-   Easy-Jtag (http://forum.gsmhosting.com/vbb/f672/)
-   -   SM-G316HU jtag repair done but no power (http://forum.gsmhosting.com/vbb/f672/sm-g316hu-jtag-repair-done-but-no-power-2686691/)
nirma 09-11-2019 15:04
Setting interface to EasyJtag2/ISP_HiPower
Setting bus width to 1 Bit
HiPower mode is ON
Setting frequence to 36 MHz
CMD Pullup Level: 1787 mV
CMD Active Level: 1853 mV
EMMC Device Information :
EMMC CID: 90014A483447326211017F042A4642EB
EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB
EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 7F042A46 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2015
EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H4G2b_7F042A46_20190911_193137.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 (2.00 MB)
Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 (2.00 MB)
Partition: WFIXNV1, [000000800000 - 000000900000], size: 000000100000 (1.00 MB)
Partition: WFIXNV2, [000000900000 - 000000A00000], size: 000000100000 (1.00 MB)
Partition: TDFIXNV1, [000000A00000 - 000000B00000], size: 000000100000 (1.00 MB)
Partition: TDFIXNV2, [000000B00000 - 000000C00000], size: 000000100000 (1.00 MB)
Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 (4.00 MB)
Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 (8.00 MB)
Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 (8.00 MB)
Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 (4.00 MB)
Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 (1.00 MB)
Partition: WRUNTIMENV1, [000002500000 - 000002600000], size: 000000100000 (1.00 MB)
Partition: WRUNTIMENV2, [000002600000 - 000002700000], size: 000000100000 (1.00 MB)
Partition: TDRUNTIMENV1, [000002700000 - 000002800000], size: 000000100000 (1.00 MB)
Partition: TDRUNTIMENV2, [000002800000 - 000002900000], size: 000000100000 (1.00 MB)
Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 (2.00 MB)
Partition: EFS, [000002B00000 - 000003F00000], size: 000001400000 (20.0 MB)
Partition: PRODNV, [000003F00000 - 000004400000], size: 000000500000 (5.00 MB)
Partition: RESERVED2, [000004400000 - 000004500000], size: 000000100000 (1.00 MB)
Partition: KERNEL, [000004500000 - 000005500000], size: 000001000000 (16.0 MB)
Partition: RECOVERY, [000005500000 - 000006500000], size: 000001000000 (16.0 MB)
Partition: CSC, [000006500000 - 000012D00000], size: 00000C800000 (200. MB)
Partition: SYSTEM, [000012D00000 - 00005DD00000], size: 00004B000000 (1.17 GB)
Partition: HIDDEN, [00005DD00000 - 000065D00000], size: 000008000000 (128. MB)
Partition: USERDATA, [000065D00000 - 0000E8FFBE00], size: 0000832FBE00 (2.05 GB)
GPT header successfully parsed
Get firmware version
Brand = samsung
Manufacturer = samsung
Device = vivalto5mve3g
Model = SM-G316HU
Phone platform = sc8830
CPU Abi = armeabi-v7a
Android release = 4.4.4
Firmware version = KTU84P.G316HUDXS0AQA2
Firmware date = Sat Jan 7 13:34:20 KST 2017
:confused::confused::confused:
nirma 09-11-2019 15:13
Found 1 serial devices
COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM3)
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.3
Loading eMMC GEN2 Firmware... IO: 1800 mV
Box S/N: 5E4CF6B5CA89F940, ,FW Ver.: 02.44
CMD Pullup Level:1726 mV
CMD Active Level:1853 mV
Box IO Level:1800 mV
CLK Rate:36000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 90014A483447326211017F042A4642EB
eMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DB
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 04/2015 Rev.0x1
eMMC NAME: H4G2b , S/N: 2130979398
eMMC NAME (HEX): 483447326220
EMMC ROM1 (Main User Data) Capacity: 3728 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is not yet programmed (clear) or RPMB General failure
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H4G2b_2130979398_20190911_1940.extcsd
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB
Soft (Partitioned) Disk/Image size: 747FBC sectors 3.6 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B
First usable sector: 34
Last usable sector: 7634910
Partition info successfully found
Found Data areas (firmware parts) count is: 25
P0 (SBOOT) [0x400000 0x200000] Size: 2.0MB
P1 (SBOOT2) [0x600000 0x200000] Size: 2.0MB
P2 (WFIXNV1) [0x800000 0x100000] Size: 1.0MB
P3 (WFIXNV2) [0x900000 0x100000] Size: 1.0MB
P4 (TDFIXNV1) [0xa00000 0x100000] Size: 1.0MB
P5 (TDFIXNV2) [0xb00000 0x100000] Size: 1.0MB
P6 (WDSP) [0xc00000 0x400000] Size: 4.0MB
P7 (MODEM) [0x1000000 0x800000] Size: 8.0MB
P8 (MODEM2) [0x1800000 0x800000] Size: 8.0MB
P9 (TDDSP) [0x2000000 0x400000] Size: 4.0MB
P10 (FOTA_SIG) [0x2400000 0x100000] Size: 1.0MB
P11 (WRUNTIMENV1) [0x2500000 0x100000] Size: 1.0MB
P12 (WRUNTIMENV2) [0x2600000 0x100000] Size: 1.0MB
P13 (TDRUNTIMENV1) [0x2700000 0x100000] Size: 1.0MB
P14 (TDRUNTIMENV2) [0x2800000 0x100000] Size: 1.0MB
P15 (PARAM) [0x2900000 0x200000] Size: 2.0MB
P16 (EFS) [0x2b00000 0x1400000] Size: 20.0MB
P17 (PRODNV) [0x3f00000 0x500000] Size: 5.0MB
P18 (RESERVED2) [0x4400000 0x100000] Size: 1.0MB
P19 (KERNEL) [0x4500000 0x1000000] Size: 16.0MB
P20 (RECOVERY) [0x5500000 0x1000000] Size: 16.0MB
P21 (CSC) [0x6500000 0xc800000] Size: 200.0MB
P22 (SYSTEM) [0x12d00000 0x4b000000] Size: 1.171GB
P23 (HIDDEN) [0x5dd00000 0x8000000] Size: 128.0MB
P24 (USERDATA) [0x65d00000 0x832fbe00] Size: 2.48GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0012D00000 (1.171GB)
Build ID: KTU84P
Display Build ID: KTU84P.G316HUDXS0AQA2
Release Incremental ID: G316HUDXS0AQA2
Release Base ID: 4.4.4
Device Model: SM-G316HU
Device Name: vivalto5mve3gdx
Architecture ABI: armeabi-v7a
Device manufacturer: samsung
Device Platform: sc8830
Product ID: vivalto5mve3g
Build Description: vivalto5mve3gdx-user 4.4.4 KTU84P G316HUDXS0AQA2 release-keys
Samsung CPU: SC7727S
Detected USERDATA USERDATA : 0x0065D00000 (2.48GB)
Unable to read gesture.key , code 2
Done.
Selected eMMC Interface
nirma 09-16-2019 05:48
Page generated in 0.14895 seconds with 5 queries
