i huave 1 after flash was dead https://www.facebook......com/akhtar.tfm |
12-31-2018, 11:37 | #5 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | h872 in qualcom 9008 Found 1 serial devices COM71 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM71) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Please select a communication interface... Found 2 devices COM71 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM71) COM23 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM23) QC Core Version 2.10 Using Port :COM23 Detecting Device mode... Connecting to device without external programmers... Device Class:sahara Device Protocol:firehose Emergency Mode:true Reading QC Device information... SerialNumber: 0xBF9F98CD MSM_HW_ID: 0x0005F0E1 OEM_PK_HASH: 0x2CF7619A278D26073F7EEA79BB7F4B7949C221487FEA058E A072CFFE38CE1496 SBL SW Version: 0x00000000 You must select loader to get access to EDL functions Operation status: 0 Success |
01-01-2019, 13:50 | #9 (permalink) | |
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | Quote:
logs: The same loader already in base with name "prog_ufs_firehose_8996_lge" QC Core Version 2.10 Using Port :COM23 Detecting Device mode... Using EDL Programmer :C:\Program Files\Z3X\EASYJTAG\Loaders\prog_ufs_firehose_8996_ ddr.elf Sahara Connectting To Device Sahara Downloading flash programmer: C:\Program Files\Z3X\EASYJTAG\Loaders\prog_ufs_firehose_8996_ ddr.elf Flash programmer failed to load! Operation status: -19 Unknown error (-19) this is deferent in the logs in ufi that mr love edition had..that's why I connot connect..i used..qcfire medusa and z3x easy jtag.. and im planning to connect tru ufs chip it self that's why I created this thread.. http://forum.gsmhosting.com/vbb/f672...orted-2539700/ Last edited by simpleprince49; 01-01-2019 at 13:58. | |
01-01-2019, 14:05 | #10 (permalink) |
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | logs in qcfire Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM23) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1F00500 [8996] 6F023100 OPK_DATA : 7C7CA65B193D8639CD1237A2AA4CB023AFAE64668B7D81759A 5A64905F15E307 Initializing Protocol...OK Sending Loader [prog_ufs_firehose_8996_ddr_zuk.elf]...Error Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 3.2 |
