09-15-2017, 05:55 | #166 (permalink) |
Crazy Poster Join Date: Apr 2011 Location: Israel
Member: 1558132 Status: Offline Thanks Meter: 2 | |
09-16-2017, 20:39 | #167 (permalink) |
Member: 1558132 Status: Offline Thanks Meter: 2 | Thanks to all the user that try to help me .... I fix the Problem by I take one of the phones that I manage to fix and I just solder the wires again to the phone and connected to the EasyJtag and I mount the EFS Partition and back up it and flash it to the phone that have a EFS problem and it work now I have no imei I fix the imei with a cert file but I have now network problem Emergency call only efs not help and Repair Network or Patch Cert not support in any box yet so I not know what to do next |
10-04-2017, 07:12 | #169 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Dhaka mirpur-1 Age: 38
Member: 577653 Status: Offline Thanks Meter: 235 | Another dead boot done Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 197.25 Kb/s Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 367.59 Kb/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 15.54 Kb/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 677.70 Kb/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 721.22 Kb/s All done |
10-12-2017, 13:30 | #171 (permalink) |
Insane Poster Join Date: Apr 2016
Member: 2566585 Status: Offline Sonork: 100.1673331 Thanks Meter: 5 | sm-g532f dead boot repair hi mr blang i have g532f dead phone i try to repair with rom1 and 2 from suport side file . emmc write file done but phone not on . i have also 1 working phone i want to read rom1 and 2 from this phone can tell me wich can you tel me start hex and length of rom1 and 2 |
10-12-2017, 13:33 | #172 (permalink) | |
Insane Poster Join Date: Oct 2012 Location: morroco
Member: 1820874 Status: Offline Thanks Meter: 20 | Quote:
You need only pit and boot loader Envoyé de mon iPhone en utilisant Tapatalk | |
10-12-2017, 14:47 | #173 (permalink) |
Member: 2566585 Status: Offline Sonork: 100.1673331 Thanks Meter: 5 | sm-g532f still dead i flash with letest bootloder and pit but phone not power on . 10/12/2017 4:23:23 PM> eMMC_tool Suite ver. 1.4.8.0 10/12/2017 4:23:23 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) 10/12/2017 4:23:23 PM> 10/12/2017 4:23:23 PM> Looking for EasyJTAG box... 10/12/2017 4:23:23 PM> EasyJTAG API ver. 2008 10/12/2017 4:23:23 PM> Setting IO Levels to 1.8V 10/12/2017 4:23:23 PM> Setting frequence to 14 Mhz 10/12/2017 4:23:23 PM> HiPower mode is OFF 10/12/2017 4:23:25 PM> OpenUSB returned = 0 10/12/2017 4:23:25 PM> Power Controller returned = 0 10/12/2017 4:23:26 PM> EasyJTAG Box Serial = ********************* 10/12/2017 4:23:32 PM> Card Serial = **************** 10/12/2017 4:23:32 PM> CardAttr = ******************** 10/12/2017 4:23:32 PM> EasyJTAG Box Firmware = 01.60 10/12/2017 4:23:32 PM> 10/12/2017 4:24:15 PM> Looking for EasyJTAG box... 10/12/2017 4:24:15 PM> EasyJTAG API ver. 2008 10/12/2017 4:24:15 PM> Setting IO Levels to 1.8V 10/12/2017 4:24:15 PM> Setting frequence to 14 Mhz 10/12/2017 4:24:15 PM> HiPower mode is OFF 10/12/2017 4:24:16 PM> OpenUSB returned = 0 10/12/2017 4:24:16 PM> Power Controller returned = 0 10/12/2017 4:24:17 PM> EasyJTAG Box Serial = 0C0C17118AA3D768 10/12/2017 4:24:17 PM> EasyJTAG Box Firmware = 01.60 10/12/2017 4:24:17 PM> HiPower mode is OFF 10/12/2017 4:24:18 PM> Frequence: 14 Mhz 10/12/2017 4:24:18 PM> CMD Pullup Level: 1680 mV 10/12/2017 4:24:18 PM> CMD Active Level: 1753 mV 10/12/2017 4:24:18 PM> eMMC Init returned = 0 10/12/2017 4:24:18 PM> EMMC Device Information : 10/12/2017 4:24:18 PM> EMMC CID: 150100514E31364242008DD04E0D343A 10/12/2017 4:24:18 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C 10/12/2017 4:24:18 PM> EMMC Manufacture Name: SAMSUNG 10/12/2017 4:24:18 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0100 10/12/2017 4:24:18 PM> EMMC Manufacture Date: 3/2017 , Rev: 00 10/12/2017 4:24:18 PM> EMMC NAME: QN16BB , S/N: 8DD04E0D , rev. 00 10/12/2017 4:24:18 PM> EMMC NAME (HEX): 514E31364242 10/12/2017 4:24:18 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 10/12/2017 4:24:18 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/12/2017 4:24:18 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 10/12/2017 4:24:18 PM> EMMC Permanent Write Protection: No 10/12/2017 4:24:18 PM> EMMC Temporary Write Protection: No 10/12/2017 4:24:18 PM> Extended CSD Information : 10/12/2017 4:24:18 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 10/12/2017 4:24:18 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 10/12/2017 4:24:18 PM> Boot Bus Config: 0x00 , width 1bit 10/12/2017 4:24:18 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/12/2017 4:24:18 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/12/2017 4:24:18 PM> Device supports partitioning features 10/12/2017 4:24:18 PM> Device can have enhanced technological features in partitions and user data area 10/12/2017 4:24:18 PM> Device can have extended partitions attribute 10/12/2017 4:24:18 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 10/12/2017 4:24:18 PM> Backup saved: QN16BB_8DD04E0D_20171012_162418.extcsd 10/12/2017 4:24:18 PM> EMMC Init completed. 10/12/2017 4:24:18 PM> 10/12/2017 4:24:18 PM> Opening file: C:\Users\kbt\Downloads\Compressed\SM-G532F_1_20170413062629_n9b88m9yfg_fac\GRANDPPLTE_C IS_SER.pit 10/12/2017 4:24:18 PM> 10/12/2017 4:24:18 PM> Pit: GRANDPPLTE_CIS_SER.pit 10/12/2017 4:24:18 PM> Entry count: 34 10/12/2017 4:24:18 PM> 10/12/2017 4:24:18 PM> The size of the last section has been updated 10/12/2017 4:24:36 PM> Selected file: E:\g532f gold\BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_ user_low_ship_MULTI_CERT.tar.md5 10/12/2017 4:24:36 PM> 10/12/2017 4:24:36 PM> BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_user_ low_ship_MULTI_CERT.tar.md5 10/12/2017 4:24:36 PM> The list of files in the firmware: 10/12/2017 4:24:36 PM> preloader.img 10/12/2017 4:24:36 PM> lk.bin 10/12/2017 4:24:36 PM> param.bin 10/12/2017 4:24:36 PM> trustzone.bin 10/12/2017 4:24:37 PM> efuse.img 10/12/2017 4:24:37 PM> 10/12/2017 4:24:40 PM> Looking for EasyJTAG box... 10/12/2017 4:24:40 PM> EasyJTAG API ver. 2008 10/12/2017 4:24:40 PM> Setting IO Levels to 1.8V 10/12/2017 4:24:40 PM> Setting frequence to 14 Mhz 10/12/2017 4:24:40 PM> HiPower mode is OFF 10/12/2017 4:24:41 PM> OpenUSB returned = 0 10/12/2017 4:24:41 PM> Power Controller returned = 0 10/12/2017 4:24:42 PM> EasyJTAG Box Serial = 0C0C17118AA3D768 10/12/2017 4:24:42 PM> EasyJTAG Box Firmware = 01.60 10/12/2017 4:24:42 PM> HiPower mode is OFF 10/12/2017 4:24:42 PM> Frequence: 14 Mhz 10/12/2017 4:24:42 PM> CMD Pullup Level: 1670 mV 10/12/2017 4:24:42 PM> CMD Active Level: 1742 mV 10/12/2017 4:24:42 PM> eMMC Init returned = 0 10/12/2017 4:24:42 PM> EMMC Device Information : 10/12/2017 4:24:42 PM> EMMC CID: 150100514E31364242008DD04E0D343A 10/12/2017 4:24:42 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C 10/12/2017 4:24:42 PM> EMMC Manufacture Name: SAMSUNG 10/12/2017 4:24:42 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0100 10/12/2017 4:24:42 PM> EMMC Manufacture Date: 3/2017 , Rev: 00 10/12/2017 4:24:42 PM> EMMC NAME: QN16BB , S/N: 8DD04E0D , rev. 00 10/12/2017 4:24:42 PM> EMMC NAME (HEX): 514E31364242 10/12/2017 4:24:42 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 10/12/2017 4:24:42 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/12/2017 4:24:42 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 10/12/2017 4:24:42 PM> EMMC Permanent Write Protection: No 10/12/2017 4:24:42 PM> EMMC Temporary Write Protection: No 10/12/2017 4:24:42 PM> Extended CSD Information : 10/12/2017 4:24:42 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 10/12/2017 4:24:42 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 10/12/2017 4:24:42 PM> Boot Bus Config: 0x00 , width 1bit 10/12/2017 4:24:42 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/12/2017 4:24:43 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/12/2017 4:24:43 PM> Device supports partitioning features 10/12/2017 4:24:43 PM> Device can have enhanced technological features in partitions and user data area 10/12/2017 4:24:43 PM> Device can have extended partitions attribute 10/12/2017 4:24:43 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 10/12/2017 4:24:43 PM> Backup saved: QN16BB_8DD04E0D_20171012_162443.extcsd 10/12/2017 4:24:43 PM> EMMC Init completed. 10/12/2017 4:24:43 PM> 10/12/2017 4:24:43 PM> Operation: Write by vendor (Samsung) 10/12/2017 4:24:43 PM> 10/12/2017 4:24:43 PM> Creating GPT-partitioninig 10/12/2017 4:24:43 PM> Writing PIT at address: 000000004400 10/12/2017 4:24:43 PM> GPT-partitioning done 10/12/2017 4:24:43 PM> 10/12/2017 4:24:43 PM> Unpacking file: preloader.img 10/12/2017 4:24:43 PM> Unpacking file: lk.bin 10/12/2017 4:24:43 PM> Unpacking file: efuse.img 10/12/2017 4:24:43 PM> Unpacking file: trustzone.bin 10/12/2017 4:24:43 PM> Unpacking file: param.bin 10/12/2017 4:24:43 PM> 10/12/2017 4:24:43 PM> Partition name: BOOTLOADER 10/12/2017 4:24:43 PM> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes 10/12/2017 4:24:43 PM> eMMC switching to ROM2 10/12/2017 4:24:43 PM> Erasing partition... 10/12/2017 4:24:50 PM> Writing partition... 10/12/2017 4:24:50 PM> Done writing partition. Write speed: 354.35 Kb/s 10/12/2017 4:24:50 PM> Partition name: LK 10/12/2017 4:24:50 PM> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes 10/12/2017 4:24:50 PM> eMMC switching to ROM1 10/12/2017 4:24:50 PM> Erasing partition... 10/12/2017 4:24:52 PM> Writing partition... 10/12/2017 4:24:53 PM> Done writing partition. Write speed: 434.90 Kb/s 10/12/2017 4:24:53 PM> Partition name: EFUSE 10/12/2017 4:24:53 PM> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes 10/12/2017 4:24:53 PM> eMMC switching to ROM1 10/12/2017 4:24:53 PM> Erasing partition... 10/12/2017 4:24:54 PM> Writing partition... 10/12/2017 4:24:54 PM> Done writing partition. Write speed: 87.51 Kb/s 10/12/2017 4:24:54 PM> Partition name: TEE1 10/12/2017 4:24:54 PM> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes 10/12/2017 4:24:54 PM> eMMC switching to ROM1 10/12/2017 4:24:54 PM> Erasing partition... 10/12/2017 4:24:55 PM> Writing partition... 10/12/2017 4:24:55 PM> Done writing partition. Write speed: 833.94 Kb/s 10/12/2017 4:24:55 PM> Partition name: PARAM 10/12/2017 4:24:55 PM> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes 10/12/2017 4:24:55 PM> eMMC switching to ROM1 10/12/2017 4:24:55 PM> Erasing partition... 10/12/2017 4:24:56 PM> Writing partition... 10/12/2017 4:24:57 PM> Done writing partition. Write speed: 822.90 Kb/s 10/12/2017 4:24:57 PM> 10/12/2017 4:24:57 PM> All done 10/12/2017 4:24:57 PM> |
10-14-2017, 10:38 | #175 (permalink) |
Member: 2566585 Status: Offline Sonork: 100.1673331 Thanks Meter: 5 | sm-g532f after repair dead boot power not on. hi sm-g532f dead boot repair showing sucsses but power not on . eMMC_tool Suite ver. 1.4.8.0 Microsoft Windows Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 1.8V Setting frequence to 14 Mhz HiPower mode is OFF EasyJTAG Box Serial = Card Serial = EasyJTAG Box Firmware = 01.60 Changelog: 08.08.2017 (ver 1.4.8.0) Fix: Bugs that have been found through your crash report Fix: Saving VCF for contacts Add: Multiple file selection for Samsung firmware Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button) Add: Intel vendor (for easy read/write ROM2/ROM3/GP1) Add: "Pinouts" tab (taken from the catalog of classic software) Add: Checker for Sony TrimArea Add: Speed graph for "Random verify emmc" Add: Fat16/Fat32/exFat support (Explorer) HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 1691 mV CMD Active Level: 1742 mV EMMC Device Information : EMMC CID: 90014A4838473475920105AA54354404 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 4/2017 , Rev: 01 EMMC NAME: H8G4u , S/N: 05AA5435 , rev. 01 EMMC NAME (HEX): 483847347592 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_05AA5435_20171014_122744.extcsd EMMC Init completed. Opening file: GRANDPPLTE_CIS_SER.pit Pit: GRANDPPLTE_CIS_SER.pit Entry count: 34 The size of the last section has been updated BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: preloader.img lk.bin param.bin trustzone.bin efuse.img HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 1722 mV CMD Active Level: 1732 mV EMMC Device Information : EMMC CID: 90014A4838473475920105AA54354404 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 4/2017 , Rev: 01 EMMC NAME: H8G4u , S/N: 05AA5435 , rev. 01 EMMC NAME (HEX): 483847347592 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_05AA5435_20171014_122805.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 304.43 Kb/s Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 434.74 Kb/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 84.47 Kb/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 856.47 Kb/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 811.06 Kb/s All done |
10-15-2017, 06:18 | #180 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | check hardware always use pit file that contain 4files folder i mean dont get pit file from backup folder or any other resorce try this firmware https://firmware.gem-flash.com/index...-info&id=13198 |
