Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 08-20-2018, 06:18   #166 (permalink)
Member: 1692778
Sonork: coolman78
Urgent help, need unbrick img for SM-N900K using sdcard method
I have hard brick galaxy note 3 due to flash wrong NHLOS partition /mmcblk0p1 , now it cannot enter bootloader mode/downloader mode
If phone plugs in PC, it recognized as Qualcomm HS-USB QLoader 9008 (com7)
Can I use USB dongle jig to enable download mode ?
Can I use 301k Ohm SMT resistor type instead of 4bands color resistor type ?
It is not working.
Help please,....THANKS
p/S: lasted ROM SM-N900K_20150304_N900KKKU0GOC4_N900KKTT0GOC4_5.0
Old 11-30-2018, 19:49   #167 (permalink)
Member: 1718952
Thanks Meter: 28
thnx it good step, i like easy jtag
Old 12-22-2018, 13:43   #168 (permalink)
Member: 2359454
Thanks Meter: 9
Problem with making Easy JTAG magicd SD
Originally Posted by blang View Post
EasyJTAG Magic SD Card Tool Operation Manual
Here are the instruction on creating recovery sd-card and boot sd-card to recover bricked Samsung Phones in case your phone got broken.*Before doing this, if your device are detected by usb as Qualcomm HS-USB QDLoader 9008 ( If you device are EXYNOS MCU Based it not need to be detected by USB at all)
Creating MAGIC CARD from ZBIN Image.
1. Download both PIT and ZBIN files for yor phone from support area.
2. Insert clean formatted SD Card in USB SD Card Reader
3. Run EasyJTAG Software and select SD Image Plugin
4. Select ZBIN file for creating recovery card by clicking button
5. Select yur SD card in drives list. And click button.
6. After few seconds magic SD card will be done. Close plugin and remove it from reader
Recovery Phone by SD Unbrick card
1. Insert SD Card in phone SD card slot and attach battery
2. Put phone in Download mode by USB-JIC either by keyboard combination ( make sure that you have used file with newer firmware than current phone firmware. If you don't know what firmware have ben in phone before software damage just use latest zbin file from support!)
3. If phone go in ODIN mode, download firmware with same version as in ZBIN file e.g if you used
4. Samsung_GT-I9200_I9200XXUDNE4_GPT_UEFI.zbin you should use I9200XXUDNE4 firmware or newer one.
5. Flash phone with ODIN with PIT file!
6. Repair Done;
Creating MAGIC CARD from BIN Dump
If your phone have more actual firmware version than ZBIN file on support or you have unsupported phone you can make ZBIN file by yourself from BINary dump ( eMMC Direct Dump or ADB Full Dump)
1. Run EasyJTAG Software and select SD Image Plugin
2. Select (128mbt DUMP)BIN* file for creating recovery card by clicking button
3. Click [Convert From BIN] button
4. After operation complete you will get ZBIN and PIT file in source folder.
Different Platforms requires different ROM parts for Magic SD
I have a Samsung J500F/DS and ZBIN file isn't exist in Easy support . I have a dump file :
EMMC_ROM1_00000000_20000000 j500f-ds.bin
EMMC_ROM2_00000000_00400000 j500f-ds.bin
EMMC_ROM3_00000000_00400000 j500f-ds.bin
1-Which file we should use for making Magic SD card?
2-Do I need to make short test point before use magic card?
If Yes. were is the test point?
Thanks in advance
The Following User Says Thank You to mohandesbiaziat For This Useful Post:
Old 12-24-2018, 08:46   #169 (permalink)
Member: 2359454
Thanks Meter: 9
I need help, please help me.
Old 08-26-2019, 06:00   #170 (permalink)
Member: 2710564
i dont have easy-jtag
Old 09-23-2019, 09:18   #171 (permalink)
javsoft's Avatar
Member: 750419
Sonork: 100.1604828
Thanks Meter: 45
can i solved 9008 qualcomm in g530m?
Old 09-25-2019, 13:04   #172 (permalink)
Member: 933096
Sonork: inocentedeti
Thanks Meter: 19
Originally Posted by .:MobileLife:. View Post
If hardware would be not fix means if have emmc damage can't be fix any box need to change emmc and most of problem no product name emmc fault.
t
tnx bro for sharing,, less time consume to solve emmc fault
The Following User Says Thank You to inocentedeti For This Useful Post:
Old 02-08-2020, 11:01   #173 (permalink)
Member: 575256
Thanks Meter: 32
this metode support for new devices 2019 above on
Old 04-01-2020, 16:57   #174 (permalink)
Member: 1596349
Thanks Meter: 7
Dear all members plz suggest to me I want to buy
A new emmc box in which is best 1-ufi.2-easy jtag plus...... (My choice is easy jtag plus)
Old 04-20-2020, 00:22   #175 (permalink)
Member: 2953860
thank you very much.
i do all steps
but when i write flash with odin the operation fail error pit
Page generated in 0.28677 seconds with 7 queries
