01-26-2019, 17:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | htc 10 easy jtag dump Setting bus width to 1 Bit Setting frequence to 36 Mhz CMD Pullup Level: 1579 mV CMD Active Level: 1879 mV EMMC Device Information : EMMC CID: 450100444634303332012244755A53D3 EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023 EMMC Manufacture : SANDISK , EMMC NAME: DF4032 , HEX: 444634303332 , S/N: 2244755A , rev. 0x01 EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: DF4032_2244755A_20190126_155801.extcsd EMMC Init completed. https://www.4shared.com/rar/Odv8rO6Eda/htc_10.html password: sunrisegsm press thanks if it works.. |
The Following 3 Users Say Thank You to simpleprince49 For This Useful Post: |
03-26-2019, 19:24 | #6 (permalink) | |
No Life Poster Join Date: May 2007 Age: 40
Member: 515130 Status: Offline Thanks Meter: 304 | Quote:
Setting frequence to 21 Mhz CMD Pullup Level: 1959 mV CMD Active Level: 2145 mV EMMC Device Information : EMMC CID: 450100444634303332011EDA7AA273D0 EMMC CSD: D00F00328F5903FFFFFFFFEF8A404022 EMMC Manufacture : SANDISK , EMMC NAME: DF4032 , HEX: 444634303332 , S/N: 1EDA7AA2 , rev. 0x01 EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: DF4032_1EDA7AA2_20190326_225144.extcsd EMMC Init completed. Get firmware version Setting frequence to 21 Mhz CMD Pullup Level: 1938 mV CMD Active Level: 2145 mV EMMC Device Information : EMMC CID: 450100444634303332011EDA7AA273D0 EMMC CSD: D00F00328F5903FFFFFFFFEF8A404022 EMMC Manufacture : SANDISK , EMMC NAME: DF4032 , HEX: 444634303332 , S/N: 1EDA7AA2 , rev. 0x01 EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: DF4032_1EDA7AA2_20190326_225207.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000 Filename: EMMC__ROM1_000000000000_000040000000.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 676.54 KB/s All done time: [00:25:50:508] dump write done but phone still dead .phone in qualmqoum mode 9008 what to do next do we need rom 2 or rom3 as well .??? if u have rom 2 rom3 please share | |
04-19-2020, 23:21 | #8 (permalink) |
Junior Member Join Date: Apr 2020 Location: algeria
Member: 2953860 Status: Offline Thanks Meter: 3 | thank you sir when i write the dump my phone still dead in the mode of hs usb qloader 9008 no power on i do factory format the size of my partitions is different than yours |
04-19-2020, 23:36 | #9 (permalink) |
Member: 2953860 Status: Offline Thanks Meter: 3 | eMMC NAME: DF4032 , S/N: 574911834 eMMC NAME (HEX): 444634303332 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure |
04-20-2020, 03:34 | #10 (permalink) |
Freak Poster Join Date: Jul 2013 Location: egypt alexandria
Member: 1972033 Status: Offline Thanks Meter: 32 | make smart report then log it here and as u see theres problem with rpmb partition |
The Following User Says Thank You to nour2014 For This Useful Post: |
