06-29-2017, 15:24 | #106 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | Quote:
Fulldump is not the solution, already try 8gb dump but doesn't work! Only the imei change but if you check in *#0011# it's still have error Sent from my iPhone using Tapatalk | |
The Following User Says Thank You to Sniper_04 For This Useful Post: |
07-07-2017, 14:50 | #107 (permalink) | |
Freak Poster Join Date: Dec 2013 Location: India
Member: 2077370 Status: Offline Sonork: 100.1616788 Thanks Meter: 268 | i need g532g boot repair file kst Quote:
CMD Pullup Level:2041 mV CMD Active Level:2516 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A483847347592013313BD2A34AC EMMC CSD : D02701320F5903FFFFFFFFE78A40002A EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 03/2017 Rev.0x1 EMMC NAME: H8G4u , S/N: 856931626 EMMC NAME (HEX): 48384734752000 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G4u _ 856931626_20170707_1855.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: 749FDD sectors 3.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 7643135 Found Data areas (firmware parts) count is: 29 Partition info successfully found --------------------------------------------- P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (NVRAM) [0x800000 0x800000] Size: 8.0MB P2 (LK) [0x1000000 0x200000] Size: 2.0MB P3 (BOTA1) [0x1200000 0x200000] Size: 2.0MB P4 (SECRO) [0x1400000 0x700000] Size: 7.0MB P5 (SECCFG) [0x1b00000 0x80000] Size: 512.0KB P6 (EFUSE) [0x1b80000 0x80000] Size: 512.0KB P7 (TEE1) [0x1c00000 0x600000] Size: 6.0MB P8 (BOTA2) [0x2200000 0x600000] Size: 6.0MB P9 (EFS) [0x2800000 0x800000] Size: 8.0MB P10 (NVDATA) [0x3000000 0x2000000] Size: 32.0MB P11 (PARAM) [0x5000000 0x800000] Size: 8.0MB P12 (RECOVERY) [0x5800000 0x1000000] Size: 16.0MB P13 (BOOT) [0x6800000 0x1000000] Size: 16.0MB P14 (MD1IMG) [0x7800000 0x2000000] Size: 32.0MB P15 (MD1DSP) [0x9800000 0x400000] Size: 4.0MB P16 (KEYSTORE) [0x9c00000 0x800000] Size: 8.0MB P17 (OMEKEYSTORE) [0xa400000 0x380000] Size: 3.500MB P18 (PROINFO) [0xa780000 0x280000] Size: 2.500MB P19 (PARA) [0xaa00000 0x80000] Size: 512.0KB P20 (PERSISTENT) [0xaa80000 0x80000] Size: 512.0KB P21 (STEADY) [0xab00000 0x100000] Size: 1.0MB P22 (PROTECT1) [0xac00000 0x800000] Size: 8.0MB P23 (PROTECT2) [0xb400000 0x800000] Size: 8.0MB P24 (RESERVE2) [0xbc00000 0x400000] Size: 4.0MB P25 (SYSTEM) [0xc000000 0xc0800000] Size: 3.7GB P26 (CACHE) [0xcc800000 0x19000000] Size: 400.0MB P27 (HIDDEN) [0xe5800000 0x3c00000] Size: 60.0MB P28 (USERDATA) [0xe9400000 0] Size: 0.0B ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000C000000 (3.7GB) Build ID: MMB29T Display Build ID: MMB29T.G532GDXU1APJ7 Release ID: 6.0.1 Device Model: SM-G532G Device Name: grandppltedx Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: mt6737t Product ID: grandpplte Build Description: grandppltedx-user 6.0.1 MMB29T G532GDXU1APJ7 release-keys Samsung CPU: MT6737T --------------------------------------------- Done. | |
07-11-2017, 09:01 | #108 (permalink) |
Freak Poster Join Date: Jul 2009 Location: Bangladesh-{Narayanganj-Dhaka}
Member: 1077758 Status: Offline Sonork: 100.1619202 Thanks Meter: 435 | samsung G532F Boot repair done but still dead flash after dead samsung G532F Boot repair done but still dead how to solved help anybody |
07-11-2017, 15:47 | #113 (permalink) |
No Life Poster Join Date: Dec 2007 Location: B.DESH (narayangonj) Age: 39
Member: 648428 Status: Offline Thanks Meter: 846 | EasyJtag Suite ver.: 2.3.0.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7600). undefined Android Explorer ver.: 1.0.0.6 eMMC ODIN ver.: 1.0.0.8 Successfully connected to box on COM5 Box S/N: 0CFF4012558EC295, ,FW Ver.: 01.58 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AAE8-ECBB , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [JTAG] : ACTIVATED Checking NAND Image : C:\Users\nazmul\Desktop\New folder\Samsung_SM-G532F_dump_rom1_192mb\Samsung_SM-G532F_dump_rom1_192mb.bin File successefuly loaded! Processing file...C:\Users\nazmul\Desktop\New folder\Samsung_SM-G532F_dump_rom1_192mb\Samsung_SM-G532F_dump_rom1_192mb.bin Z3X EasyJtag Software ver. 2.3.0.0 Loading eMMC Addon Firmware... CMD Pullup Level:2052 mVCMD Active Level:2310 mV Input file : C:\Users\nazmul\Desktop\New folder\Samsung_SM-G532F_dump_rom1_192mb\Samsung_SM-G532F_dump_rom1_192mb.binWriting 0000400000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1337 kB/s |
07-11-2017, 20:10 | #116 (permalink) |
No Life Poster Join Date: Jan 2003 Location: GMT +5 Age: 49
Member: 19737 Status: Offline Thanks Meter: 133 | I checked many time this model for boot repair but all times fail. Easy jtag write by vender have many bugs and complecations. Sent from my SAMSUNG-SM-G920A using Tapatalk |
07-19-2017, 16:51 | #117 (permalink) |
Crazy Poster Join Date: Sep 2013 Location: mooroco
Member: 2024815 Status: Offline Thanks Meter: 6 | G532G no power after boot repair hi evryone mi probleme is with G532G dead during flash i repaired boot using easyjtag successfully but phone not power also probleme with G532f repair done using rom1 rom2 writh flash direct emmc but phone sttile dead i need helpe of you thanks in advance. |
