10-09-2017, 11:52 | #1 (permalink) |
Freak Poster Join Date: Sep 2014 Location: Bahawal Nagar
Member: 2250995 Status: Offline Thanks Meter: 47 | SM-A500FU Boot Dead During Flash Job = UnlockNetwork Phone was on Fallowing Firmware : Selected model: SM-A500FU INFO : 10/8/2017 6:43:47 PM > Detected phone model: SM-A500FU INFO : 10/8/2017 6:43:47 PM > Firmware compiled date: Thu Aug 4 21:03:10 KST 2016 INFO : 10/8/2017 6:43:47 PM > PDA version: A500FUXXU1CPH3 INFO : 10/8/2017 6:43:47 PM > CSC version: A500FUDBT1CPH3 INFO : 10/8/2017 6:43:47 PM > SW version: A500FUXXU1CPH3 INFO : 10/8/2017 6:43:48 PM > Phone SN: RF8G31KMLKN INFO : 10/8/2017 6:43:48 PM > Android version: 6.0.1 (MMB29M) INFO : 10/8/2017 6:43:48 PM > Sales code: DBT INFO : 10/8/2017 6:43:48 PM > Country: Germany INFO : 10/8/2017 6:43:48 PM > HW platform: msm8916 INFO : 10/8/2017 6:43:48 PM > HW Chip: MSM8916 INFO : 10/8/2017 6:43:48 PM > HW Modem: MSM8916 INFO : 10/8/2017 6:43:48 PM > Security patch level: 2016-08-01 INFO : 10/8/2017 6:43:48 PM > SIM 1 status: absent INFO : 10/8/2017 6:43:48 PM > Codename: a5ultexx INFO : 10/8/2017 6:43:48 PM > Checking Root: INFO : 10/8/2017 6:43:48 PM > Phone is Rooted. INFO : 10/8/2017 6:43:48 PM > Unlocking phone... INFO : 10/8/2017 6:44:11 PM > Phone is successfully unlocked After Unlock it was asking Fot again Network Lock Decided to downlgrade via sm sucesse Repor used the fallowing combination To Downgrade COMBINATION_OXA_FA44_A500FUXXU1AOK1.zip Sucessfiully dongraded nd Unlocked Done then flash with same firmware A500FUXXU1CPH3_A500FUDBT1CPH3_A500FUXXU1CPH3_HOME. tar it faild nd says too big system image 4ext fail bala bla Now phone no download mod vibrate Only I Hv ....................... ATF EMMC Tool Easy Jtag Box Mudussa Pro Box Which One is sucessfull to repair the boot of fallowing Model ? Share your experiance m8s B.R |
10-10-2017, 09:42 | #2 (permalink) |
Member: 2250995 Status: Offline Thanks Meter: 47 | After Write by wander not Power On Detect Log Write by vander Done used that firmware where it was before downgrade After Done it shows Writen Fimware But Still Same After Diconnect all wires No power On |
10-12-2017, 01:49 | #3 (permalink) | |
Insane Poster Join Date: Oct 2012 Location: morroco
Member: 1820874 Status: Offline Thanks Meter: 20 | Quote:
The commbined firmware is problem is 4.4.4 use latest firmware 6.0.1 and repair boot Envoyé de mon iPhone en utilisant Tapatalk | |
10-12-2017, 08:15 | #4 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,554 | you have to use last firmware. there are fuse and you can't use old boot for repair phone success. |
The Following User Says Thank You to blang For This Useful Post: |
10-12-2017, 15:32 | #5 (permalink) | |
Member: 2250995 Status: Offline Thanks Meter: 47 | See Detail............ Quote:
it was on 6.0.1 When dead >>>>> A500FUXXU1CPH3_A500FUDBT1CPH3_DBT Last Resled Acording CSC DBT is >>A500FUXXS1CQC4_A500FUDBT1CPH3_DBT Pls creat lateset Dump Many users are sick about this dead | |
10-12-2017, 16:44 | #6 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | hi bro chck this successed post i have done it 2016. check the link http://forum.gsmhosting.com/vbb/f672...-done-2158700/ |
10-12-2017, 18:12 | #7 (permalink) | |
Member: 2250995 Status: Offline Thanks Meter: 47 | Mention boot File Quote:
10-13-2017, 04:43 | #8 (permalink) | |
Freak Poster Join Date: Jun 2014
Member: 2213928 Status: Offline Thanks Meter: 440 | Quote:
10-14-2017, 11:03 | #9 (permalink) |
Member: 2250995 Status: Offline Thanks Meter: 47 | No Download Mod factry reset + Format Then write dumped Rom 1 based on 5.0.2 From support . Then Write by vander and used last firmware 6.0.1 Boot loaders Only Still No Download Mod even CLK Replaced by wire At Usb Connect QUALCOM HS-USB QLOADER 9008 EMMC Device Information : EMMC CID: 150100523331314D4200ACDEC42532CA EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 3/2015 , Rev: 00 EMMC NAME: R311MB , S/N: ACDEC425 , rev. 00 EMMC NAME (HEX): 523331314D42 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: R311MB_ACDEC425_20171014_144213.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 Partition: modem, [000001300000 - 000004C70000], size: 000003970000 Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 Partition: fsg, [000005078000 - 000005378000], size: 000000300000 Partition: sec, [000005378000 - 00000537C000], size: 000000004000 Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 Partition: param, [000005E00000 - 000006800000], size: 000000A00000 Partition: efs, [000006800000 - 000007600000], size: 000000E00000 Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 Partition: fota, [000009800000 - 000009D00400], size: 000000500400 Partition: backup, [000009D00400 - 00000A3FE000], size: 0000006FDC00 Partition: fsc, [00000A3FE000 - 00000A6FE000], size: 000000300000 Partition: ssd, [00000A6FE000 - 00000A700000], size: 000000002000 Partition: persist, [00000A700000 - 00000AF00000], size: 000000800000 Partition: persdata, [00000AF00000 - 00000B800000], size: 000000900000 Partition: system, [00000B800000 - 0000A1800000], size: 000096000000 Partition: cache, [0000A1800000 - 0000AE000000], size: 00000C800000 Partition: hidden, [0000AE000000 - 0000B1C00000], size: 000003C00000 Partition: userdata, [0000B1C00000 - 0003AB400000], size: 0002F9800000 GPT header successfully parsed Get firmware version |
