SD Card Unbrick Solution by Easy-JTAG Manual EasyJTAG Magic SD Card Tool Operation Manual Here are the instruction on creating recovery sd-card and boot sd-card to recover bricked Samsung Phones in case your phone got broken.*Before doing this, if your device are detected by usb as Qualcomm HS-USB QDLoader 9008 ( If you device are EXYNOS MCU Based it not need to be detected by USB at all) Creating MAGIC CARD from ZBIN Image. 1. Download both PIT and ZBIN files for yor phone from support area. 2. Insert clean formatted SD Card in USB SD Card Reader 3. Run EasyJTAG Software and select SD Image Plugin 4. Select ZBIN file for creating recovery card by clicking button 5. Select yur SD card in drives list. And click button. 6. After few seconds magic SD card will be done. Close plugin and remove it from reader Recovery Phone by SD Unbrick card 1. Insert SD Card in phone SD card slot and attach battery 2. Put phone in Download mode by USB-JIC either by keyboard combination ( make sure that you have used file with newer firmware than current phone firmware. If you don't know what firmware have ben in phone before software damage – just use latest zbin file from support!) 3. If phone go in ODIN mode, download firmware with same version as in ZBIN file e.g if you used 4. Samsung_GT-I9200_I9200XXUDNE4_GPT_UEFI.zbin you should use I9200XXUDNE4 firmware or newer one. 5. Flash phone with ODIN with PIT file! 6. Repair Done; Creating MAGIC CARD from BIN Dump If your phone have more actual firmware version than ZBIN file on support or you have unsupported phone – you can make ZBIN file by yourself from BINary dump ( eMMC Direct Dump or ADB Full Dump) 1. Run EasyJTAG Software and select SD Image Plugin 2. Select (128mbt DUMP)BIN* file for creating recovery card by clicking button 3. Click [Convert From BIN] button 4. After operation complete you will get ZBIN and PIT file in source folder. • Different Platforms requires different ROM parts for Magic SD |
Sir, Very good user manual but better you give video manual. Best Regards |
but better you give video manual for full process |
(128mbt DUMP)BIN* file for need working phone ?? |
Question Do I need Use TWEEZER TO SHORT of some dead bodies |
thnx it good step, i like easy jtag |
Excellent ....feedback, tips..... results..... anyone.? Problem is, some phones do not boot with the sd card method, unless your doing a tweak. I had a phone that I could only odin with the card in and when I pulled the card, It wouldnt work so I had to stop being lazy and do the jtag chain and presto, no need for sd after the real jtag thing. Now we need a image sharing thread with phones labeled correctly when we post them... |
BR. Siddeque. |
nice update.... good work from teamm... |
EasyJTAG Magic SD Card Tool Operation Picture Manual for new bees. Creating MAGIC CARD from ZBIN Image. Step 1 Run Plugin http://s19.postimg.org/6dngjtigz/image.jpg Step 2 Browse zbin file http://s19.postimg.org/6114ar6ir/image.jpg Step 3 Select SD cared reader http://s19.postimg.org/8kwr4uu2r/image.jpg Step 4 Write SD cared http://s19.postimg.org/groqwfk5f/image.jpg Magic Cared is ready for boot repair now do these steps. Recovery Phone by SD Unbrick card 1. Insert SD Card in phone SD card slot and attach battery 2. Put phone in Download mode by USB-JIC either by keyboard combination ( make sure that you have used file with newer firmware than current phone firmware. If you don't know what firmware have ben in phone before software damage – just use latest zbin file from support!) 3. If phone go in ODIN mode, download firmware with same version as in ZBIN file e.g if you used 4. Samsung_GT-I9200_I9200XXUDNE4_GPT_UEFI.zbin you should use I9200XXUDNE4 firmware or newer one. 5. Flash phone with ODIN with PIT file! 6. Repair Done. Creating MAGIC CARD from BIN Dump Do step 1 and 2 same as above. Step 3 and 4. http://s19.postimg.org/se8uxk7gj/3_4.jpg http://s19.postimg.org/x3ysm5ygz/Ful...231_PM_bmp.jpg http://s19.postimg.org/rh2foovyb/Ful...256_PM_bmp.jpg BR. Siddeque. |
http://forum.gsmhosting.com/vbb/f672.../#post10732554 BR. Siddeque. |
Phone with product name unkown can fix boss |
Product name empty can we fix it |
t |
