Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 10-31-2018, 16:32   #1 (permalink)
Member: 2340647
Thanks Meter: 53
SM-G355H Boot Repair Problem
Hello,,
G355H Still dead after repair
Is there any error in the logo:
31/10/2018 01:27:26 م> Looking for EasyJTAG box...
31/10/2018 01:27:26 م> EasyJTAG API ver. 2100
31/10/2018 01:27:26 م> Setting IO Levels to 1.8V
31/10/2018 01:27:26 م> Setting frequence to 6 Mhz
31/10/2018 01:27:26 م> EasyJTAG Box Serial = FBE84B4C2A0EC2BE
31/10/2018 01:27:26 م> EasyJTAG Box Firmware = 2.30
31/10/2018 01:27:26 م> Setting interface to EasyJtag2/ISP
31/10/2018 01:27:26 م> Setting bus width to 1 Bit
31/10/2018 01:27:26 م> CMD Pullup Level: 1818 mV
31/10/2018 01:27:26 م> CMD Active Level: 1871 mV
31/10/2018 01:27:26 م> eMMC Init returned = 0
31/10/2018 01:27:26 م> EMMC Device Information :
31/10/2018 01:27:26 م> EMMC CID: 1501004B3558594D4203A30DF483C1ED
31/10/2018 01:27:26 م> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
31/10/2018 01:27:26 م> EMMC Manufacture : SAMSUNG , EMMC NAME: K5XYMB , HEX: 4B3558594D42 , S/N: A30DF483 , rev. 0x03
31/10/2018 01:27:26 م> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2014
31/10/2018 01:27:26 م>    EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000)
31/10/2018 01:27:26 م>    EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
31/10/2018 01:27:26 م>    EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000)
31/10/2018 01:27:26 م> EMMC Permanent Write Protection: No
31/10/2018 01:27:26 م> EMMC Temporary Write Protection: No
31/10/2018 01:27:26 م> Extended CSD Information :
31/10/2018 01:27:26 م> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
31/10/2018 01:27:26 م> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
31/10/2018 01:27:26 م> Boot Bus Config: 0x00 , width 1bit
31/10/2018 01:27:26 م> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
31/10/2018 01:27:26 م> Supported partition features [PARTITIONING_SUPPORT]: 0x07
31/10/2018 01:27:26 م> Device supports partitioning features
31/10/2018 01:27:26 م> Device can have enhanced technological features in partitions and user data area
31/10/2018 01:27:26 م> Device can have extended partitions attribute
31/10/2018 01:27:26 م> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
31/10/2018 01:27:26 م> Backup saved: K5XYMB_A30DF483_20181031_132726.extcsd
31/10/2018 01:27:26 م> EMMC Init completed.
31/10/2018 01:27:27 م> Scanning soft partitions
31/10/2018 01:27:27 م> GPT header is found and is valid
31/10/2018 01:27:27 م> Partition: fixnv1, [000000400000 - 0000007C0000], size: 0000003C0000 (3.75 MB)
31/10/2018 01:27:27 م> Partition: fixnv2, [0000007C0000 - 000000B80000], size: 0000003C0000 (3.75 MB)
31/10/2018 01:27:27 م> Partition: sbl1, [000000B80000 - 000000D80000], size: 000000200000 (2.00 MB)
31/10/2018 01:27:27 م> Partition: sbl2, [000000D80000 - 000000F80000], size: 000000200000 (2.00 MB)
31/10/2018 01:27:27 م> Partition: wdsp, [000000F80000 - 000001480000], size: 000000500000 (5.00 MB)
31/10/2018 01:27:27 م> Partition: wdsp_backup, [000001480000 - 000001980000], size: 000000500000 (5.00 MB)
31/10/2018 01:27:27 م> Partition: modem, [000001980000 - 000002380000], size: 000000A00000 (10.0 MB)
31/10/2018 01:27:27 م> Partition: modem_backup, [000002380000 - 000002D80000], size: 000000A00000 (10.0 MB)
31/10/2018 01:27:27 م> Partition: fota_sig, [000002D80000 - 000002DC0000], size: 000000040000 (256. KB)
31/10/2018 01:27:27 م> Partition: ota, [000002DC0000 - 0000035C0000], size: 000000800000 (8.00 MB)
31/10/2018 01:27:27 م> Partition: runtimenv1, [0000035C0000 - 000003980000], size: 0000003C0000 (3.75 MB)
31/10/2018 01:27:27 م> Partition: runtimenv2, [000003980000 - 000003D40000], size: 0000003C0000 (3.75 MB)
31/10/2018 01:27:27 م> Partition: param, [000003D40000 - 000004000000], size: 0000002C0000 (2.75 MB)
31/10/2018 01:27:27 م> Partition: efs, [000004240000 - 000005640000], size: 000001400000 (20.0 MB)
31/10/2018 01:27:27 م> Partition: prodnv, [000005640000 - 000005B40000], size: 000000500000 (5.00 MB)
31/10/2018 01:27:27 م> Partition: odin_reserved, [000005B40000 - 000005B80000], size: 000000040000 (256. KB)
31/10/2018 01:27:27 م> Partition: kernel, [000005B80000 - 000006A80000], size: 000000F00000 (15.0 MB)
31/10/2018 01:27:27 م> Partition: recovery, [000006A80000 - 000007980000], size: 000000F00000 (15.0 MB)
31/10/2018 01:27:27 م> Partition: csc, [000007980000 - 00000F180000], size: 000007800000 (120. MB)
31/10/2018 01:27:27 م> Partition: system, [00000F180000 - 000056580000], size: 000047400000 (1.11 GB)
31/10/2018 01:27:27 م> Partition: hidden, [000056580000 - 000058380000], size: 000001E00000 (30.0 MB)
31/10/2018 01:27:27 م> Partition: userdata, [000058380000 - 0000E8FFBE00], size: 000090C7BE00 (2.26 GB)
31/10/2018 01:27:27 م> GPT header successfully parsed
31/10/2018 01:27:27 م> Get firmware version
31/10/2018 01:27:28 م> Brand = samsung
31/10/2018 01:27:28 م> Manufacturer = samsung
31/10/2018 01:27:28 م> Model = SM-G355H
31/10/2018 01:27:28 م> Phone platform = sc8830
31/10/2018 01:27:28 م> CPU Abi = armeabi-v7a
31/10/2018 01:27:28 م> Android release = 4.4.2
31/10/2018 01:27:28 م> Firmware version = KOT49H.G355HXXU0ANHA
31/10/2018 01:27:28 م> Firmware date = Wed Aug 20 01:00:10 KST 2014
Old 11-02-2018, 13:19   #2 (permalink)
Member: 13148
Thanks Meter: 676
Originally Posted by wahby4 View Post
Hello,,
1) At log are no errors
2) you need to write latest firmware, like G355HXXS0AQA6 (05.01.2017), but you wrote a ANH version (08.2014)
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 11-02-2018, 14:43   #3 (permalink)
Member: 2340647
Thanks Meter: 53
ok i will try & post the result
Thank u
Old 11-02-2018, 18:33   #4 (permalink)
Member: 2340647
Thanks Meter: 53
Same problem after write G355HXXS0AQA6 file:
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.3.0.0
Loading eMMC GEN2 Firmware... IO: 1800 mV
Box S/N: FBE84B4C2A0EC2BE, ,FW Ver.: 02.30
CMD Pullup Level:1816 mV
CMD Active Level:1870 mV
Box IO Level:1800 mV
CLK Rate:12000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 1501004B3558594D4203A30DF483C1ED
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 12/2014  Rev.0x3
eMMC NAME: K5XYMB , S/N: 2735600771
eMMC NAME (HEX): 4B3558594D42
IC Name: Samsung , KMK5X000YM-B314/4GB+LPDDR2 6Gb(x32) @FBGA162
EMMC ROM1 (Main User Data)   Capacity: 3728 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB
EMMC Password Locked: No
  Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: K5XYMB_2735600771_20181102_1552.extcsd
Found Data areas (firmware parts) count is: 22
Partition info successfully found
P0 (SBL1) [0x400000 0x200000] Size: 2.0MB
P1 (SBL2) [0x600000 0x200000] Size: 2.0MB
P2 (EFS) [0x800000 0x1400000] Size: 20.0MB
P3 (PARAM) [0x1c00000 0x800000] Size: 8.0MB
P4 (KERNEL) [0x2400000 0x1400000] Size: 20.0MB
P5 (RECOVERY) [0x3800000 0x1400000] Size: 20.0MB
P6 (CSC) [0x4c00000 0x9600000] Size: 150.0MB
P7 (SYSTEM) [0xe200000 0x51400000] Size: 1.269GB
P8 (HIDDEN) [0x5f600000 0x8000000] Size: 128.0MB
P9 (OTA) [0x67600000 0x800000] Size: 8.0MB
P10 (FIXNV1) [0x67e00000 0x3c0000] Size: 3.750MB
P11 (FIXNV2) [0x681c0000 0x3c0000] Size: 3.750MB
P12 (WDSP) [0x68580000 0x500000] Size: 5.0MB
P13 (MODEM) [0x68a80000 0xa00000] Size: 10.0MB
P14 (RUNTIMENV1) [0x69480000 0x3c0000] Size: 3.750MB
P15 (RUNTIMENV2) [0x69840000 0x3c0000] Size: 3.750MB
P16 (WDSP_BACKUP) [0x69c00000 0x500000] Size: 5.0MB
P17 (MODEM_BACKUP) [0x6a100000 0xa00000] Size: 10.0MB
P18 (FOTA_SIG) [0x6ab00000 0x40000] Size: 256.0KB
P19 (ODIN_RESERVED) [0x6ab40000 0x40000] Size: 256.0KB
P20 (PRODNV) [0x6ab80000 0x500000] Size: 5.0MB
P21 (USERDATA) [0x6b080000 0x7df7be00] Size: 1.967GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000E200000 (1.269GB)
Build ID:  KOT49H
Display Build ID:  KOT49H.G355HXXS0AQA6
Release ID:  4.4.2
Device Model:  SM-G355H
Device Name:  kanas3gxx
Architecture ABI:  armeabi-v7a
Device manufacturer:  samsung
Device Platform:  sc8830
Product ID:  kanas
Build Description:  kanas3gxx-user 4.4.2 KOT49H G355HXXS0AQA6 release-keys
Samsung CPU:  sc7735s
Done.
Old 11-03-2018, 04:18   #5 (permalink)
Member: 2463805
Thanks Meter: 25
write boot config file
write boot configuration file from dumb and check.
The Following User Says Thank You to pirunthan7 For This Useful Post:
Old 11-03-2018, 11:50   #6 (permalink)
Member: 2340647
Thanks Meter: 53
Also i wrote dump v1 But sam problem
Old 11-03-2018, 22:40   #7 (permalink)
Member: 2463805
Thanks Meter: 25
Try once format and write dump
Try format and write ROM 1,2 and user bin and extCSD file.
And also checkis there any damages in clk CMD lines before write dump.
Old 11-04-2018, 15:53   #8 (permalink)
Member: 2340647
Thanks Meter: 53
Already i wiped & write full dump v1 - v2 and other dump from internet
The info in logo is 100% correct
thak u
Old 11-05-2018, 05:07   #9 (permalink)
Member: 1368525
Thanks Meter: 22
did you change emmc or use phone bricked emmc??
Sent from my Nokia 2 using Tapatalk
Old 11-05-2018, 13:05   #10 (permalink)
Member: 2340647
Thanks Meter: 53
No - the device dead after flash
the lines should be removed from device when power on?
anyways i removed lines and same problem
sorry for bad english
thank u
Old 11-05-2018, 15:19   #11 (permalink)
Member: 2463805
Thanks Meter: 25
What was the problem?
Why did you flashed it ? Did you flashed wrong firmware? Give some details of the phone condition before flashing.
Old 11-06-2018, 11:29   #12 (permalink)
Member: 2340647
Thanks Meter: 53
i flashed wrong firmware G355HXXU0ANF8_OLB0ANF3_REV3
but i don't remember why - Because the flashing is a long time ago
Old 11-08-2018, 11:42   #13 (permalink)
Member: 2463805
Thanks Meter: 25
check this thread
boot repair g355h 100% ok
Old 11-08-2018, 16:17   #14 (permalink)
Member: 2340647
Thanks Meter: 53
thank u bro...........
Page generated in 0.54840 seconds with 7 queries
