07-24-2017, 06:54 | #123 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
Samsung G532G dead boot repair done | |
The Following User Says Thank You to maxpro12 For This Useful Post: |
07-29-2017, 19:43 | #126 (permalink) | |
Crazy Poster Join Date: Sep 2013 Location: mooroco
Member: 2024815 Status: Offline Thanks Meter: 6 | Quote:
07-30-2017, 09:16 | #127 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Dhaka mirpur-1 Age: 38
Member: 577653 Status: Offline Thanks Meter: 235 | Another g532g dead boot repair done HiPower mode is OFF CMD Pullup Level: 2052 mV CMD Active Level: 2464 mV EMMC Device Information : EMMC CID: 90014A4838473475920135C9992034BE EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture Name: SKHYNIX EMMC NAME: H8G4u , S/N: 35C99920 , rev. 01 EMMC NAME (HEX): 483847347592 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H8G4u_35C99920_20170730_141059.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 180.58 Kb/s Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 711.31 Kb/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 15.64 Kb/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 696.12 Kb/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 743.68 Kb/s All done |
07-30-2017, 11:55 | #129 (permalink) | |
08-02-2017, 07:45 | #130 (permalink) |
No Life Poster Join Date: Aug 2007 Location: earth
Member: 570373 Status: Offline Thanks Meter: 236 | eMMC_tool Suite ver. 1.0.0.47 Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 2.8V Setting frequence to 14 Mhz HiPower mode is OFF EasyJTAG Box Serial = 0800200 Card Serial = AA9 EasyJTAG Box Firmware = 01.58 Changelog: 28.05.2017 (ver 1.0.0.47) Fix: Bugs that have been found through your crash report Fix: Searching for partitions when scanning MBR Fix: Searching for MassStorage devices Add: AutoUpdate for the program HiPower mode is OFF CMD Pullup Level: 2815 mV CMD Active Level: 2774 mV Can't init device. Reason: CMD Timeout Error HiPower mode is OFF CMD Pullup Level: 3196 mV CMD Active Level: 3031 mV Can't init device. Reason: CMD Timeout Error pls help me |
08-06-2017, 15:17 | #135 (permalink) |
Member: 577653 Status: Offline Thanks Meter: 235 | Another g532g dead boot repair done HiPower mode is OFF CMD Pullup Level: 2103 mV CMD Active Level: 2897 mV EMMC Device Information : EMMC CID: 90014A4838473475920120E6ACFC549C EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture Name: SKHYNIX EMMC NAME: H8G4u , S/N: 20E6ACFC , rev. 01 EMMC NAME (HEX): 483847347592 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H8G4u_20E6ACFC_20170806_201351.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 201.36 Kb/s Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 721.74 Kb/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 15.82 Kb/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 740.26 Kb/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 748.00 Kb/s All done |
