08-14-2017, 14:11 | #1 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | SAMSUNG SM-Z130H Dead Boot Repair Done By Easy Jtag ! Frequence: 21 Mhz CMD Pullup Level: 1732 mV CMD Active Level: 1794 mV EMMC Device Information : EMMC CID: 150100464A32374D4200D28B97A2134C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 1/2016 , Rev: 00 EMMC NAME: FJ27MB , S/N: D28B97A2 , rev. 00 EMMC NAME (HEX): 464A32374D42 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: FJ27MB_D28B97A2_20170814_181139.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: spl.img Unpacking file: nvitem.bin Unpacking file: sboot.bin Unpacking file: dzimage Unpacking file: dzimage-recovery Unpacking file: ramdisk-recovery.img Unpacking file: sprdcp.img Unpacking file: sprddsp.img Unpacking file: csc.img Unpacking file: rootfs.img Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 41984 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 352.68 Kb/s Partition name: FIXNV2 Filename: nvitem.bin , Offset: 000000600000 , filesize: 177440 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 554.77 Kb/s Partition name: SBOOT Filename: sboot.bin , Offset: 000002200000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1136.01 Kb/s Partition name: KERNEL Filename: dzimage , Offset: 000002C00000 , filesize: 5368832 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 908.12 Kb/s Partition name: RECOVERY Filename: dzimage-recovery , Offset: 000003400000 , filesize: 5368832 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 911.87 Kb/s Partition name: RAMDISK Filename: ramdisk-recovery.img , Offset: 000003C00000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 861.68 Kb/s Partition name: MODEM Filename: sprdcp.img , Offset: 000004400000 , filesize: 7483452 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 932.63 Kb/s Partition name: DSP Filename: sprddsp.img , Offset: 000004C00000 , filesize: 1967104 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1200.64 Kb/s Partition name: CSC Filename: csc.img , Offset: 000005200000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1028.26 Kb/s Partition name: ROOTFS Filename: rootfs.img , Offset: 0000B0600000 , filesize: 827199488 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 885.80 Kb/s All done |
The Following User Says Thank You to Pijush Das For This Useful Post: |
