09-23-2019, 16:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: GSM WORLD
Member: 263277 Status: Offline Thanks Meter: 142 | Samsung t285 mdm block 1 Setting frequence to 21 MHz CMD Pullup Level: 2062 mV CMD Active Level: 2743 mV EMMC Device Information : EMMC CID: 1501003847544634520080AEE850461C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 80AEE850 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 8GTF4R_80AEE850_20190923_195923.extcsd EMMC Init completed. |
09-23-2019, 16:37 | #2 (permalink) |
Member: 263277 Status: Offline Thanks Meter: 142 | eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 10 (64 bit) build 17763 (10.0.17763.719) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 0CFFE0212174A39E Card Serial = FEFE8E9D EasyJTAG Box Firmware = 1.63 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting frequence to 21 MHz CMD Pullup Level: 2660 mV CMD Active Level: 2763 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 21 MHz CMD Pullup Level: 2062 mV CMD Active Level: 2753 mV EMMC Device Information : EMMC CID: 1501003847544634520080AEE850461C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 80AEE850 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 8GTF4R_80AEE850_20190923_195517.extcsd EMMC Init completed. Scanning soft partitions Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #2 Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #3 Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #4 Error reading at address: 000000040000 , error: -2, CMD CRC Error ... Retry #5 Too many errors. Reading has been stopped HiPower mode is ON HiPower mode is ON Setting frequence to 1 MHz CMD Pullup Level: 1845 mV CMD Active Level: 1959 mV Can't init device. Reason: CMD Timeout Error Error: Previous operation is not finished yet. Setting frequence to 21 MHz CMD Pullup Level: 1856 mV CMD Active Level: 1959 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 21 MHz CMD Pullup Level: 2052 mV CMD Active Level: 2732 mV EMMC Device Information : EMMC CID: 1501003847544634520080AEE850461C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 80AEE850 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 8GTF4R_80AEE850_20190923_195717.extcsd EMMC Init completed. Get firmware version Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #2 Error reading at address: 000000080000 , error: -1, CMD Timeout Error ... Retry #1 Entry count: 31 Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000080000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000080000 , error: -2, CMD CRC Error ... Retry #2 Entry count: 31 Too many errors. Enabling ResetBox mode Firmware info not found Setting frequence to 21 MHz CMD Pullup Level: 2072 mV CMD Active Level: 2722 mV EMMC Device Information : EMMC CID: 1501003847544634520080AEE850461C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 80AEE850 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 8GTF4R_80AEE850_20190923_195805.extcsd EMMC Init completed. Setting frequence to 21 MHz CMD Pullup Level: 2072 mV CMD Active Level: 2743 mV EMMC Device Information : EMMC CID: 1501003847544634520080AEE850461C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 80AEE850 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 8GTF4R_80AEE850_20190923_195840.extcsd EMMC Init completed. Opening file: GTEXSLTE_EUR_OPEN.pit Pit: GTEXSLTE_EUR_OPEN.pit Entry count: 31 The size of the last section has been updated BL_T285DDU0ARL1_CL14945180_QB20969384_REV02_user_l ow_ship.tar.md5 The list of files in the firmware: spl.img sboot.bin sboot2.bin param.lfs AP_T285DDU0ARL1_CL14945180_QB20969384_REV02_user_l ow_ship.tar.md5 The list of files in the firmware: boot.img recovery.img system.img CP_T285DDU0ARL1_CL967227_QB11379550_REV00.tar.md5 The list of files in the firmware: sprdcp.img sprdgdsp.img sprdltedsp.img sprdwdsp.img pm_sharkl_arm7.bin nvitem.bin CSC_ODI_T285ODI0ARL1_CL14945180_QB20971973_REV02_u ser_low_ship.tar.md5 The list of files in the firmware: gtexslte_eur_open.pit cache.img hidden.img Setting frequence to 21 MHz CMD Pullup Level: 2062 mV CMD Active Level: 2743 mV EMMC Device Information : EMMC CID: 1501003847544634520080AEE850461C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 80AEE850 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 8GTF4R_80AEE850_20190923_195923.extcsd EMMC Init completed. Setting frequence to 21 MHz CMD Pullup Level: 2072 mV CMD Active Level: 2743 mV EMMC Device Information : EMMC CID: 1501003847544634520080AEE850461C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 80AEE850 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 8GTF4R_80AEE850_20190923_195932.extcsd EMMC Init completed. Scanning soft partitions Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #2 Error reading at address: 000000040000 , error: -2, CMD CRC Error ... Retry #3 Error reading at address: 000000040000 , error: -2, CMD CRC Error ... Retry #4 Error reading at address: 000000080000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000080000 , error: -1, CMD Timeout Error ... Retry #2 Error reading at address: 000000080000 , error: -2, CMD CRC Error ... Retry #3 Entry count: 31 Partition: BOOT, [000000000000 - 000000080000], size: 000000080000 Partition: BOOT2, [000000000000 - 000000100000], size: 000000100000 Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 Partition: l_fixnv1, [000000800000 - 000000900000], size: 000000100000 Partition: l_fixnv2, [000000900000 - 000000A00000], size: 000000100000 Partition: pm_sys, [000000A00000 - 000000B00000], size: 000000100000 Partition: rsvdfixnv1, [000000B00000 - 000000C00000], size: 000000100000 Partition: l_ldsp, [000000C00000 - 000001000000], size: 000000400000 Partition: l_modem, [000001000000 - 000002000000], size: 000001000000 Partition: l_gdsp, [000002000000 - 000002400000], size: 000000400000 Partition: l_warm, [000002400000 - 000002800000], size: 000000400000 Partition: FOTA_SIG, [000002800000 - 000002900000], size: 000000100000 Partition: l_runtimenv1, [000002900000 - 000002A00000], size: 000000100000 Partition: l_runtimenv2, [000002A00000 - 000002B00000], size: 000000100000 Partition: td_runtimenv1, [000002B00000 - 000002C00000], size: 000000100000 Partition: td_runtimenv2, [000002C00000 - 000002D00000], size: 000000100000 Partition: PARAM, [000002D00000 - 000002F00000], size: 000000200000 Partition: efs, [000002F00000 - 000004300000], size: 000001400000 Partition: prodnv, [000004300000 - 000004800000], size: 000000500000 Partition: RESERVED2, [000004800000 - 000004E00000], size: 000000600000 Partition: KERNEL, [000004E00000 - 000005E00000], size: 000001000000 Partition: RECOVERY, [000005E00000 - 000006E00000], size: 000001000000 Partition: PERSISTENT, [000006E00000 - 000006F00000], size: 000000100000 Partition: PERSDATA, [000006F00000 - 000007800000], size: 000000900000 Partition: CACHE, [000007800000 - 000014000000], size: 00000C800000 Partition: SYSTEM, [000014000000 - 000094000000], size: 000080000000 Partition: HIDDEN, [000094000000 - 000096800000], size: 000002800000 Partition: userdata, [000096800000 - 0001D2000000], size: 00013B800000 Setting frequence to 21 MHz CMD Pullup Level: 2041 mV CMD Active Level: 2382 mV EMMC Device Information : EMMC CID: 1501003847544634520080AEE850461C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 80AEE850 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 8GTF4R_80AEE850_20190923_203442.extcsd EMMC Init completed. Scanning soft partitions Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #2 Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #3 Error reading at address: 000000040000 , error: -1, CMD Timeout Error ... Retry #4 Error reading at address: 000000080000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000080000 , error: -2, CMD CRC Error ... Retry #1 Error reading at address: 000000080000 , error: -1, CMD Timeout Error ... Retry #2 Entry count: 31 Partition: BOOT, [000000000000 - 000000080000], size: 000000080000 Partition: BOOT2, [000000000000 - 000000100000], size: 000000100000 Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 Partition: l_fixnv1, [000000800000 - 000000900000], size: 000000100000 Partition: l_fixnv2, [000000900000 - 000000A00000], size: 000000100000 Partition: pm_sys, [000000A00000 - 000000B00000], size: 000000100000 Partition: rsvdfixnv1, [000000B00000 - 000000C00000], size: 000000100000 Partition: l_ldsp, [000000C00000 - 000001000000], size: 000000400000 Partition: l_modem, [000001000000 - 000002000000], size: 000001000000 Partition: l_gdsp, [000002000000 - 000002400000], size: 000000400000 Partition: l_warm, [000002400000 - 000002800000], size: 000000400000 Partition: FOTA_SIG, [000002800000 - 000002900000], size: 000000100000 Partition: l_runtimenv1, [000002900000 - 000002A00000], size: 000000100000 Partition: l_runtimenv2, [000002A00000 - 000002B00000], size: 000000100000 Partition: td_runtimenv1, [000002B00000 - 000002C00000], size: 000000100000 Partition: td_runtimenv2, [000002C00000 - 000002D00000], size: 000000100000 Partition: PARAM, [000002D00000 - 000002F00000], size: 000000200000 Partition: efs, [000002F00000 - 000004300000], size: 000001400000 Partition: prodnv, [000004300000 - 000004800000], size: 000000500000 Partition: RESERVED2, [000004800000 - 000004E00000], size: 000000600000 Partition: KERNEL, [000004E00000 - 000005E00000], size: 000001000000 Partition: RECOVERY, [000005E00000 - 000006E00000], size: 000001000000 Partition: PERSISTENT, [000006E00000 - 000006F00000], size: 000000100000 Partition: PERSDATA, [000006F00000 - 000007800000], size: 000000900000 Partition: CACHE, [000007800000 - 000014000000], size: 00000C800000 Partition: SYSTEM, [000014000000 - 000094000000], size: 000080000000 Partition: HIDDEN, [000094000000 - 000096800000], size: 000002800000 Partition: userdata, [000096800000 - 0001D2000000], size: 00013B800000 Setting frequence to 21 MHz CMD Pullup Level: 2103 mV CMD Active Level: 3207 mV EMMC Device Information : EMMC CID: 1501003847544634520080AEE850461C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 80AEE850 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 8GTF4R_80AEE850_20190923_203456.extcsd EMMC Init completed. Scanning soft partitions Entry count: 31 Partition: BOOT, [000000000000 - 000000080000], size: 000000080000 Partition: BOOT2, [000000000000 - 000000100000], size: 000000100000 Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 Partition: l_fixnv1, [000000800000 - 000000900000], size: 000000100000 Partition: l_fixnv2, [000000900000 - 000000A00000], size: 000000100000 Partition: pm_sys, [000000A00000 - 000000B00000], size: 000000100000 Partition: rsvdfixnv1, [000000B00000 - 000000C00000], size: 000000100000 Partition: l_ldsp, [000000C00000 - 000001000000], size: 000000400000 Partition: l_modem, [000001000000 - 000002000000], size: 000001000000 Partition: l_gdsp, [000002000000 - 000002400000], size: 000000400000 Partition: l_warm, [000002400000 - 000002800000], size: 000000400000 Partition: FOTA_SIG, [000002800000 - 000002900000], size: 000000100000 Partition: l_runtimenv1, [000002900000 - 000002A00000], size: 000000100000 Partition: l_runtimenv2, [000002A00000 - 000002B00000], size: 000000100000 Partition: td_runtimenv1, [000002B00000 - 000002C00000], size: 000000100000 Partition: td_runtimenv2, [000002C00000 - 000002D00000], size: 000000100000 Partition: PARAM, [000002D00000 - 000002F00000], size: 000000200000 Partition: efs, [000002F00000 - 000004300000], size: 000001400000 Partition: prodnv, [000004300000 - 000004800000], size: 000000500000 Partition: RESERVED2, [000004800000 - 000004E00000], size: 000000600000 Partition: KERNEL, [000004E00000 - 000005E00000], size: 000001000000 Partition: RECOVERY, [000005E00000 - 000006E00000], size: 000001000000 Partition: PERSISTENT, [000006E00000 - 000006F00000], size: 000000100000 Partition: PERSDATA, [000006F00000 - 000007800000], size: 000000900000 Partition: CACHE, [000007800000 - 000014000000], size: 00000C800000 Partition: SYSTEM, [000014000000 - 000094000000], size: 000080000000 Partition: HIDDEN, [000094000000 - 000096800000], size: 000002800000 Partition: userdata, [000096800000 - 0001D2000000], size: 00013B800000 Setting frequence to 21 MHz CMD Pullup Level: 2103 mV CMD Active Level: 3207 mV EMMC Device Information : EMMC CID: 1501003847544634520080AEE850461C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 80AEE850 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2019 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 8GTF4R_80AEE850_20190923_203510.extcsd EMMC Init completed. Scanning soft partitions Entry count: 31 Partition: BOOT, [000000000000 - 000000080000], size: 000000080000 Partition: BOOT2, [000000000000 - 000000100000], size: 000000100000 Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 Partition: l_fixnv1, [000000800000 - 000000900000], size: 000000100000 Partition: l_fixnv2, [000000900000 - 000000A00000], size: 000000100000 Partition: pm_sys, [000000A00000 - 000000B00000], size: 000000100000 Partition: rsvdfixnv1, [000000B00000 - 000000C00000], size: 000000100000 Partition: l_ldsp, [000000C00000 - 000001000000], size: 000000400000 Partition: l_modem, [000001000000 - 000002000000], size: 000001000000 Partition: l_gdsp, [000002000000 - 000002400000], size: 000000400000 Partition: l_warm, [000002400000 - 000002800000], size: 000000400000 Partition: FOTA_SIG, [000002800000 - 000002900000], size: 000000100000 Partition: l_runtimenv1, [000002900000 - 000002A00000], size: 000000100000 Partition: l_runtimenv2, [000002A00000 - 000002B00000], size: 000000100000 Partition: td_runtimenv1, [000002B00000 - 000002C00000], size: 000000100000 Partition: td_runtimenv2, [000002C00000 - 000002D00000], size: 000000100000 Partition: PARAM, [000002D00000 - 000002F00000], size: 000000200000 Partition: efs, [000002F00000 - 000004300000], size: 000001400000 Partition: prodnv, [000004300000 - 000004800000], size: 000000500000 Partition: RESERVED2, [000004800000 - 000004E00000], size: 000000600000 Partition: KERNEL, [000004E00000 - 000005E00000], size: 000001000000 Partition: RECOVERY, [000005E00000 - 000006E00000], size: 000001000000 Partition: PERSISTENT, [000006E00000 - 000006F00000], size: 000000100000 Partition: PERSDATA, [000006F00000 - 000007800000], size: 000000900000 Partition: CACHE, [000007800000 - 000014000000], size: 00000C800000 Partition: SYSTEM, [000014000000 - 000094000000], size: 000080000000 Partition: HIDDEN, [000094000000 - 000096800000], size: 000002800000 Partition: userdata, [000096800000 - 0001D2000000], size: 00013B800000 Get firmware version Entry count: 31 Entry count: 31 Brand = samsung Manufacturer = samsung Device = gtexslte Model = SM-T285 Phone platform = sc8830 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY47V.T285XXU0ARB1 Firmware date = Thu Feb 8 16:16:29 KST 2018 |
09-23-2019, 18:59 | #3 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | and you did not try the read solution from the stiked threads? Is it really so difficult to read stiked threads? They are marked as important. |
The Following User Says Thank You to layder For This Useful Post: |
