01-05-2017, 21:56 | #1 (permalink) |
Crazy Poster Join Date: Dec 2006
Member: 417115 Status: Offline Thanks Meter: 0 | Samsung SM-J200H/DS eMMC Repair i already connect tp and i have J200H/DS Pit files i need Dump file and i want to repair my j200 I want to help please _______________________________ Z3X EasyJtag Software ver. 2.5.0.3 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 01FFE01784328975, ,FW Ver.: 01.56 CMD Pullup Level:2083 mV CMD Active Level:2908 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48384734742101238690FB2300 EMMC CSD : D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2016 Rev.0x1 EMMC NAME: H8G4t , S/N: 596021499 EMMC NAME (HEX): 48384734742000 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G4t _ 596021499_20170105_2246.extcsd Searching for partition tables... Partitioning not detected... Done. |
01-08-2017, 17:53 | #12 (permalink) |
Freak Poster Join Date: Aug 2010 Age: 38
Member: 1382268 Status: Offline Thanks Meter: 71 | Take IT Bro this is the dump file i have read but i should tel you this dump file i have read with Easy Jtag ADB Dumper from working phone and i used 2 free software instead easy Jtag for reading adb dump so if want those i can upload those too By EasyJTAG |
The Following User Says Thank You to aidin01 For This Useful Post: |
01-08-2017, 18:44 | #13 (permalink) | |
Member: 417115 Status: Offline Thanks Meter: 0 | Quote:
Thank you, my brother will try | |
01-08-2017, 23:01 | #15 (permalink) |
Member: 1382268 Status: Offline Thanks Meter: 71 | Do this First write this dump after that write latest bootloader on it anf after that phone should turn on and go to download mode and flash with latest firmware from sammobilee or any rom server |
