Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-19-2017, 17:59   #16 (permalink)
Member: 2024815
Thanks Meter: 2
Originally Posted by Jani-Jan View Post
I was. faced sam problem with easyjtag. I think some thing wrong with this model..
yes bro same for me i tried with 2 the first after repair just vibrat the second after repair no power
Old 07-19-2017, 18:26   #17 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 126
Did you try with any other box?
Sent from my Phone.
Old 07-19-2017, 18:28   #18 (permalink)
Member: 2024815
Thanks Meter: 2
Sent from my Phone.
no bro just easyjtag
Old 07-24-2017, 06:36   #19 (permalink)
Member: 2506794
Sonork: 100.1675120
Thanks Meter: 95
same problem..g532g repair done but no power..help z3x team,..
Old 07-24-2017, 07:54   #20 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 278
Originally Posted by hiifi View Post
hi evryone mi probleme is with G532G dead during flash i repaired boot using easyjtag successfully but phone not power also probleme with G532f repair done using rom1 rom2 writh flash direct emmc but phone sttile dead i need helpe of you thanks in advance.
You can follow flowing link and post result
Samsung G532G dead boot repair done
The Following User Says Thank You to maxpro12 For This Useful Post:
Old 07-29-2017, 18:52   #21 (permalink)
Member: 2236331
Thanks Meter: 22
my samsung g532f repair ok but still death..... any solution bro.............
Old 07-30-2017, 12:54   #22 (permalink)
Member: 2024815
Thanks Meter: 2
also tried with this but still dead somthing is worrong i need support from team
Old 08-07-2017, 11:41   #23 (permalink)
Member: 2200372
Thanks Meter: 2
just write ROM2 ROM3 or 4 file flash g532f or g532g have mtk cpu like sony c5 c4 etc have link security area
dont write ROM1 OR USERDATA because this area have NVRAM and efs and nvram and efs have (CPID) security you need backup security area if you wont change emmc or write Rom 1 or userdata and phone become dead ....
The Following User Says Thank You to mahmud544 For This Useful Post:
Old 08-15-2017, 23:50   #24 (permalink)
Member: 2024815
Thanks Meter: 2
i will try bro thanks i wrot rom 1 rom 2 nothing
Old 10-12-2017, 14:30   #25 (permalink)
Member: 2566585
Sonork: 100.1673331
Thanks Meter: 4
Unhappy sm-g532f dead boot repair
hi
mr blang i have g532f dead phone i try to repair with rom1 and 2 from suport side file .
emmc write file done but phone not on .
i have also 1 working phone i want to read rom1 and 2 from this phone
can tell me wich can you tel me start hex and length of rom1 and 2
Old 10-12-2017, 14:33   #26 (permalink)
Member: 1820874
Thanks Meter: 19
Originally Posted by helpdesk1 View Post
hi
You need only pit and boot loader
Envoyé de mon iPhone en utilisant Tapatalk
Old 10-12-2017, 15:47   #27 (permalink)
Member: 2566585
Sonork: 100.1673331
Thanks Meter: 4
Unhappy sm-g532f still dead
i flash with letest bootloder and pit but phone not power on .
10/12/2017 4:23:23 PM> eMMC_tool Suite ver. 1.4.8.0
10/12/2017 4:23:23 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
10/12/2017 4:23:23 PM> Looking for EasyJTAG box...
10/12/2017 4:23:23 PM> EasyJTAG API ver. 2008
10/12/2017 4:23:23 PM> Setting IO Levels to 1.8V
10/12/2017 4:23:23 PM> Setting frequence to 14 Mhz
10/12/2017 4:23:23 PM> HiPower mode is OFF
10/12/2017 4:23:25 PM> OpenUSB returned = 0
10/12/2017 4:23:25 PM> Power Controller returned = 0
10/12/2017 4:23:26 PM> EasyJTAG Box Serial = *********************
10/12/2017 4:23:32 PM> Card Serial = ****************
10/12/2017 4:23:32 PM> CardAttr = ********************
10/12/2017 4:23:32 PM> EasyJTAG Box Firmware = 01.60
10/12/2017 4:24:15 PM> Looking for EasyJTAG box...
10/12/2017 4:24:15 PM> EasyJTAG API ver. 2008
10/12/2017 4:24:15 PM> Setting IO Levels to 1.8V
10/12/2017 4:24:15 PM> Setting frequence to 14 Mhz
10/12/2017 4:24:15 PM> HiPower mode is OFF
10/12/2017 4:24:16 PM> OpenUSB returned = 0
10/12/2017 4:24:16 PM> Power Controller returned = 0
10/12/2017 4:24:17 PM> EasyJTAG Box Serial = 0C0C17118AA3D768
10/12/2017 4:24:17 PM> EasyJTAG Box Firmware = 01.60
10/12/2017 4:24:17 PM> HiPower mode is OFF
10/12/2017 4:24:18 PM> Frequence: 14 Mhz
10/12/2017 4:24:18 PM> CMD Pullup Level: 1680 mV
10/12/2017 4:24:18 PM> CMD Active Level: 1753 mV
10/12/2017 4:24:18 PM> eMMC Init returned = 0
10/12/2017 4:24:18 PM> EMMC Device Information :
10/12/2017 4:24:18 PM> EMMC CID: 150100514E31364242008DD04E0D343A
10/12/2017 4:24:18 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
10/12/2017 4:24:18 PM> EMMC Manufacture Name: SAMSUNG
10/12/2017 4:24:18 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0100
10/12/2017 4:24:18 PM> EMMC Manufacture Date: 3/2017 , Rev: 00
10/12/2017 4:24:18 PM> EMMC NAME: QN16BB , S/N: 8DD04E0D , rev. 00
10/12/2017 4:24:18 PM> EMMC NAME (HEX): 514E31364242
10/12/2017 4:24:18 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/12/2017 4:24:18 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/12/2017 4:24:18 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/12/2017 4:24:18 PM> EMMC Permanent Write Protection: No
10/12/2017 4:24:18 PM> EMMC Temporary Write Protection: No
10/12/2017 4:24:18 PM> Extended CSD Information :
10/12/2017 4:24:18 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/12/2017 4:24:18 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/12/2017 4:24:18 PM> Boot Bus Config: 0x00 , width 1bit
10/12/2017 4:24:18 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/12/2017 4:24:18 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/12/2017 4:24:18 PM> Device supports partitioning features
10/12/2017 4:24:18 PM> Device can have enhanced technological features in partitions and user data area
10/12/2017 4:24:18 PM> Device can have extended partitions attribute
10/12/2017 4:24:18 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/12/2017 4:24:18 PM> Backup saved: QN16BB_8DD04E0D_20171012_162418.extcsd
10/12/2017 4:24:18 PM> EMMC Init completed.
10/12/2017 4:24:18 PM> Opening file: C:\Users\kbt\Downloads\Compressed\SM-G532F_1_20170413062629_n9b88m9yfg_fac\GRANDPPLTE_C IS_SER.pit
10/12/2017 4:24:18 PM> Pit: GRANDPPLTE_CIS_SER.pit
10/12/2017 4:24:18 PM> Entry count: 34
10/12/2017 4:24:18 PM> The size of the last section has been updated
10/12/2017 4:24:36 PM> Selected file: E:\g532f gold\BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_ user_low_ship_MULTI_CERT.tar.md5
10/12/2017 4:24:36 PM> BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_user_ low_ship_MULTI_CERT.tar.md5
10/12/2017 4:24:36 PM> The list of files in the firmware:
10/12/2017 4:24:36 PM> preloader.img
10/12/2017 4:24:36 PM> lk.bin
10/12/2017 4:24:36 PM> param.bin
10/12/2017 4:24:36 PM> trustzone.bin
10/12/2017 4:24:37 PM> efuse.img
10/12/2017 4:24:40 PM> Looking for EasyJTAG box...
10/12/2017 4:24:40 PM> EasyJTAG API ver. 2008
10/12/2017 4:24:40 PM> Setting IO Levels to 1.8V
10/12/2017 4:24:40 PM> Setting frequence to 14 Mhz
10/12/2017 4:24:40 PM> HiPower mode is OFF
10/12/2017 4:24:41 PM> OpenUSB returned = 0
10/12/2017 4:24:41 PM> Power Controller returned = 0
10/12/2017 4:24:42 PM> EasyJTAG Box Serial = 0C0C17118AA3D768
10/12/2017 4:24:42 PM> EasyJTAG Box Firmware = 01.60
10/12/2017 4:24:42 PM> HiPower mode is OFF
10/12/2017 4:24:42 PM> Frequence: 14 Mhz
10/12/2017 4:24:42 PM> CMD Pullup Level: 1670 mV
10/12/2017 4:24:42 PM> CMD Active Level: 1742 mV
10/12/2017 4:24:42 PM> eMMC Init returned = 0
10/12/2017 4:24:42 PM> EMMC Device Information :
10/12/2017 4:24:42 PM> EMMC CID: 150100514E31364242008DD04E0D343A
10/12/2017 4:24:42 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
10/12/2017 4:24:42 PM> EMMC Manufacture Name: SAMSUNG
10/12/2017 4:24:42 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0100
10/12/2017 4:24:42 PM> EMMC Manufacture Date: 3/2017 , Rev: 00
10/12/2017 4:24:42 PM> EMMC NAME: QN16BB , S/N: 8DD04E0D , rev. 00
10/12/2017 4:24:42 PM> EMMC NAME (HEX): 514E31364242
10/12/2017 4:24:42 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
10/12/2017 4:24:42 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
10/12/2017 4:24:42 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
10/12/2017 4:24:42 PM> EMMC Permanent Write Protection: No
10/12/2017 4:24:42 PM> EMMC Temporary Write Protection: No
10/12/2017 4:24:42 PM> Extended CSD Information :
10/12/2017 4:24:42 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
10/12/2017 4:24:42 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
10/12/2017 4:24:42 PM> Boot Bus Config: 0x00 , width 1bit
10/12/2017 4:24:42 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
10/12/2017 4:24:43 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
10/12/2017 4:24:43 PM> Device supports partitioning features
10/12/2017 4:24:43 PM> Device can have enhanced technological features in partitions and user data area
10/12/2017 4:24:43 PM> Device can have extended partitions attribute
10/12/2017 4:24:43 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
10/12/2017 4:24:43 PM> Backup saved: QN16BB_8DD04E0D_20171012_162443.extcsd
10/12/2017 4:24:43 PM> EMMC Init completed.
10/12/2017 4:24:43 PM> Operation: Write by vendor (Samsung)
10/12/2017 4:24:43 PM> Creating GPT-partitioninig
10/12/2017 4:24:43 PM> Writing PIT at address: 000000004400
10/12/2017 4:24:43 PM> GPT-partitioning done
10/12/2017 4:24:43 PM> Unpacking file: preloader.img
10/12/2017 4:24:43 PM> Unpacking file: lk.bin
10/12/2017 4:24:43 PM> Unpacking file: efuse.img
10/12/2017 4:24:43 PM> Unpacking file: trustzone.bin
10/12/2017 4:24:43 PM> Unpacking file: param.bin
10/12/2017 4:24:43 PM> Partition name: BOOTLOADER
10/12/2017 4:24:43 PM> Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
10/12/2017 4:24:43 PM> eMMC switching to ROM2
10/12/2017 4:24:43 PM> Erasing partition...
10/12/2017 4:24:50 PM> Writing partition...
10/12/2017 4:24:50 PM> Done writing partition. Write speed: 354.35 Kb/s
10/12/2017 4:24:50 PM> Partition name: LK
10/12/2017 4:24:50 PM> Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
10/12/2017 4:24:50 PM> eMMC switching to ROM1
10/12/2017 4:24:50 PM> Erasing partition...
10/12/2017 4:24:52 PM> Writing partition...
10/12/2017 4:24:53 PM> Done writing partition. Write speed: 434.90 Kb/s
10/12/2017 4:24:53 PM> Partition name: EFUSE
10/12/2017 4:24:53 PM> Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
10/12/2017 4:24:53 PM> eMMC switching to ROM1
10/12/2017 4:24:53 PM> Erasing partition...
10/12/2017 4:24:54 PM> Writing partition...
10/12/2017 4:24:54 PM> Done writing partition. Write speed: 87.51 Kb/s
10/12/2017 4:24:54 PM> Partition name: TEE1
10/12/2017 4:24:54 PM> Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
10/12/2017 4:24:54 PM> eMMC switching to ROM1
10/12/2017 4:24:54 PM> Erasing partition...
10/12/2017 4:24:55 PM> Writing partition...
10/12/2017 4:24:55 PM> Done writing partition. Write speed: 833.94 Kb/s
10/12/2017 4:24:55 PM> Partition name: PARAM
10/12/2017 4:24:55 PM> Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
10/12/2017 4:24:55 PM> eMMC switching to ROM1
10/12/2017 4:24:55 PM> Erasing partition...
10/12/2017 4:24:56 PM> Writing partition...
10/12/2017 4:24:57 PM> Done writing partition. Write speed: 822.90 Kb/s
10/12/2017 4:24:57 PM> All done
Old 10-14-2017, 11:38   #28 (permalink)
Member: 2566585
Sonork: 100.1673331
Thanks Meter: 4
Unhappy sm-g532f after repair dead boot power not on.
hi
sm-g532f dead boot repair showing sucsses but power not on .
Microsoft Windows
HiPower mode is OFF
Card Serial =
Changelog:
08.08.2017 (ver 1.4.8.0)
Fix: Bugs that have been found through your crash report
Fix: Saving VCF for contacts
Add: Multiple file selection for Samsung firmware
Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button)
Add: Intel vendor (for easy read/write ROM2/ROM3/GP1)
Add: "Pinouts" tab (taken from the catalog of classic software)
Add: Checker for Sony TrimArea
Add: Speed graph for "Random verify emmc"
Add: Fat16/Fat32/exFat support (Explorer)
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 1691 mV
EMMC CID: 90014A4838473475920105AA54354404
EMMC CSD: D02701320F5903FFFFFFFFE78A40002A
EMMC Manufacture Name: SKHYNIX
EMMC Manufacture ID: 0x90 , OEM ID: 014A
EMMC Manufacture Date: 4/2017 , Rev: 01
EMMC NAME: H8G4u , S/N: 05AA5435 , rev. 01
EMMC NAME (HEX): 483847347592
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Backup saved: H8G4u_05AA5435_20171014_122744.extcsd
Opening file: GRANDPPLTE_CIS_SER.pit
Entry count: 34
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 1722 mV
CMD Active Level: 1732 mV
Backup saved: H8G4u_05AA5435_20171014_122805.extcsd
Done writing partition. Write speed: 304.43 Kb/s
Partition name: LK
Done writing partition. Write speed: 434.74 Kb/s
Done writing partition. Write speed: 84.47 Kb/s
Done writing partition. Write speed: 856.47 Kb/s
Done writing partition. Write speed: 811.06 Kb/s
All done
Old 10-14-2017, 21:30   #29 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 33
Unhappy sm-g532f dead boot wating for sulation.
Old 10-14-2017, 21:41   #30 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 176,808
are you sure boot have same or high version what boot inside phone?
Page generated in 0.49538 seconds with 8 queries
