Old 09-15-2017, 05:55   #166 (permalink)
Crazy Poster
Member: 1558132
Thanks Meter: 2
I manage to root the phone and flash ******* recovery so I have a root and the computer give me to options to send commend in adb and I have SU privilege so if you have a commend how to reset the EFS in adb commend please tell me because I try one method not work
Old 09-16-2017, 20:39   #167 (permalink)
Crazy Poster
Member: 1558132
Thanks Meter: 2
Thanks to all the user that try to help me .... I fix the Problem by I take one of the phones that I manage to fix and I just solder the wires again to the phone and connected to the EasyJtag and I mount the EFS Partition and back up it and flash it to the phone that have a EFS problem and it work now I have no imei I fix the imei with a cert file but I have now network problem Emergency call only efs not help and Repair Network or Patch Cert not support in any box yet so I not know what to do next
Old 09-19-2017, 11:49   #168 (permalink)
Member: 902423
Sonork: Davidlab
Thanks Meter: 2
Originally Posted by redrose2009 View Post
Password working and phone alive
thx bro
br
redrose2009
pasword : BY MASUM MT
Old 10-04-2017, 07:12   #169 (permalink)
Shohel_sst's Avatar
Member: 577653
Thanks Meter: 235
Another dead boot done
Creating GPT-partitioninig
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 197.25 Kb/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 367.59 Kb/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 15.54 Kb/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 677.70 Kb/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 721.22 Kb/s
All done
Old 10-10-2017, 11:17   #170 (permalink)
aikonmani's Avatar
Member: 304090
Thanks Meter: 210
Originally Posted by sadak89 View Post
I'm facing same as here please help
I also have this same problem.
Any solution?
Old 10-12-2017, 13:30   #171 (permalink)
Member: 2566585
Sonork: 100.1673331
Thanks Meter: 5
Unhappy sm-g532f dead boot repair
hi
mr blang i have g532f dead phone i try to repair with rom1 and 2 from suport side file .
emmc write file done but phone not on .
i have also 1 working phone i want to read rom1 and 2 from this phone
can tell me wich can you tel me start hex and length of rom1 and 2
Old 10-12-2017, 13:33   #172 (permalink)
Member: 1820874
Thanks Meter: 20
Originally Posted by helpdesk1 View Post
hi
You need only pit and boot loader
Envoyé de mon iPhone en utilisant Tapatalk
Old 10-12-2017, 14:47   #173 (permalink)
Member: 2566585
Sonork: 100.1673331
Thanks Meter: 5
Unhappy sm-g532f still dead
i flash with letest bootloder and pit but phone not power on .
10/12/2017 4:23:23 PM> eMMC_tool Suite ver. 1.4.8.0
10/12/2017 4:23:23 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
10/12/2017 4:23:23 PM> Looking for EasyJTAG box...
10/12/2017 4:23:23 PM> EasyJTAG API ver. 2008
10/12/2017 4:23:23 PM> Setting IO Levels to 1.8V
10/12/2017 4:23:23 PM> Setting frequence to 14 Mhz
10/12/2017 4:23:23 PM> HiPower mode is OFF
10/12/2017 4:23:25 PM> OpenUSB returned = 0
10/12/2017 4:23:25 PM> Power Controller returned = 0
10/12/2017 4:23:26 PM> EasyJTAG Box Serial = *********************
10/12/2017 4:23:32 PM> Card Serial = ****************
10/12/2017 4:23:32 PM> CardAttr = ********************
10/12/2017 4:23:32 PM> EasyJTAG Box Firmware = 01.60
10/12/2017 4:24:15 PM> Looking for EasyJTAG box...
10/12/2017 4:24:15 PM> EasyJTAG API ver. 2008
10/12/2017 4:24:15 PM> Setting IO Levels to 1.8V
10/12/2017 4:24:15 PM> Setting frequence to 14 Mhz
10/12/2017 4:24:15 PM> HiPower mode is OFF
10/12/2017 4:24:16 PM> OpenUSB returned = 0
10/12/2017 4:24:16 PM> Power Controller returned = 0
10/12/2017 4:24:17 PM> EasyJTAG Box Serial = 0C0C17118AA3D768
10/12/2017 4:24:17 PM> EasyJTAG Box Firmware = 01.60
10/12/2017 4:24:17 PM> HiPower mode is OFF
10/12/2017 4:24:18 PM> Frequence: 14 Mhz
10/12/2017 4:24:18 PM> CMD Pullup Level: 1680 mV
10/12/2017 4:24:18 PM> CMD Active Level: 1753 mV
10/12/2017 4:24:18 PM> eMMC Init returned = 0
10/12/2017 4:24:18 PM> EMMC Device Information :
10/12/2017 4:24:18 PM> EMMC CID: 150100514E31364242008DD04E0D343A
10/12/2017 4:24:18 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
10/12/2017 4:24:18 PM> EMMC Manufacture Name: SAMSUNG
10/12/2017 4:24:18 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0100
10/12/2017 4:24:18 PM> EMMC Manufacture Date: 3/2017 , Rev: 00
10/12/2017 4:24:18 PM> EMMC NAME: QN16BB , S/N: 8DD04E0D , rev. 00
10/12/2017 4:24:18 PM> EMMC NAME (HEX): 514E31364242
10/12/2017 4:24:18 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/12/2017 4:24:18 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/12/2017 4:24:18 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/12/2017 4:24:18 PM> EMMC Permanent Write Protection: No
10/12/2017 4:24:18 PM> EMMC Temporary Write Protection: No
10/12/2017 4:24:18 PM> Extended CSD Information :
10/12/2017 4:24:18 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/12/2017 4:24:18 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/12/2017 4:24:18 PM> Boot Bus Config: 0x00 , width 1bit
10/12/2017 4:24:18 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/12/2017 4:24:18 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/12/2017 4:24:18 PM> Device supports partitioning features
10/12/2017 4:24:18 PM> Device can have enhanced technological features in partitions and user data area
10/12/2017 4:24:18 PM> Device can have extended partitions attribute
10/12/2017 4:24:18 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/12/2017 4:24:18 PM> Backup saved: QN16BB_8DD04E0D_20171012_162418.extcsd
10/12/2017 4:24:18 PM> EMMC Init completed.
10/12/2017 4:24:18 PM> Opening file: C:\Users\kbt\Downloads\Compressed\SM-G532F_1_20170413062629_n9b88m9yfg_fac\GRANDPPLTE_C IS_SER.pit
10/12/2017 4:24:18 PM> Pit: GRANDPPLTE_CIS_SER.pit
10/12/2017 4:24:18 PM> Entry count: 34
10/12/2017 4:24:18 PM> The size of the last section has been updated
10/12/2017 4:24:36 PM> Selected file: E:\g532f gold\BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_ user_low_ship_MULTI_CERT.tar.md5
10/12/2017 4:24:36 PM> BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_user_ low_ship_MULTI_CERT.tar.md5
10/12/2017 4:24:36 PM> The list of files in the firmware:
10/12/2017 4:24:36 PM> preloader.img
10/12/2017 4:24:36 PM> lk.bin
10/12/2017 4:24:36 PM> param.bin
10/12/2017 4:24:36 PM> trustzone.bin
10/12/2017 4:24:37 PM> efuse.img
10/12/2017 4:24:40 PM> Looking for EasyJTAG box...
10/12/2017 4:24:40 PM> EasyJTAG API ver. 2008
10/12/2017 4:24:40 PM> Setting IO Levels to 1.8V
10/12/2017 4:24:40 PM> Setting frequence to 14 Mhz
10/12/2017 4:24:40 PM> HiPower mode is OFF
10/12/2017 4:24:41 PM> OpenUSB returned = 0
10/12/2017 4:24:41 PM> Power Controller returned = 0
10/12/2017 4:24:42 PM> EasyJTAG Box Serial = 0C0C17118AA3D768
10/12/2017 4:24:42 PM> EasyJTAG Box Firmware = 01.60
10/12/2017 4:24:42 PM> HiPower mode is OFF
10/12/2017 4:24:42 PM> Frequence: 14 Mhz
10/12/2017 4:24:42 PM> CMD Pullup Level: 1670 mV
10/12/2017 4:24:42 PM> CMD Active Level: 1742 mV
10/12/2017 4:24:42 PM> eMMC Init returned = 0
10/12/2017 4:24:42 PM> EMMC Device Information :
10/12/2017 4:24:42 PM> EMMC CID: 150100514E31364242008DD04E0D343A
10/12/2017 4:24:42 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
10/12/2017 4:24:42 PM> EMMC Manufacture Name: SAMSUNG
10/12/2017 4:24:42 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0100
10/12/2017 4:24:42 PM> EMMC Manufacture Date: 3/2017 , Rev: 00
10/12/2017 4:24:42 PM> EMMC NAME: QN16BB , S/N: 8DD04E0D , rev. 00
10/12/2017 4:24:42 PM> EMMC NAME (HEX): 514E31364242
10/12/2017 4:24:42 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/12/2017 4:24:42 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/12/2017 4:24:42 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/12/2017 4:24:42 PM> EMMC Permanent Write Protection: No
10/12/2017 4:24:42 PM> EMMC Temporary Write Protection: No
10/12/2017 4:24:42 PM> Extended CSD Information :
10/12/2017 4:24:42 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/12/2017 4:24:42 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/12/2017 4:24:42 PM> Boot Bus Config: 0x00 , width 1bit
10/12/2017 4:24:42 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/12/2017 4:24:43 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/12/2017 4:24:43 PM> Device supports partitioning features
10/12/2017 4:24:43 PM> Device can have enhanced technological features in partitions and user data area
10/12/2017 4:24:43 PM> Device can have extended partitions attribute
10/12/2017 4:24:43 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/12/2017 4:24:43 PM> Backup saved: QN16BB_8DD04E0D_20171012_162443.extcsd
10/12/2017 4:24:43 PM> EMMC Init completed.
10/12/2017 4:24:43 PM> Operation: Write by vendor (Samsung)
10/12/2017 4:24:43 PM> Creating GPT-partitioninig
10/12/2017 4:24:43 PM> Writing PIT at address: 000000004400
10/12/2017 4:24:43 PM> GPT-partitioning done
10/12/2017 4:24:43 PM> Unpacking file: preloader.img
10/12/2017 4:24:43 PM> Unpacking file: lk.bin
10/12/2017 4:24:43 PM> Unpacking file: efuse.img
10/12/2017 4:24:43 PM> Unpacking file: trustzone.bin
10/12/2017 4:24:43 PM> Unpacking file: param.bin
10/12/2017 4:24:43 PM> Partition name: BOOTLOADER
10/12/2017 4:24:43 PM> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
10/12/2017 4:24:43 PM> eMMC switching to ROM2
10/12/2017 4:24:43 PM> Erasing partition...
10/12/2017 4:24:50 PM> Writing partition...
10/12/2017 4:24:50 PM> Done writing partition. Write speed: 354.35 Kb/s
10/12/2017 4:24:50 PM> Partition name: LK
10/12/2017 4:24:50 PM> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
10/12/2017 4:24:50 PM> eMMC switching to ROM1
10/12/2017 4:24:50 PM> Erasing partition...
10/12/2017 4:24:52 PM> Writing partition...
10/12/2017 4:24:53 PM> Done writing partition. Write speed: 434.90 Kb/s
10/12/2017 4:24:53 PM> Partition name: EFUSE
10/12/2017 4:24:53 PM> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
10/12/2017 4:24:53 PM> eMMC switching to ROM1
10/12/2017 4:24:53 PM> Erasing partition...
10/12/2017 4:24:54 PM> Writing partition...
10/12/2017 4:24:54 PM> Done writing partition. Write speed: 87.51 Kb/s
10/12/2017 4:24:54 PM> Partition name: TEE1
10/12/2017 4:24:54 PM> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
10/12/2017 4:24:54 PM> eMMC switching to ROM1
10/12/2017 4:24:54 PM> Erasing partition...
10/12/2017 4:24:55 PM> Writing partition...
10/12/2017 4:24:55 PM> Done writing partition. Write speed: 833.94 Kb/s
10/12/2017 4:24:55 PM> Partition name: PARAM
10/12/2017 4:24:55 PM> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
10/12/2017 4:24:55 PM> eMMC switching to ROM1
10/12/2017 4:24:55 PM> Erasing partition...
10/12/2017 4:24:56 PM> Writing partition...
10/12/2017 4:24:57 PM> Done writing partition. Write speed: 822.90 Kb/s
10/12/2017 4:24:57 PM> All done
Old 10-12-2017, 20:32   #174 (permalink)
Member: 112185
Sonork: 100.1612613
Thanks Meter: 163
mine repair successfull but phone always dot go to DM
and detected as MTK usb driver !!!!
any solution ???
Old 10-14-2017, 10:38   #175 (permalink)
Member: 2566585
Sonork: 100.1673331
Thanks Meter: 5
Unhappy sm-g532f after repair dead boot power not on.
hi
sm-g532f dead boot repair showing sucsses but power not on .
Microsoft Windows
HiPower mode is OFF
Card Serial =
Changelog:
08.08.2017 (ver 1.4.8.0)
Fix: Bugs that have been found through your crash report
Fix: Saving VCF for contacts
Add: Multiple file selection for Samsung firmware
Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button)
Add: Intel vendor (for easy read/write ROM2/ROM3/GP1)
Add: "Pinouts" tab (taken from the catalog of classic software)
Add: Checker for Sony TrimArea
Add: Speed graph for "Random verify emmc"
Add: Fat16/Fat32/exFat support (Explorer)
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 1691 mV
EMMC CID: 90014A4838473475920105AA54354404
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture Name: SKHYNIX
EMMC Manufacture ID: 0x90 , OEM ID: 014A
EMMC Manufacture Date: 4/2017 , Rev: 01
EMMC NAME: H8G4u , S/N: 05AA5435 , rev. 01
EMMC NAME (HEX): 483847347592
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Backup saved: H8G4u_05AA5435_20171014_122744.extcsd
Opening file: GRANDPPLTE_CIS_SER.pit
Entry count: 34
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 1722 mV
CMD Active Level: 1732 mV
Backup saved: H8G4u_05AA5435_20171014_122805.extcsd
Done writing partition. Write speed: 304.43 Kb/s
Partition name: LK
Done writing partition. Write speed: 434.74 Kb/s
Done writing partition. Write speed: 84.47 Kb/s
Done writing partition. Write speed: 856.47 Kb/s
Done writing partition. Write speed: 811.06 Kb/s
All done
Old 10-14-2017, 20:30   #176 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 36
Unhappy sm-g532f dead boot wating for sulation.
Old 10-14-2017, 20:41   #177 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,557
are you sure boot have same or high version what boot inside phone?
Old 10-14-2017, 21:00   #178 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 36
Unhappy g532f dead boot
yes bro i am sure i use high version.
Old 10-15-2017, 06:17   #179 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
check hardware
always use pit file that contain 4files folder i mean dont get pit file from backup folder or any other resorce
Old 10-15-2017, 06:18   #180 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
check hardware
try this firmware https://firmware.gem-flash.com/index...-info&id=13198
Page generated in 0.37716 seconds with 9 queries
