09-12-2019, 09:48 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Age: 39
Member: 681346 Status: Offline Thanks Meter: 14 | SM-G316HU jtag repair done but no dwonlod mode Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 36 MHz CMD Pullup Level: 1787 mV CMD Active Level: 1853 mV EMMC Device Information : EMMC CID: 90014A483447326211017F042A4642EB EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 7F042A46 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G2b_7F042A46_20190911_193137.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 (2.00 MB) Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 (2.00 MB) Partition: WFIXNV1, [000000800000 - 000000900000], size: 000000100000 (1.00 MB) Partition: WFIXNV2, [000000900000 - 000000A00000], size: 000000100000 (1.00 MB) Partition: TDFIXNV1, [000000A00000 - 000000B00000], size: 000000100000 (1.00 MB) Partition: TDFIXNV2, [000000B00000 - 000000C00000], size: 000000100000 (1.00 MB) Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 (4.00 MB) Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 (8.00 MB) Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 (8.00 MB) Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 (4.00 MB) Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 (1.00 MB) Partition: WRUNTIMENV1, [000002500000 - 000002600000], size: 000000100000 (1.00 MB) Partition: WRUNTIMENV2, [000002600000 - 000002700000], size: 000000100000 (1.00 MB) Partition: TDRUNTIMENV1, [000002700000 - 000002800000], size: 000000100000 (1.00 MB) Partition: TDRUNTIMENV2, [000002800000 - 000002900000], size: 000000100000 (1.00 MB) Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 (2.00 MB) Partition: EFS, [000002B00000 - 000003F00000], size: 000001400000 (20.0 MB) Partition: PRODNV, [000003F00000 - 000004400000], size: 000000500000 (5.00 MB) Partition: RESERVED2, [000004400000 - 000004500000], size: 000000100000 (1.00 MB) Partition: KERNEL, [000004500000 - 000005500000], size: 000001000000 (16.0 MB) Partition: RECOVERY, [000005500000 - 000006500000], size: 000001000000 (16.0 MB) Partition: CSC, [000006500000 - 000012D00000], size: 00000C800000 (200. MB) Partition: SYSTEM, [000012D00000 - 00005DD00000], size: 00004B000000 (1.17 GB) Partition: HIDDEN, [00005DD00000 - 000065D00000], size: 000008000000 (128. MB) Partition: USERDATA, [000065D00000 - 0000E8FFBE00], size: 0000832FBE00 (2.05 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = vivalto5mve3g Model = SM-G316HU Phone platform = sc8830 CPU Abi = armeabi-v7a Android release = 4.4.4 Firmware version = KTU84P.G316HUDXS0AQA2 Firmware date = Sat Jan 7 13:34:20 KST 2017 |
09-12-2019, 13:48 | #2 (permalink) |
Member: 681346 Status: Offline Thanks Meter: 14 | g316hu cannot download mode Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0000E8FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: nvitem.bin Unpacking file: sprddsp.img Unpacking file: sprdcp.img Unpacking file: param.lfs Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: cache.img Unpacking file: system.img Unpacking file: hidden.img Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 1359.01 KB/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1780.05 KB/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3265.21 KB/s Partition name: WFIXNV2 Filename: nvitem.bin , Offset: 000000900000 , filesize: 174856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1776.56 KB/s Partition name: WDSP Filename: sprddsp.img , Offset: 000000C00000 , filesize: 1967104 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3142.82 KB/s Partition name: MODEM Filename: sprdcp.img , Offset: 000001000000 , filesize: 7365292 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3243.46 KB/s Partition name: PARAM Filename: param.lfs , Offset: 000002900000 , filesize: 634880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3229.02 KB/s Partition name: KERNEL Filename: boot.img , Offset: 000004500000 , filesize: 5725184 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3252.40 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005500000 , filesize: 7062528 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3266.12 KB/s Partition name: CSC Filename: cache.img , Offset: 000006500000 , filesize: 29651216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 3249.64 KB/s Partition name: SYSTEM Filename: system.img , Offset: 000012D00000 , filesize: 917927504 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 1635 Done writing partition. Write speed: 3032.11 KB/s Partition name: HIDDEN Filename: hidden.img , Offset: 00005DD00000 , filesize: 9408752 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 13 Done writing partition. Write speed: 3154.60 KB/s Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Writing BootConfig ... Reg: 179 Value: 0x08 Reg: 177 Value: 0x00 Reg: 162 Value: 0x00 Done All done time: [00:06:36:410] Last edited by nirma; 09-12-2019 at 13:57. Reason: g316hu cannot download mode |
