11-10-2017, 19:09 | #1 (permalink) |
Freak Poster Join Date: Jul 2014 Location: philippines
Member: 2226456 Status: Offline Sonork: jerrenn Thanks Meter: 83 | SM-G318MZ DS deadboot revive via easy jtag Code: HiPower mode is ON Frequence: 14 Mhz CMD Pullup Level: 1216 mV CMD Active Level: 3011 mV Can't init device. Reason: CMD Timeout Error HiPower mode is ON Frequence: 14 Mhz CMD Pullup Level: 2145 mV CMD Active Level: 2629 mV EMMC Device Information : EMMC CID: 90014A4834473262110166A741C482DC EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: 66A741C4 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Backup saved: H4G2b_66A741C4_20171111_011137.extcsd EMMC Init completed. Opening file: SM-G318MZ_VIVALTO_ML_4GB_20150210.pit Pit: SM-G318MZ_VIVALTO_ML_4GB_20150210.pit Entry count: 30 The size of the last section has been updated G318MZDXS0AQC1_G318MZOLC0APE1_G318MZDXU0APE1_HOME.tar.md5 The list of files in the firmware: boot.img cache.img hidden.img recovery.img sboot.bin sboot2.bin spl.img sprdcp.img sprddsp.img system.img HiPower mode is ON Frequence: 14 Mhz CMD Pullup Level: 2155 mV CMD Active Level: 2980 mV EMMC Device Information : EMMC CID: 90014A4834473262110166A741C482DC EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: 66A741C4 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Backup saved: H4G2b_66A741C4_20171111_011150.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000080000 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: sprddsp.img Unpacking file: sprdcp.img Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: cache.img Unpacking file: system.img Unpacking file: hidden.img Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 215.81 Kb/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 670.47 Kb/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 953.44 Kb/s Partition name: WDSP Filename: sprddsp.img , Offset: 000000C00000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1009.43 Kb/s Partition name: MODEM Filename: sprdcp.img , Offset: 000001000000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 830.92 Kb/s Partition name: KERNEL Filename: boot.img , Offset: 000004500000 , filesize: 5747712 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 805.95 Kb/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005500000 , filesize: 7085056 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 805.94 Kb/s Partition name: CSC Filename: cache.img , Offset: 000006E00000 , filesize: 48103696 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 847.66 Kb/s Partition name: SYSTEM Filename: system.img , Offset: 000013600000 , filesize: 924419872 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 1648 Done writing partition. Write speed: 746.16 Kb/s Partition name: HIDDEN Filename: hidden.img , Offset: 000053C00000 , filesize: 8261872 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 13 Done writing partition. Write speed: 981.61 Kb/s All done thenflash via doin |
11-27-2017, 14:42 | #5 (permalink) | |
Freak Poster Join Date: May 2012 Location: Kabasalan, Zambo Sibugay, Phil
Member: 1757686 Status: Offline Thanks Meter: 29 | For what reason? if you already done via vendor flashing and still not work then perhaps there could be some bad blocks on emmc. If you had experienced this kind of errors: Quote:
