04-16-2015, 18:38 | #61 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2379007 Status: Offline Sonork: 100.1664140 Thanks Meter: 4 | how can you solve? Compression thread encountered exception: "Exception of type Compression Exception thrown, cause buffer error (-5)" |
04-23-2015, 04:21 | #63 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Tema, Ghana Age: 45
Member: 108131 Status: Offline Thanks Meter: 21 | i'm i to see any file on the magic sd card after creation???? Hi, i go through the procedure as described in the images you shared but when i finish creating the magic sd card, i'm i to see any file (s) on the card as when i check the content after creation, there isn't a single file on the sd card. it's still a blank sd card. i have tried several cards of varying sizes and the outcome has been the same. what will you advice??? thanx and best wishes |
05-09-2015, 04:36 | #71 (permalink) |
Member: 108131 Status: Offline Thanks Meter: 21 | No file on sd card after creating magic sd card Hi Team, please i'm i to see any files on the magic sd card after creating it??? reason for asking is i've done this for several of the supported devices and various files in the support and in all instance, though it says "SD operation done", there's no file on the sd card and when i insert to put the device in download mode, nothing happens. i have tried this with SEVERAL sd cards and the result is the same. please clarify this for me. thanx and best wishes |
05-09-2015, 05:31 | #72 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Quote:
What is the your phone history. | |
05-12-2015, 21:16 | #73 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1090661 Status: Offline Thanks Meter: 15 | |
05-19-2015, 07:37 | #75 (permalink) | |
Freak Poster Join Date: Feb 2012 Location: Lebanon
Member: 1726910 Status: Offline Sonork: 100.1623945 Thanks Meter: 41 | Quote:
Sometimes you get corrupted zbin file from support, so download it again and try to open it with 7zip to see if it's ok After you make the sd boot card, insert it in a working phone and it should notify you that this sd card is damaged or something like that..... Than you are ready to fix your dead phone Use terraterm with a serial port, to force your device to enter sd card mode Regards Sent from my iPad using Tapatalk | |
