01-07-2018, 17:01 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: bangladesh
Member: 2307631 Status: Offline Sonork: 100.1661033 Thanks Meter: 9 | Sm-g530h boot repaired but no download mode log given 1/7/2018 9:13:47 PM> Looking for EasyJTAG box... 1/7/2018 9:13:47 PM> EasyJTAG API ver. 2022 1/7/2018 9:13:47 PM> Setting IO Levels to 2.8V 1/7/2018 9:13:47 PM> Setting frequence to 21 Mhz 1/7/2018 9:13:47 PM> EasyJTAG Box Serial = 1111111111111111 1/7/2018 9:13:47 PM> EasyJTAG Box Firmware = 1.62 1/7/2018 9:13:48 PM> Setting frequence to 21 Mhz 1/7/2018 9:13:48 PM> CMD Pullup Level: 1639 mV 1/7/2018 9:13:48 PM> CMD Active Level: 2237 mV 1/7/2018 9:13:48 PM> eMMC Init returned = 0 1/7/2018 9:13:48 PM> EMMC Device Information : 1/7/2018 9:13:48 PM> EMMC CID: 150100514E31534D4200A0FBC2A052F6 1/7/2018 9:13:48 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C 1/7/2018 9:13:48 PM> EMMC Manufacture Name: SAMSUNG , EMMC NAME: QN1SMB , EMMC NAME (HEX): 514E31534D42 , S/N: A0FBC2A0 , rev. 0x00 1/7/2018 9:13:48 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015 1/7/2018 9:13:48 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 1/7/2018 9:13:48 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 1/7/2018 9:13:48 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) 1/7/2018 9:13:48 PM> EMMC Permanent Write Protection: No 1/7/2018 9:13:48 PM> EMMC Temporary Write Protection: No 1/7/2018 9:13:48 PM> Extended CSD Information : 1/7/2018 9:13:48 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 1/7/2018 9:13:49 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 1/7/2018 9:13:49 PM> Boot Bus Config: 0x00 , width 1bit 1/7/2018 9:13:49 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 1/7/2018 9:13:49 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 1/7/2018 9:13:49 PM> Device supports partitioning features 1/7/2018 9:13:49 PM> Device can have enhanced technological features in partitions and user data area 1/7/2018 9:13:49 PM> Device can have extended partitions attribute 1/7/2018 9:13:49 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 1/7/2018 9:13:49 PM> Backup saved: QN1SMB_A0FBC2A0_20180107_211349.extcsd 1/7/2018 9:13:49 PM> EMMC Init completed. 1/7/2018 9:13:49 PM> 1/7/2018 9:13:49 PM> Operation: Write all eMMC Regions at once 1/7/2018 9:13:49 PM> 1/7/2018 9:13:49 PM> Writing BootConfig ... 1/7/2018 9:13:49 PM> Reg: 179 Value: 0x00 1/7/2018 9:13:50 PM> Reg: 177 Value: 0x00 1/7/2018 9:13:51 PM> Reg: 162 Value: 0x00 1/7/2018 9:13:52 PM> Done 1/7/2018 9:13:52 PM> 1/7/2018 9:13:53 PM> Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 1/7/2018 9:13:53 PM> Filename: EMMC_ROM2_00000000_00400000.bin 1/7/2018 9:13:53 PM> eMMC switching to ROM2 1/7/2018 9:13:54 PM> Writing partition... 1/7/2018 9:14:33 PM> Done writing partition. Write speed: 105.00 KB/s 1/7/2018 9:14:33 PM> 1/7/2018 9:14:33 PM> Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 1/7/2018 9:14:33 PM> Filename: EMMC_ROM3_00000000_00400000.bin 1/7/2018 9:14:34 PM> eMMC switching to ROM3 1/7/2018 9:14:35 PM> Writing partition... 1/7/2018 9:15:14 PM> Done writing partition. Write speed: 105.08 KB/s 1/7/2018 9:15:14 PM> 1/7/2018 9:15:14 PM> Writing to: ROM1 , start: 0x000000000000 , size: 0x000008000000 1/7/2018 9:15:14 PM> Filename: EMMC_ROM1_00000000_08000000.bin 1/7/2018 9:15:15 PM> eMMC switching to ROM1 1/7/2018 9:15:15 PM> Writing partition... 1/7/2018 9:19:39 PM> Done writing partition. Write speed: 497.80 KB/s 1/7/2018 9:19:39 PM> 1/7/2018 9:19:39 PM> All done time: [00:05:46:030] 1/7/2018 9:21:25 PM> 1/7/2018 9:21:25 PM> Looking for EasyJTAG box... 1/7/2018 9:21:25 PM> EasyJTAG API ver. 2022 1/7/2018 9:21:25 PM> Setting IO Levels to 2.8V 1/7/2018 9:21:25 PM> Setting frequence to 21 Mhz 1/7/2018 9:21:25 PM> EasyJTAG Box Serial = 111111111111 1/7/2018 9:21:25 PM> EasyJTAG Box Firmware = 1.62 1/7/2018 9:21:27 PM> Setting frequence to 21 Mhz 1/7/2018 9:21:27 PM> CMD Pullup Level: 1650 mV 1/7/2018 9:21:27 PM> CMD Active Level: 2237 mV 1/7/2018 9:21:27 PM> eMMC Init returned = 0 1/7/2018 9:21:27 PM> EMMC Device Information : 1/7/2018 9:21:27 PM> EMMC CID: 150100514E31534D4200A0FBC2A052F6 1/7/2018 9:21:27 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C 1/7/2018 9:21:27 PM> EMMC Manufacture Name: SAMSUNG , EMMC NAME: QN1SMB , EMMC NAME (HEX): 514E31534D42 , S/N: A0FBC2A0 , rev. 0x00 1/7/2018 9:21:27 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015 1/7/2018 9:21:27 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 1/7/2018 9:21:27 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 1/7/2018 9:21:27 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) 1/7/2018 9:21:27 PM> EMMC Permanent Write Protection: No 1/7/2018 9:21:27 PM> EMMC Temporary Write Protection: No 1/7/2018 9:21:27 PM> Extended CSD Information : 1/7/2018 9:21:27 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 1/7/2018 9:21:27 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 1/7/2018 9:21:27 PM> Boot Bus Config: 0x00 , width 1bit 1/7/2018 9:21:27 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 1/7/2018 9:21:27 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 1/7/2018 9:21:27 PM> Device supports partitioning features 1/7/2018 9:21:27 PM> Device can have enhanced technological features in partitions and user data area 1/7/2018 9:21:27 PM> Device can have extended partitions attribute 1/7/2018 9:21:27 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 1/7/2018 9:21:27 PM> Backup saved: QN1SMB_A0FBC2A0_20180107_212127.extcsd 1/7/2018 9:21:27 PM> EMMC Init completed. 1/7/2018 9:21:27 PM> 1/7/2018 9:21:27 PM> Get firmware version 1/7/2018 9:21:27 PM> 1/7/2018 9:21:36 PM> Brand = samsung 1/7/2018 9:21:36 PM> Manufacturer = samsung 1/7/2018 9:21:36 PM> Model = SM-G530H 1/7/2018 9:21:36 PM> Phone platform = msm8916 1/7/2018 9:21:36 PM> CPU Abi = armeabi-v7a 1/7/2018 9:21:36 PM> Android release = 4.4.4 1/7/2018 9:21:36 PM> Firmware version = KTU84P.G530HXXU1ANJ3 1/7/2018 9:21:36 PM> Firmware date = Tue Oct 21 21:46:27 KST 2014 |
01-08-2018, 14:29 | #2 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | 1-movinand format and resett 2-movinand factory reset 3-repaire EXTCSD 4-wrte dump all regons https://www.4shared.com/rar/9lgjFyL3...sted_thor.html |
The Following User Says Thank You to ilyasrao For This Useful Post: |
01-17-2018, 11:12 | #3 (permalink) | |
Member: 2307631 Status: Offline Sonork: 100.1661033 Thanks Meter: 9 | movinand format?? Quote:
where is movinand format situated ? please | |
The Following User Says Thank You to rasheddk For This Useful Post: |
